I have a epson stylus 925 printer an when I print the ink either comes out with lines through the picture or in blotchy spots that bleed and make the picture look like a watercolor painting. I have glossy paper and checked the settings to fit my paper. I've done a headers cleaner an nossel check in the settings an it hasent helped if you can figure out what I might be forgetting or doing incorrectly let me know
    Guru:
  • 859 Answers
Usually this type of problem is related to the paper choice setting in Printer Setup within your Graphics program. If you are printing from within Windows Preview, you would need to set the values first in the Printer property pages found from Start menu, Printers and Faxes. This leads you to the default setup for your entire system. So it is more preferable to open the image in a Program vs Windows Preview and from within the program usually you go to the File Menu and then Print Preview witch allows you to access the Printer property button and setup from there or you will see a Print Setup item to click on and access the properties just for this print job alone.
Does any of this help you or have you more to offer so I can more specific?
If so, use the comment box below to reply.
Thanks,
Worldvet
Posted on Sep 02, 2008
I have Epson stylus photo 925 and get horizontal lines on printed page. I have run the Print Head Alignment program but the printout is too light to see. Aolution?
Hi
I suggest you clean it manually by removing the print head and then rub the print head in a plain paper with isopropyl alcohol until ink flows. Return the ink cartridge into the printer and run the print nozzle for 2-3 times.
Please let me know if you need more help.
Mar 05, 2011 | Epson Stylus Photo 925 InkJet Printer
New Black ink in it and it still won't print in black
Printer not used for long time before? Ink dried inside head. Use spuit tube, connect to black nozzle. fill tube with cleaner. wait for 1 -2 hours.
Jun 27, 2009 | Epson Stylus C88 InkJet Photo Printer
Photo 925 broke print and i need to replace it
It is probably cheaper ,unfortunately,to replace the printer.Heads are roughly $60 US and it takes a tech to install plus new ink required to seal the vacuum.
Jun 20, 2009 | Epson Stylus Photo 925 InkJet Printer
When I print pictures from my digital camera the pictures are coming out with streaky lines as well as some off color in spots
Double Check Weather Or Not ALL Of The Packaging Tape Is Off The Ink Carts. Sometimes WE Over Look The Lil Tape Sometimes Blue, Green, OR Black. Make Sure Your Settings Are Accurate, As Far As Quality Of Print (normal-to-best). Check And See If You Paper Type Is Correct (Photo, Plain, Postcard...Etc. Only Thing That I Can Think Of? Hope It Helps!!!
Jun 04, 2009 | Epson Stylus Photo 1400 Printer
The jets are constantly needing cleaning...
Either you're using a low grade ink to refill the cartridges or you're not using it enough to keep the head clean. If the ink is allowed to dry on the print head, simply running the "Clean print head" function doesn't always get the dried ink loose. Remove the cartridge and CAREFULLY, clean it with damp toilet paper. Only go ONE DIRECTION when cleaning. SIDE TO SIDE. When it looks clean, check carefully for any left over fuzz. You can also clean the wiper inside the printer with a damp cotton swab.
May 03, 2009 | Epson Stylus Photo 925 InkJet Printer
Blotchy print results in shaded areas
hi
Try running head cleaning cycles from the utility
Dec 13, 2008 | Epson Stylus Photo 900 InkJet Printer
Printer Head cleaning
I've encountered the same situation with my 925. It requires routine cleaning. Try using name brand ink if you aren't already. Cheap ink has a tendancy to dry and clog at a quicker rate. Also, be sure to turn off the printer when you are finished with it. From what I understand, when you shut it off, it caps the ink nozzles like putting the lid on a ketchup bottle.
When doing a job with lots of ink usage, use a quality paper and do a nozzle cleaning right before hand. Hope this helps.
Jun 09, 2008 | Epson Stylus Photo 925 InkJet Printer
Black ink on glossy paper looks like leopard spots
printer need head cleaning , after cleaning check nozzle , if solid color appear w/out space on black color it means good and clean nozzle.
Dec 27, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Vertical lines
1. Took out the ink carts and cleaned the copper contacts of both the ink carts.
2. Clean the copper contacts on the ink carts slot in the printer and then insert the ink carts in the printer and then print out the page.
Dec 11, 2007 | Epson Stylus C60 InkJet Printer
Photo Printer
sina, Does the photo print good using photo paper? How regular of a paper? Do all other colors have ink? What program are you printing the photo from? Have you tried printing from a different program? Some programs send varying information to printers. If all of the above has been tried...uninstall the printer and download the newest drivers from EPSON and re-install the printer. Good luck Tim
Feb 03, 2007 | Epson Stylus Photo 925 InkJet Printer
140 people viewed this question
jasbo
jasbo
