Hello hedrickcari
Welcome,
You said, you are getting a no flow error code. This washer was installed today.If I
have an air pocket, how do you get it out so the washer senses the water
flow?
First I would unplug the washer for 5 minutes and see if it resets and clears the errors!
Make sure the door is tightly closed. (Unlike
top-loaders, front-loading washing machines must be closed in order for
water to begin filling. Makes a lot of sense when you think about it.)
Then make sure the machine is plugged in to a live (or working)
electrical outlet. It's a good idea to check the appropriate circuit
breaker and reset it if needed or check the fuse if you have a fuse box.
Next, turn the control dial to the proper cycle and push the START/STOP
button firmly. Then turn both faucets (hot and cold) on all the way.
Take a look at the inlet hoses (which go from your pipes to your
washer) and straighten them out if necessary.
Turn off the faucets and then disconnect the hoses. Clean the hose
filter screens to remove any blockage that could be plugging up the
water line.
Then replace the filter screens, reconnect the hoses, turn the faucets
back on, open and close the door, and push the START/STOP button firmly
one more time.
You should be rewarded with the sound of water beginning to fill up
your Maytag® Neptune® washer. If you aren't, please contact Customer
Service at 1-800-688-9900.
Samsung Washer Fault Codes | ||
4E | WATER SUPPLY ERROR | Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the preset water level after 10 Minutes or more at the time of initial water supply. The error status can be cleared by turning the POWER switch OFF and back ON. |
5E | WATER DRAIN ERROR | 5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drainerror can be cleared by turning POWER SW OFF and back ON. |
oE | OVER-FLOW ERROR | Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER switch OFF. Water is drained prior to POWER switch OFF. The tub is drained for 2 minutes if a frequency of more than 25 KHz is detected. |
UE | UNBALANCE ERROR |
Laundry load is unbalanced, manually loosen any tangled laundry. If only one item of clothing needs washing, such as a bathrobe or jeans, the final spin result might be unsatisfactory and an UE error message will be shown in the display. Unbalance error is cleared by POWER switch OFF and back ON. |
HE | WATER HEATER ERROR | HE, HE1 is displayed if the water temperature rises by 7 C or more in 1 Min or by 2 C or less 20 Min after heating process has started. The error can be cleared by turning POWER switch OFF. |
1 E | WATER PRESSURE SWITCH ERROR |
* Generated Frequency Signal of WATER LEVEL (WIL) SIW (KHz) Normal Level = Abnormal W/L Frequency Low Level = 30.00 Khz High Level = 15.00 Khz If the same signal is detected for more than 5 seconds, it is aPRESSURE SWITCH Error. When this error occurs the drain pump will operate for 3 min. and the display will show 1 E indicating a pressure switch error. |
cE | ABNORMAL WATER TEMPERATURE ERROR |
e.g. If the water temperature is 50 C or more, during a Delicate or Wool cycle. At the time of initial water supply, if the water temperature is not appropriate, the display will show cE. This error can be cleared by POWER SWITCH OFF. |
11 E | WATER LEAKAGE ERROR | Water Leakage error occurs when the water drains naturally, (by leakage) after the washing program starts. |
tE | THERMISTOR ERROR | This error occurs when the Thermistor circuit is abnormal or a voltage of O.2v or below or, 4.5v and over is detected. This error can be cleared by POWER switch OFF. |
3E | MOTOR RESTRICTION ERROR |
Hall Sensor is sensed every 5OOms. 1 second after motor starts to work. If data of hall sensor is less than 2 (2RPM), the Washing motor will stop at once. During Washing and Rinsing when a motor restriction is sensed, the motor stops and then proceeds to the next water -flow action. If the motor stops working and this happens in one direction ten times, "3E" Error is displayed. During dehydrating. when a motor restriction is sensed. the motor stops working and then returns to the initial stage of the dehydration unbalance sensing cycle. After ten times, "3E" Error isdisplayed, When the motor Is told to stop because of an operating function. no error is shown. Power 81W OFF can clear the motor restriction error. |
8E | OVER CURRENT ERROR |
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action). IPM: Integrated power module. The IPM controls the motor. If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action. If the motor stops working, in one direction ten times, "8E" Error is displayed. During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error. |
I GET THE nF symbol for no reason mid way thru cycle
