Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Fuse replacement I have a Philips Magnavox 60 rear projection. What happens is when I turn the power it does nothing. I have read that this could be a fuse. If so where would I find such a fuse and what is the price range of such an item?
  • Philips Master
  • 3,459 Answers
If the power light is on but your set has no audio and no video its likely the opt ic went out. This is a common problem with this model. The site has a chip kit that may help.
Posted on Sep 07, 2008
My Philips Magnavox 60 in rear projection TV # PTV775-AH01 has no power when you turn it on. How can I fix it?
It sounds like a power supply problem, it could be as simple as an internal fuse (not the fuse in the plug) or something more sinister like a transformer issue which can become expensive, either way i wouldnt recommend repairing yourself unless your confident with electrics and know what to look for
Oct 28, 2014 | Philips 60P8341 60" Rear Projection...
Need the board of an philips magnavox model PTV910
Which Board are you needing? Let me know and I can assist you.
Jan 02, 2010 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P5040 C104. Green power light- no sound/ no picture, fuse good.
Hey my tv is doing the same thing. The green power light with no sound and no picture and the fuse is good. I was wondering if you fixed the problem and if you could tell me how to fix mine.
Nov 02, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips magnavox 60" rear projection no sound no picture
That could be from
1) Faulty Lamp
2) Vertical/Horizontal Output IC
3) A Shorted IC driver
4) Blown fuse
5) Open resistors around the fuse
Keep all of these in mind and I would test the IC's first with a multimeter,IC's are transistors,usually having 3 legs and screwed into a heat sink,if they read 0 they are shorted. Also if you find something has gone bad,look around the component to see if there is an underlying problem as it will be frustrating and more expensive to find out after the first replacement.
May 11, 2009 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox(model 9P6034C102 )
This is any easy fix. Goto to get a repair kit. Its a common problem on some of the older Magnavox projection TV sets.
Jul 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Phillips 60" rear projection 60pp920217f
There are two major possible cause. The picture tube or the power unit. I had the same problem. Fortunately it turned out to be the lesser of both evils. The power unit. The repair shop was able to rebuild a power unit for less than the price as purchasing a 32' LCD TV. Less than $400.00
Apr 21, 2008 | Philips Magnavox 9P6034C 60" Rear...
No picture
Something in the deflection circuit. possibly a capacitor, resistor or transistor. How are your soldering and troubleshooting Skills?
Dec 26, 2007 | Philips Magnavox 9P6034C 60" Rear...
Projection tv philips magnavox 9p5031c101
power supply problem .the cherps are the power supply ossiclating and trying to produce . soon you won't even hear that
Aug 06, 2007 | Philips Magnavox 9P6034C 60" Rear...
Television Turns on and then Turns Right back off!!!
Either a short in the High Voltage section or power supply section. If you are not a TV technician you will have to find a reputable repair shop to help. Good luck.
Aug 01, 2006 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
61 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
