Question about Brother Office Equipment & Supplies
I have a MCF LC-51 series fax, and scanner I cannot fax or recieve.
    Genius:
  • 2,120 Answers
Check for a dial tone using a regular phone plugged into the wall jack.
make sure the phone cord is hooked into the LINE jack on the machine
make you do NOT have a DSL line.
Posted on Sep 03, 2008
Tip
How to setup your EPSON FAX
1. Connect the supplied phone cord with one end to a phone jack and the other end to the LINE port of the unit. Make sure that the phone jack has a dial tone.
Note: Nowadays a lot of people are using a VOIP Service, keep in mind that the FAX was invented to work on an analog phone system (yeah the regular phone) and this new phone system might result in FAX transmission failures.
2. Default FAX settings works fine. The only time you need to configure it is if you have a phone or an answering machine connected to the unit.
3. To test if you can receive fax, go to http://www.faxzero.com (a free fax service) and send yourself a fax message.
4. To test if you can send fax, a friend's fax number is recommended.
on Nov 06, 2008 | Epson Stylus Multifunction Printer/...
CANT RECIEVE A FAX,from hp officejet v series BUT COULD SENDone
follow the document from te below link
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01669610&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=441125&lang=en
and i think this should work for you ............... any further assistance let me know i will surely try my best to help you ................ thank you
HAMID
Oct 20, 2009 | HP Officejet 5610 All-In-One InkJet...
Black large vertical line on receivers end of fax
If you are sure that there is nothing on the scanner glass, the scanner itself could be bad and need replacing. The most common thing that causes this is some dried white-out correction fluid on the scanner glass.
Sep 09, 2009 | Computers & Internet
Having trouble receiving faxes, takes several times of someone sending to me to receive.
First thing to check is the condition of the phone line, if the machine has a handset make a phone call from the handset, is the line clear? Is there any static or Echos on the line?
Is the machine on a shared line with computers or an answering machine?
Call the Fax machine from a phone, is the line clear? did the machine generate its handshake burst? Did anything else try to answer the line?
Check the phone cable input, it should be going onto the LINE jack on the back of the machine.
Apr 15, 2009 | Brother IntelliFax-1860C Plain Paper...
Panafax UF580
Not recommended, it just screws everthing else up.
Jul 02, 2008 | Panasonic Panafax UF-595 Plain Paper Laser...
Help changin cartridge for the lc 51 series
The Brother lc-51 series cartridges fit a variety of different Brother printers.
On this Brother.com support page
you should select the printer model that you have, and download the user manual for your printer. Once you've downloaded the manual, look in the 'Routine Maintenance' section for how to change the printer cartridges.
Mar 20, 2008 | Computers & Internet
Can recieve well, sends all black
The scanner is not receiving light. That is either because paper is covering the scanner, or the scanner light source is not working. In this case, make sure the connections are in place, if so, replace the scanner.
Feb 26, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Faxing
the best way is to call brother hotline due to so many diffrent telephone line techniques!
You may read the chapter fax within the manual or have a look around here:
http://welcome.solutions.brother.com/bsc/public/us/us/en/faq/faq_list.html?reg=us&c=us&lang=en&prod=mfc240c_all&Cat=12
Sorry, not possible to give a brief and direct answer to your question.
Jan 24, 2008 | Brother Multi-Function Center MFC-240C...
109 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
