Question about Fisher and Paykel GWL11 Top Load Washer
Gwl 10 fisher and paykel washer won't start
Washer won't start. beeps once per second with second and third washer light and one rinse light on. tried resetting, no difference. I can't even get into the diagostic mode. any ideas? other than the diverter valve, which I replaced two years ago, the machine has had no problems.
  • 46 Answers
Hi
if you can,t reset the module i would think that it is a module fault or display fault possibly moisture has got into one of the modules, if you can,t get into any service modes you will have to change modules
cheers grantsreps
Posted on Oct 02, 2008
Machine stuck in drain mode, beeps, can only turn off at powerpoint.
Your motor controller board is faulty
needs repair or new/recondition board.
May 06, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Fishwe&Paykel GWL10 won
It could be the out of balance switch faulty & need replacing.
Nov 17, 2012 | Fisher Paykel EcoSmart GWL15
My Fisher Paykel GWL 15 will only fill if Hot wash is selected. Should I call a service technician? Thanks Glenn
Try to swap the plugs and hoses to the hot /cold solenoids see if that works the hot valve with cold water if work you need to buy a cold valve.
Jan 24, 2012 | Fisher Paykel EcoSmart GWL15
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,...
GWL Washer won't spin only beeps; Diagnostic lighs:the third light is lit up green in the bank of lights on the left; the first light on the right is lit up orange and the third is lit up red. Thanks,Hepi
Jul 24, 2011 | Fisher and Paykel GWL11 Top Load Washer
Model gwl 15 us not draining
find black rubber drain hose under machine and squeeze several times to loosen soap and hair gunk.
start the mahine on the rinse cycle. This should start the draining process.
Dec 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
My fisher and Paykel gwl-11us gets stuck in the rinse mode and eventually starts beeping.
Hi just read your posting.Now when the machine starts to beep a series of lights will turn on.They will be in a row of 8 lights.Starting from the left to right which ones are lit?Is it the 2nd and 4th or the 1st and 7th ---etc---?Or if you have the model with an LCD display the error code will appear.Please reply with additional information and I am sure I can help you rectify this fault.
Aug 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
GWL 11 washer. Water does not come in when power
Hi just read your posting.Now what water setting have you selected?Is it warm cold or hot?Does the machine stop and beep with a series of lights that come on?If there are lights that come on when it beeps, they will be in a row of 8 lights.Starting from left to right which ones are lit?Is it the 3rd and 6th or 1st and 7th --etc--?Now if you have an LCD display what error code is it showing?Please reply with additional information and I can help you rectify this fault.
Jun 23, 2010 | Fisher and Paykel GWL11 Top Load Washer
During the rinse cycle, our GWL 11 Fisher & Paykel
The problem is in the pump, so it will not pump out, you will need to find another way to empty it, removing the agitator will make the job easier.
When you get the water out the pump can be accessed from underneath, it turns anticlockwise to remove it,.
I would buy a new pump as it is most likely that is all that is wrong with it.
Apr 18, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykal GWL 10 US - Stops before rinse
52. (00110100) Eco - Diverter Top-up Fault diverter valve made be stuck in half open position ,may be a mechanical obstuction or the wax filled solenoid that actuates it may be faulty .located under machine beside pump .
Jun 17, 2008 | Fisher and Paykel GWL11 Top Load Washer
...most likely the balance sensor, a small contact switch behind the main control panel that is telling the machine it is out of balance, more likely the switch and/or contacts have corroded...
Aug 06, 2007 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
167 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
sonic boom...
sonic boom...
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
