Question about Nakamichi AV-7 Receiver
No sound from my record turntable into my computer.
My Audio Technica AT-PL50 turntable suddenly stopped working with my Audio Cleaning Lab program. I convert old LP records to CD's with this program. There is now no sound from the turntable going into the computer.
No wave files are being created from the LP records.
    Brigadier General:
  • 8,546 Answers
If you're certain there is no sound going out of the TT...
Setting the Pre-amp Switch
For increased flexibility of use, this turntable has an internal
stereo phono pre-amplifier. The Pre-amp Selector Switch
is located under the turntable platter, in the rear-center
(Fig. 1). If the system amplifier you are using has a PHONO
input, set the Pre-amp Selector Switch to the “OFF”
position. If your amplifier does not have a PHONO input,
set the Pre-amp Selector Switch to the “ON” position and
connect the turntable’s output cables to the AUX or other
high-level input on the amplifier (described later).
Turntable operates, but no sound at all
1. The stylus guard is still in place.
2. The tone arm Lift button is pressed in.
3. Amplifier controls set incorrectly: wrong input selected,
tape monitor on, speakers switched off, etc.
4. Check the stylus on phono cartridge for correct placement.
Refer to the instructions for replacing the stylus
on page 5.
Turntable operates, but no sound, or sound not loud
enough
1. If the turntable is connected to an AUX (high-level)
input: The Pre-amp Selector Switch may be set to the
“OFF” position (phono-input level).
2. The input gain of the amplified speaker or similar
device may be too low.
3. The stylus assembly may not be fully seated in the
cartridge body.
You could also isolate the problem to either the TT or the PC by trying the TT on some other sound device like a receiver. Make sure the PreAmp Selector switch is ON and plug the TT into any AUX, CD or TAPE input.
Posted on Apr 24, 2009
I have an Audio-Technica turntable (AT-PL50). I recently moved and when I hooked my turntable back up, the sound is terrible. It sounds distorted, similar to the sound of blown-out speakers. But, I checked...
it sounds like your cartridge is shot and damaged.
this turntable has fixed cartridge and only the stylus can be changed.
check out this manual: http://www.audio-technica.com/cms/resource_library/literature/0fb01429606842cf/at_pl50_om.pdf
Jun 20, 2010 | Audio Technica AT-PL50 Turntable
Convert from Vinyl to MP3
I prefair to use Magix Audio Cleaning Lab to convert records to MP3, It's really good at getting rid of noise and crackles.
Jan 01, 2010 | Audio Technica AT-PL50 Turntable
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Sound very distorted
This turntable has a preamp switch on it, which is probably on and what is causing the distortion. Take off the metal record platter by lifting up on the two holes gently. Turn the pre-amp switch to 'off' and then try it again. This is probably it...
Or you can plug it into an input that doesn't have a preamp and that should work.
Dec 25, 2008 | Audio Technica AT-PL50 Turntable
Audio Technica AT-PL50 Stereo full automatic turntable system
Try pushing the button on the far right. I had this same problem last night before I released the button was in the wrong position. It is called the "Lift" button and when depressed it lifts the needle up from the record- or keeps it raised and never lets it come down.
Sep 01, 2008 | Audio Technica AT-PL50 Turntable
Turn table set up
NCH software has what you need
good stuff, free trial
Dec 24, 2007 | Audio Technica AT-PL50 Turntable
Nakamichi AV-7 Receiver Logo
267 people viewed this question
Top Nakamichi Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Rommel Balcita
Colin Stickland
Colin Stickland
Are you a Nakamichi Audio Player and Recorder Expert? Answer questions, earn points and help others
