Question about Goodman CKL36AR36 Air Conditioner
10 kw heat with 2 speed fan
I am going to HVACR classes and studding for a test . and i realy need a wiring diagram for a 10 kw heater with 2 speed fan . I have to build it on a board i know i need a T-stat, a transformer, 2 heat sequencers, 2 relay switches, and 4 lights , like i say this is just like a project not a real heater , i just nees to show the wiring work . if you can help me out i will be for ever in debt to you .
Thanks
E. Bannister
E-Mail hynyburp@yahoo.com
    Prodigy:
    An expert who has answered 500 questions.
  • 540 Answers
Checkout GOODMAN ELECTRIC FURNACES . website.
Posted on Sep 04, 2008
Hi, I am getting Faulty codes P0036, P0056, P0141, P0161 in reference Bank 1 and Bank 2 for sensors 2 on 2003 CTS.I was told the sensors where changed but codes still appear?
If the sensors were replaced an DTC'S come back has to be a wiring problem or PCM ,
The ECM detects that the HO2S heater low control circuit voltage is between 2.6-4.6 volts when the heater is commanded OFF, indicating an open HO2S heater circuit.
Is the fuse open?
All four codes refer to the heating element circuit ! there is a relay in the under hood fuse box that supplies B+ voltage to the O2 sensor heating elements . I would change that or test the relay , videos on you tube on testing relays .
MAIN Relay
LO SPEED Relay, HI SPEED Relay, S/P FAN Relay, PRE O2 Fuse, IGN-1 Fuse, ECM Fuse, POST O2 Fuse, and INJ Fuse
Also check
POST O2 Fuse
10 A
HO2S Bank 1 Sensor 2 and HO2S Bank 2 Sensor 2
PRE O2 Fuse
10 A
Heated Oxygen Sensor (HO2S) Bank 1 Sensor 1 and HO2S Bank 2 Sensor 1
Jul 23, 2016 | 2003 Cadillac CTS
Tip
Frigidaire Dishwasher Error Codes and Service Test Mode
Many modern appliances have error code build in to the control programing to help with the diagnosis of a failure. Frigidaire dishwashers with display s will flash Er then a two letter error code.
Er i s a Switch error (Replace Console Pn# 154639207)
CE is a Configuration error (Replace Control Pn#154543602)
UO is a Vent that will not close. (Replace Vent Pn#154682301) or remove blockage
uF is a Vent fan Not running (Replace Vent Pn#154682301) or remove blockage
Other codes you my see in the display that are not errors
LO is Low rinse aid
PF is power failure
Ho is Water Heating
CL is close Door
01-24 hours of delay
Service Test
To enter service test you must turn off the power and PF will be displayed. While in PF press and hold Pad # 1 and Pad # 7 at which time an “rt” will appear in the display. To get it out of service test Press Pad # 1 and the Pad # 7 this will return you to PF mode.
[ (#1)(#2)(#3)(#4)(#5)(#6)(#7) (#8)(#9)(10)(11) ]
Press pad # 1 Active water valve Ultimate Scrub Maxx Clean Valve on =FL Valve off =rt
Press pad # 2 Test Speed motor (1 Time) motor @ 2800 rpms Speed Wash pad ”28′ First two digits motor speed
Press pad # 2 Test Speed motor (2 Times) wash motor @2950 rpms Speed Wash pad “29′ in display
Press pad # 2 Test Speed motor (3 Times) wash motor @3150 rpms Speed Wash pad “31′ in display
Press pad # 2 Test Speed motor (4 Times) wash motor @3450 rpms Speed Wash pad “34′ in display
Press pad # 2 Test Speed motor (5 Times) turns off wash motor No light on ”rt” in display
Press pad # 3 Test Dispenser dispenser powered Normal Wash on = “Sd” off = “rt”
Press pad # 4 Test Drain pump on/off China Crystal or Party glasses on = dP off = “rt”
Press pad # 5 Test Fan dry Active vent on/off Top Rack,Eco Wash Glasses on = Fan speed off = “rt”
Press pad # 7 Test Rinse aid level none Rinse only low = RE full = RF off = “rt”
Press pad # 8 Test Soil Sensor none Wash Silencer or Wash pressure on = sensor voltage reading off = “rt”
Press pad # 9 Test Thermistor none Wash Temperature on = Temperature in °F off = “rt”
Press pad #10 Test Heater on/off Heater on/off No Heat Dry on = HO off = “rt”
on Dec 23, 2009 | Dishwashers
I have no fan speed on my auto temp heat or ac
Replace the motor ! Test the electrical circuit ! Don't know anything about automotive electrical circuit ? Go on youtube an check out video on basic electrical trouble shooting , Also Voltage drop testing a circuit . How to read a wiring diagram . Then go to http://www.bbbind.com/free_tsb.html free wiring diagrams . Test the circuit . Do a current draw test on the blower motor . You need a amp meter to do this test .
Dec 15, 2015 | AC Cars & Trucks
Heater blower motor.,Highspeed only works..problem??
9 out of 10 times its the heater fan resistor doing this. it has wires that corresponed to diffreent speed settings for heater fan. the resistor is beside the blower motor, Your Kia Sportage Blower Motor Resistor controls the heating equipment in the vehicle by opening and closing the fan motor. The Kia Sportage Blower Motor Resistor allows the heating and climate control system to control the speed of the vehicle's cooling fan. its under the passenger side glove box. undo 2 screws and disconnect the electrical connector. thats it!!
Jan 24, 2012 | 2000 Kia Sportage
I have a 3 speed fan switch with 4 wires. The wire colors are grey,black,yellow,and brown. Where do they go such as L,1,2,3 on the switch?
Did you get a wiring diagram with the switch/fan? This should tell you which is which.
Each manufacturer has different color coding. If you didn't get a diagram, contact the manufacturer for instructions.
Good luck,
Handie Andie
Mar 25, 2011 | Solar Fan Impressions 3 Speed/4 Wire...
How can I change my goodman furnace fan motor to the low speed ? GMP075-3
First turn off the power to the fan...then take off the door to get to the fan. Once this is done depending on if you have a belt driven fan or direct drive motor (doesn't have a belt), if its a direct drive motor look at the side of the motor and check for speed taps. there are usually about five taps with one or two wires. beside the taps you might see 1,2,3,4,5 or C,H,M,L (high medium low)...simply remove the taps and go to the desired speed selection. Then turn power back on and wa-la. Others might have to be rewired on the bored and you will have to be able to read a wiring diagram for that and might need an HVACR technician to come out and have a look...hope this helps you out
Feb 11, 2011 | Heating & Cooling
I need a wire diagram for a hobart C44A
The lid to control box has diagram inside, the heat kw is in the metal ID plate on right end of top of control box
Oct 24, 2009 | Hobart Dishwashers
Need Fuse Map Diagram BMW 318i 1993
check the internet for a bmw e36 ETM ( electronic troubleshooting manual) everything you need is there.
Jun 02, 2009 | 1994 BMW 3 Series
My blower fan came off the motor shaft.
THE BLOWER MOTOR HAS 6-WIRES ....2--CAPICATOR (BROWN- BROWN WHITE STRIPE)3- SPEEDS BLACK-HI-SPEED--BLUE--MED......RED--LOW SPEED OR HEAT AND THE LAST ONE TO COMMOM.
Nov 23, 2008 | Goodman GMS90703BXA Heater
Goodman CKL36AR36 Air Conditioner Logo
120 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
