Question about GE Microwave Ovens
I have a space saver micowave. When I start it, it sounds like somthing is getting zapped. It also does not heat. It started with microwave popcorn and does it all the time and we cannot use it. Can you tell me what it might be and how much to fix it? Thanks Bob
  • 706 Answers
Hi Bob,
Chances are ..you have either a bad magnetron tube or the filament transformer that is failing and arcing. The replacement cost of the parts & then labor to diagnose and install is probably more than it's worth so I would suggest you just consider buying another one. Also, Microwave Ovens radiate RF and unless you are trained in how to test for that and verify the shielding hasn't been compromised during repair, I wouldn't try to fix it myself. As an added concern, there is also High Voltage in there as well.. Your call.. but I would probably discard it and consider another one.. Hope that helps..
Oh.. for a quick test, remove everything from inside the cooking compartment and place a cup of water in there.. turn the microwave on for ~ 2 minutes..does the water get hot? boil or stay cold? If it stays cold.. discard it.. If it gets warm, the magnetron is probably in the midst of failing but if it gets hot .. then you may only have a loose connection in the electronics compartment ( magnetron, transformer etc) Something to hope for.. :-)
Posted on Sep 03, 2008
Jenn air microwave makes zapping sound and won't heat food
Possible bad inverter board (power) and or the Magnetron which does the main heating.
Oct 31, 2012 | Jenn-Air Microwave Ovens
My GE Space Saver Microwave that comes on but makes a buzz sound in operation and does not heat.
If it buzzes before you hit "Start", you may have a control circuit board problem or a door switch problem.
If it buzzes after you hit "Start", you would probably have a bad magnetron and/or high voltage rectifier diode.
We would need more details no the failure and of course the full model number to help you further.
Jun 20, 2011 | GE Microwave Ovens
We have a GE JVM1540 space saver microwave. It is less than a year old. Will not heat and immediately starts smelling like burning plastic. Any ideas as to what is causing that?
CHECK THE MICROWAVE MANUAL LOOK FOR FACTORY WARRANTY ,MUST BE A BAD COMPONENT ,IF YOU MICROWAVE IS UNDER 1 YEAR WARRANTY THE FACTORY WILL REPAIR IT AT NOT COST TO YOU..CONTACT GE FACTORY.
Feb 18, 2011 | GE Spacemaker JVM1540 Microwave Oven
STOP HEATING FOOD SOUNDS LIKE MICOWAVE IS STILL ON. STARTED SMOKING.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Oct 24, 2010 | Kenmore 63792 Microwave Oven
When I turn on the micowave; smell somthing burning
The magnetron (the part that heats the food) may be ready to burn out. If you smell the burning, you should then unplug the microwave, open it up and see if you can determine for sure that it is coming from that part. Unfortunately even if I am right, it is almost more cost effective to just replace the microwave rather than replace that part. You can run this microwave till it dies if you want, but I would be ready with a new one.
Let me know how this works out for you.
Benjamin
Apr 29, 2010 | KitchenAid KCMS145J Microwave Oven
WE have a JVM1650SHO5 space saver GE Microwave Oven that suddenly started not heating. No other issues.
heatman101
Mar 06, 2010 | GE JVM1650 1000 Watts Microwave Oven
GE space saver Microwave not heating
heatman101
Jun 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Reset shows on display of my GE space saver microwave oven
change the board that has the reset on the display board it is bad
Mar 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My space saver microwave will not heat. When I turn it on it sounds like somthing is getting zapped. I cannot use it. Can you tell me what is wrong and how much it would cost to fix. Model #...
Quite often this is due to grease or food particles stuck to the inside of the oven or stuck on or behind the waveguide cover.
In this model, it is a larger stirrer cover type made of thicker plastic in the ceiling of the oven.
It can be fragile, and the metal edges of the oven behind it can be sharp, so be careful!
The cover and the metal behind it should be cleaned with a mild, non-ammonia cleaner.
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly.
Then you can apply some high-temperature appliance paint, available from places like Wal-Mart, Lowe's or Builder's Square.
If your waveguide cover is burned, it will need to be replaced. It provides important protection for the magnetron.
While you have the cover off, look for grease buildup or charring on the metal and the stirrer (an antenna or blade-like device).
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
After checking this, please let us know if you still have trouble.
Sep 02, 2008 | GE Microwave Ovens
Microwave Ovens Logo
51 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
