Question about Canon PowerShot EOS D60 Digital Camera
White balance metering
I have recently started using a digital camera, a Canon D60, and am not pleased about the white balance. When a camera samples the scene for the white balance, does it use information uniformly from the entire field, or if there is a spotmeter does it base the white balance on that part of the meter reading?
    Sergeant:
  • 255 Answers
Cameras need a white reference for that measurement, they don't get it from the meter. On your camera (which I think works pretty much like my 10D) you can take a picture of a white card (white reference); the camera would use that frame to set its WB in AUTO mode (AWB). You can also safely guesstimate the K value with a little practice for cases in which a white card is not available or no other white objects are at hand. White Balance measures the light K value which illuminates a scene it doesn't measure the objects in an image. Further, in some cases you may have mixed lighting which makes matters slightly more complex. For example: if you are shooting under tungsten ambient light and want to use flash as a main or fill light you'll have to use a gel on the flash to match the ambient light and set the camera to that K value. This will give uniform light cast (color). However, for creative purposes, it's desirable occasionally to let one of the two light sources "shift". In the example just given, if you set the camera to a K value of 5600-5800 (around a typical flash K value) and use the flash without gels then, the tungsten ambient light would appear as shifted (redish, the typical tungsten colorcast when used with daylight film/wb) while the flash light would be balanced and not shifted. This difference (shift) would give the picture a different feeling.
Posted on Sep 14, 2005
In the P S A M modes my shots have a moderate blue cast. This just started without reason. The manuakl was no help because it didn't even list the problem.
Check your white balance setting. In the point&shoot modes the camera sets the white balance automatically. In the PSAM modes you get to choose the white balance. Set it to Auto and see if that makes any difference. Set it to Cloudy or Shade and see if the pictures come out reddish or yellowish.
Aug 05, 2012 | Nikon D60 Digital Camera
Overexposed photos on a nikon D60 in sunlight
You could set the white balance to the full sun setting. You could set the ISO to a lower number. You could set the "exposure compensation" to a lower number.
Jul 14, 2010 | Nikon D60 Digital Camera
Eos camera white balance is blue D60
Having gone over a month without a response, I assume this is no longer a problem.
Apr 20, 2010 | Canon EOS 40D Digital Camera
Whats the best setting to take pictures at concerts
Turn the flash off. Set the ISO to at least 800. Use auto white balance or set it to tungsten lighting. Set the metering to spot metering.
Apr 16, 2010 | Canon PowerShot SD1200 IS / Digital IXUS...
Canon IXUS50 overexposing each photo - white balance problem?
Hello. go into your menu and find the reset function. Reset the camera and try it. If the reset to factory settings doesn't solve your problem it needs to go to the repair shop. Joe
Apr 05, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
I have nikon d60 its colors are not prefect it comes yellow blue green what should i do
change the white balance in the menu to more apprpriate in the situation you are...or put it to auto.
Jun 24, 2009 | Nikon D60 Digital Camera with 18-55mm lens
When I take pictures with my D60 on Manual the optimal exposure seems to be lying to me. In both situations dark and light everything is much much darker than it should be at optimal exposure. I want to...
Check the white balance. Set it to the corresponding lighting conditions and try the white card setting. It should be the last option on the white balance menu. To use it, snap a picture of a white piece of paper and save it. Just experiment with different settings till you get good results. Best of luck!
Jun 15, 2009 | Nikon D60 Digital Camera with 18-55mm +...
I use first time nikon d60.
it would depend on the lighting. you can lower down your shutter speed, or change the white-balance or aperture on the camera. make sure that your camera is set on manual. hit me back on the results.
Jan 30, 2009 | Nikon D60 Digital Camera with 18-55mm lens
Problems with picture
i think that its because you are on spot metering.
take it off spot metering and also make sure that you exposure is on 0.0
i allways use P mode.
my email is seekreep@yahoo.co.uk
Nov 04, 2007 | Canon PowerShot Pro1 Digital Camera
Canon PowerShot EOS D60 Digital Camera Logo
132 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
