Question about JVC GR-D70EK Mini DV Digital Camcorder
Capacity of the memory card
What capacity of the memory card can I use in my camera?
    Master:
  • 903 Answers
The models listed below are able to accept the memory cards up to 64MB without any problems (bigger sizes may work but are not verified at this time). If your camera is not on the list please contact JVC at 800 252 5722 2003 models GR-D70US GR-D90US GR-D91US GR-D200US GR-DX300US GR-DX75US GR-DX95US GR-DV500US GR-DV800US 2002 models GR-DVL520U GR-DVL522U GR-DVL720U GR-DVL725U GR-DVL820U GR-DVL822U GR-DVL920U GR-DVM76U GR-DVM96U 2001 models GR-DVL510U GR-DVL512U GR-DVL815U GR-DVL817U GR-DVL915U GR-DVM75U GR-DVP3U GR-DV2000U
Posted on Sep 14, 2005
Memory full
If you are using the memory that came in your camera, and you do not have an accessory SD memory card installed, your camera's built in memory will fill up quickly because it has a very small capacity. If you have an SD memory card, it may be a small card with limited capacity. SC and SDSC memory cards are available with 4, 8, 16, 32, 64, 128 and 256 Gb capacity. Of course, the higher the capacity and the faster the card, the more you will pay. For most amateur applications 16 or 32 Gb should be sufficient. Optionally you could set your camera to take lower resolution pictures. That will increase the number of pictures your memory will accommodate, but there is a price; picture quality.
Apr 16, 2014 | Nikon COOLPIX S9500 Digital Camera Black
WHAT IS THE CAPACITY OF EXTENDED MEMORY OF DIGITAL CAMERA IXUS 95IS
There is no card limit mentioned but as far as I know it support 32GB SD card. But in case of video capacity it supported only 4gb in a single clip.
Mar 14, 2011 | Canon PowerShot SD1200 IS / Digital IXUS...
It says memory card error.i took out the sd card and it was not locked and it still says memory card locked. i formated the card also and it still says the same thing.
How big is its capacity ? Some device can only support memory card at certain maximum capacity, if you inserted card with higher capacity it wouldn't able to read it and it would say "card error".
Try to insert another card with lower capacity. i.e. if you have got "card error" notification for inserting 4 Gb memory card, try to insert 2 Gb card
Hope this help, and if you think its helpful RATE please.
Jan 28, 2011 | Canon PowerShot SD790 IS/ IXUS 90 IS...
Memory card requires formatting error but won't format when select continue
Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible
Nov 20, 2010 | Kodak EasyShare V570 Digital Camera
Can't format new memory card
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manual for the camera was written.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 16, 2010 | Kodak EasyShare C875 Digital Camera
Just bought a used Pentax Optio 750Z online. Am trying to use 2GB San Disk Memory Card. Camera will not accept it. Monitor reads.."Memory Card Error". Is 2GB too much capacity? Is camera...
Is it a SDHC card? SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
You could try formatting the card. There is a function in the camera menus to do this. If it won't format then it may simply be too high capacity. It is often difficult to find out the maximum capacity a camera will use, as today's memory cards are much larger that those available when the manuals for even recent cameras were written.
Nov 07, 2010 | SanDisk Cameras
Why is my new memory did not work with my unit
In the lack of any information about the new memory card, I can only guess that you have obtained a high-capacity card that is too advanced for your camera. There is a difference between SD cards and SDHC (for high capacity) cards. The latter are not backwards compatible with earlier cameras, and some cameras can't recognize a memory card larger than a certain capacity even if it is an SD type.
Oct 20, 2010 | Olympus Camedia C-350 Digital Camera
Is a SDHC Memory Card 4GB compatible with my Canon Powershot SD600 camera?
Your camera will accept a maximum SD card capacity of 2GB. It simply isn't capable of handling anything of a larger capacity and in particular is incompatible with the more technically advanced SDHC cards.
Your fix is to either replace your camera with a later model or to stick to using SD cards with a maximum 2GB capacity.
Aug 26, 2010 | SanDisk 4GB Secure Digital High Capacity...
Got new olympus memory card, keeps saying card error
Is the memory card the correct capacity? Is it too "big"? ie is it say a 8 gig and maybe your camera only supports 4 gig? I had that problem with my camera-I had bought a memory card which was too high in capacity for it. Check your user manual for the cards and capacity you can use.
Oct 03, 2009 | Olympus Camedia C-50 Zoom Digital Camera
Kodak z712is how do i see memory card capacity
That 908 is the camera's estimate of the remaining capacity of the memory card at the current settings.
Jun 26, 2008 | Kodak EasyShare Z612 Digital Camera
JVC GR-D70EK Mini DV Digital Camcorder Logo
208 people viewed this question
Top JVC Video Cameras Experts
Steven Wander
Steven Wander
Marvin
Marvin
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
