Question about Iwill Computers & Internet
Computer startup problem ; IWILL KK266 motherboard
Hello
Hope you can help me with problem. Have above motherboard. Entered setup and was in IWILL smart settings/micro stepping menu. CPU clock set at 133; CPU clock ratio set at auto ; CPU Vcore setting was accidentally set at 1.525V ;BIOS-ROM flash protect set at non-flash. I meant to exit and not save but exited saving above settings. Upon restart, computer would not boot up. Is there a way to restore defaults or reset setup??
Thanks
etsh
    Guru:
  • 859 Answers
There usually is a sequence to do this, but you will have to contact IWILL personally to get that from them if the solution below doesn't work.
[Print this off so you can refer to it in hand]
1. Power off your computer.
2. Unplug your computer.
3. Open up the side panel.
4. You will see the insides of you PC and you MUST be careful not to damage anything sticking up from the mainboard.
5. Look for a Button Cell Battery, about the size of a nickel and shiny silver in color.
6. There is usually a tab release on one side of the battery holder.
Close those two together and the battery will pop out. Otherwise sneak a sharp probe under the battery to lift it out.
Remove and keep the battery out for several seconds. This allows all settings in the setup screens to go away and the setup defaults will be used next time you bootup.
7. Re insert the battery, until it snaps into place.
8. Reattach the power plug and turn your computer on.
9. Enter the setup pages again.
At the bottom of the screen you will see a key legend that gives you an F key to press to setup Optimal Settings or words to this affect.
10. You will also have to reset the time and day here too. Do that and exit with saving.
You should be okay now.
Any questions, use the comment box below to ask away.
Please remember to rate all our solutions on FixYa.
Thanks,
Worldvet
Posted on Sep 02, 2008
    Genius:
  • 1,847 Answers
In the setup BIOS screen choose the optimum default setting and save and exit out.
  • Legin Varghese
    Legin Varghese Sep 02, 2008
    open the tower and and flash the CMOS jumper and then try.
Can't boot from USB on motherboard "ASUS p5s-mx se". No issue on BIOS Setup menu !
Start and pres Del /F 2 /F10 for Setup bios .Change the boot sequence.
Usb drive 1st
Hard disk 2nd
BIOS - The setup program used in desktop and laptop computers/PCs - Page 1 of 2
Phoenix BIOS setup and help
And make a boot-able pen drive.
There is an rate option "Was this helpful?" Yes or No.
If you are helped you can rate ,that is your choice.
Hope it helps.
Jan 19, 2011 | ASUS motherboard P5S-MX SE LGA775 SiS671FX...
Setting the clock
HI,
Please give me a min.i'll let you know if there's a manual available for your model
Apr 24, 2008 | Jensen VM9511TS AM/FM/CD/DVD/SD Player/7"...
Tip
MAKING YOUR COMPUTER OPERATE VERY FAST & SECURED THROUGH CPU OVERCLOCKING
NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN
drbrightirem.jpgOverclocking a processor means enabling it to operate above the manufacturer's specified frequency. Many internet sites provide instructions for overclocking. Processor manufacturers and many computer experts believe the slight gain in performance (only perceivable on CPU-intensive software) isn't worth the expense or considerable risk.
  • Get whatever tools you need: screwdriver, needle-nose pliers, motherboard manual, cooling hardware, etc.
  • 2 Find out whether your motherboard can be adjusted in the BIOS setup, with jumpers or not at all.
  • 3 Find out clock-speed limitations of the motherboard.
  • 4 Run all Windows and any third-party diagnostic applications you have. Fix all system problems.
  • 5 Make a complete backup of your system, documents and applications you don't have on CD-ROM. Do not overwrite these copies.
  • 6 If you have a BIOS-adjustable motherboard, make changes according to your motherboard manual, and skip to Step 15.
  • 7 Shut down computer.
  • 8 Leave computer plugged in to surge suppressor.
  • 9 Disconnect all peripherals from computer.
  • 10 Remove cover of chassis.
  • 11 Ground yourself to computer with any professional grounding equipment you have. Otherwise, ground yourself by touching a metal part of the chassis.
  • 12 If your motherboard has adjustable jumpers, locate the jumpers that control the CPU speed.
  • 13 Use needle-nose pliers to change jumper settings. Move jumpers to positions indicated in your motherboard manual for the clock speed you want. Check the internet for recommendations.
  • 14 Install a CPU heat sink, heat-sink compound, and a specialty cooling fan, if appropriate and possible.
  • 15 Put system back together, and reboot.
  • 16 If computer does not boot, and CPU still works, try lowering the clock speed. If that doesn't work, restore the original configuration.
  • 17 Check all functions, and run a CPU-intensive program.
  • NOTE: OVERCLOCKING COMPUTER CPU MAKES IT PERFORM FASTER ABOVE THE FACTORY SET LEVEL, BEFORE OVERCLOCKING, READ THE GUIDE BELOW, AND VIEW THE SOFTWARE APPROACH HERE OPEN Tips & Warnings
    • CPUs have rated and maximum speeds. Exceeding the maximum speed is far more likely to cause problems than more conservative adjustments.
    • Overclocking an Intel processor explicitly voids its warranty. Other manufacturers have similar exclusions. Intel prevents overclocking of some CPUs by disabling higher multiplier settings.
    • Expect a shorter life for an overclocked processor, including the possibility of its immediate failure.
    • Prepare to deal with seemingly unrelated problems that can be caused by overclocking: destruction of other internal components, lost data, system and application crashes, and an inability to boot the system. Such problems can occur randomly or materialize well after you have altered your motherboard
    on Dec 06, 2010 | Computers & Internet
    Motherboard ID 07/28/2004-KM266-8237-6A6LYM4BC-00 **Above mentioned is the motherboard id of my motherboard. can u please tell me how much of the DDR can i use on my board? m using now one 512mb and...
    Maximum of 1 GB per slot.
    Yes, you can buy DDR400, it will be underclocked by the motherboard to DDR266. If you want some extra performance you can go in the BIOS and lower the timings one unit.
    Yes, they will work, but not very fast. They should be used only as a last option.
    Aug 03, 2010 | MSI Computers & Internet
    Iwill bd 133/no boot screen/no activity in hdd led
    press the delete key repeatadly while booting up and you will go into the bios. then find boot sequence and set your harddrive to 2nd boot deviceand your cdrom to 1st. also if it says no signal check your graphics card connection if you have a seperate graphics card. if you do have a seperate graphics card remove the screen cable and connect it to the onboard graphics instead. if this still does not work then remove the small battery on the motherboard for around 30 seconds and replace. then repeat the above steps. removing the battery will reset your motherboard.
    thanks
    please rate me and give me a fiya! if it works for you.
    Apr 05, 2009 | Iwill BD133U Motherboard
    Set clock on radio
    Hello atesha23,
    Below is the step-by-step procedure for setting the JVC clock. Please note that after you have entered the PSM mode, if you have not pressed a button for about 2 seconds, the radio will automatically exit the mode and return to normal operating mode. In that case, you must restart PSM by holding the "SEL" button until the display changes.
    (1). Enter the PSM mode by pressing and holding the
    SEL button until the display changes.
    (2). Use the rocker switch left/right until "CLOCK
    H" is displayed.
    (3) Set the clock hours by turning the volume
    control up/down.
    (4) Press the rocker switch again until "CLOCK M"
    is displayed.
    (5) Set the clock minutes by turning the volume
    control up/down.
    (6) Press the SEL button to finish and EXIT.
    Hope this helps.
    Mar 31, 2009 | JVC KD-G140 Car CD Player
    How do I set the time on my Pioneer RT500?
    Hi!
    Please follow the instructions given below... =)
    Setting the clock
    The clock is set to the correct time automatically, but it
    can also be set manually. The clock can be set for
    daylight saving time and time zone.
    Preparation:
    • Turn ON the TV and set it to the video input mode.
    • Select “CLOCK” from “SYSTEM SETUP”. For the
    procedure, see steps 1 to 3 in “Using the SETUP
    MENU”
    1 Press SETUP while the DVD and video tape is
    stopped.
    The SETUP MENU screen will appear.
    TIMER REC SET
    SYSTEM SETUP
    AV SETUP
    REC SETUP
    CH SETUP
    OTHER
    SETUP MENU
    ENTER/
    SELECT ENTER RETURN BACK SETUP END
    SELECT
    2 Press  or  to select the desired menu and
    press ENTER.
    The submenu screen of the selected menu will appear.
    TIMER REC SET
    SYSTEM SETUP
    AV SETUP
    REC SETUP
    CH SETUP
    OTHER
    LANGUAGE
    PARENTAL
    CLOCK
    DISC SETUP
    OTHER
    SETUP MENU
    3 Press  or  to select the desired submenu and
    press ENTER.
    The screen for the selected submenu will appear.
    CLOCK (manually)
    You can manually set the date, year and present time
    with the remote control.
    Ex.: Setting the clock to “10:20AM” October, 30th, 2004.
    1 Select “CLOCK” and press ENTER.
    01/01/04 12:00AM
    2 Select the desired items using  or  (month,
    date, year, hour, minute and AM/PM) then press
    ENTER.
    3 Press  or  to set the value of the selected
    item.
    • For the minutes, press  or  once to set the time
    minute by minute, or hold down either of buttons
    for several seconds to set the time in 10-minute
    intervals.
    10/30/04 10:200AM
    4 Repeat steps 2 and 3 to set the date, year and
    present time, and press ENTER. The SETUP MENU
    will close.
    This completes clock time setting.
    AUTO CLOCK
    You can automatically set the clock by turning “ON” the
    AUTO CLOCK function.
    When you want to set the auto clock function to “OFF”,
    select “AUTO CLOCK”, press ENTER and select “OFF”
    from the list.
    Auto clock setting
    Preparation:
    You must connect the antenna or cable before connecting
    the AC cord to the power source.
    Wait 30 minutes with the power turned off, after the
    antenna or cable is connected, for the auto clock
    feature to activate.
    After the clock is set automatically, you may have to set
    the time zone and daylight saving time. (See page 26.)
    Press STANDBY/ON to turn on the DVD/VCR after the
    auto clock operation completed.
    • When shipped from the factory, the “AUTO CLOCK”
    option is set to “ON” position.
    • If you turn the DVD/VCR on during auto clock
    setting, the clock is not set.
    • After a power failure or disconnection of the power
    plug, the clock setting will be lost. In this case, wait
    30 minutes before turning the DVD/VCR on.
    • With cable box connection, if the auto clock setting
    is unsuccessful, select the PBS channel carrying
    the XDS information, then turn the DVD/VCR off.
    After 30 minutes, turn the DVD/VCR on.
    • If the clock is not set automatically, set the clock
    manually.
    STANDARD TIME (Time zone)
    In the rare event that you live within the broadcast range
    of two stations in two different time zones, the DVD/VCR
    may recognize the wrong station for the auto clock set.
    To correct the situation:
    Select “STANDARD TIME” and select the time zone from
    the list below.
    Selectable time zones and correction times
    ATLANTIC: GMT – 4 hours
    (GMT: Greenwich Mean Time)
    EASTERN: GMT – 5 hours
    CENTRAL: GMT – 6 hours
    MOUNTAIN: GMT – 7 hours
    PACIFIC: GMT – 8 hours
    ALASKA: GMT – 9 hours
    HAWAII: GMT – 10 hours
    AUTOMATIC: AUTO SET
    Note
    • When shipped from the factory, the “TIME ZONE” is
    set to “AUTOMATIC”.
    • After making the auto clock setting, in some cases
    the clock may display another time zone. You can
    correct the clock by selecting your time zone
    setting above.
    • When the clock is not set or you set the clock
    manually, the time zone setting is not available.
    DAYLIGHT SAVING TIME
    You can set the clock to daylight saving time automatically
    or manually.
    To select daylight saving time, select “DAYLIGHT
    SAVING TIME” and select “ON”, while to cancel the
    daylight saving time, select “OFF”.
    ON: For manual setting (forward 1 hour)
    OFF: For manual setting (back 1 hour)
    AUTOMATIC: For automatic setting (read XDS in
    the signal)
    Note
    • When you want to set daylight saving time, on the
    first Sunday in April you set it to “ON”, and on the
    last Sunday in October you set it to “OFF”.
    • When shipped from the factory, the “DAYLIGHT
    SAVING TIME” option is set to “AUTOMATIC”.
    • When the clock is not set, the daylight saving time
    • When there is no daylight saving time in your area,
    always select “OFF”.
    Jan 03, 2009 | Pioneer DVR-RT500 DVD Recorder/VCR
    Not optimal clock speed
    Problem most likely is in bios. Hit the Del key when rebooting to enter bios setup. Check the settings there for the cpu. Asus has an automatic setting for overclocking for this board. Make sure it is set to auto. Save then reboot. Hope this helps.
    Dec 16, 2008 | Biostar motherboard I945GZ-M775 Socket 775...
    Jumper setting
    hello
    can you send me this page to check with you if you want
    AYADI
    Mar 14, 2008 | Iwill VX133 (MAVX133) Motherboard
    Iwill vx133 manual
    WHAT DO U NEE DTO KNOW JUMPERS OR cpu info i looked on line dont see any manels on yorus so old but maby i can help u ?
    Jan 26, 2008 | Iwill VX133 (MAVX133) Motherboard
    Computers & Internet Logo
    412 people viewed this question
    Top Iwill Computers & Internet Experts
    Alun Cox
    Josh Whitehead
    Josh Whitehead
    David
    David
    Are you an Iwill Computer and Internet Expert? Answer questions, earn points and help others
