Question about Whirlpool Calypso GVW9959K Top Load Washer
Kenmre Calypso problems
I just acquired a washer and dryer. "Calypso Elite Series"
The washer has a leak from the back panel and has had for some time.
The dryer has "E1" code and shuts off after it heats up even on the lowest setting. It will run continuously on air dry.
Can you help? Thanks Speedy
  • speedylite Sep 07, 2008
    with regards to the washer there is a water leak coming from the back panel
  • Anonymous Sep 09, 2008
    My Calypso also has been leaking - checked all hoses, used the "Approved repair service" here in Orlando, and had to take 2 days off work to have the tech on visit 1 spend 70 minutes on my phone with Whirlpool - I paid for their training session - he barely knew how to open it up! Visit 2, a different tech stated it was bleach/softener ensemble that had molding flaw. Paid for 2 home visits (gave up vacation time), and paid for the replacement set up - we installed. Still leaking from the back (where rust was forming I had to show them) not the front where ensemble was. Usually during rinse & spin cycles. Now this week it is hanging up on the rinse / spin cycles - repetitive stop & starts: example 20 minutes to count down 3 minutes. Everything is soaking wet. Any ideas before I try the "brilliant" useless but expensive techs again and lose money and vacation time again?
I had the same problem and it was fabric build up in the top of the machine. There is a little whole where the water comes in on the top and it was full of lint type material. I clean it out after laundry day every week and haven't had a problem since.
Posted on Nov 02, 2008
    Novelist:
    Champion:
  • 261 Answers
Sounds like a thermistor
Posted on Sep 04, 2008
Water leaking (a lot) from underneath washer
WATER IS NOT GOING INTO THE TUB, INSTEAD GOING OUT. GET A PAINT SCRAPER N PRY THE LID OPEN TO MAKE SURE THE TUB IS IN PLACE WHEN YOU MOVED IT. THERE'S TWO CLIPS BETWEEN THE LID PANEL AND THE MACHINE. PUSH IN HARD AND IT RELEASE THE LID PANEL. FROM THERE YOU WILL SEE THE TUB AND ALL THE WATER DISPENSING UNITS. IT COULD ALSO BE A RIP IN ONE OF THE HOSE WHEN YOU MOVED THE MACHINE. GOOD LUCK
BOYNISMO@YAHOO.COM OR 714-334-1998
Mar 10, 2010 | Kenmore Elite 45986 Front Load Washer
Error codes
Kenmre HE2 Plus front loader has a F 28 error. Whats the problem and how do I fix it?
Jan 19, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore elite calypso doesn't respond to buttons except cancel
I've had a similiar problem on my calypso. In my case the key pad would go dead after washing or pushing stop after a few minutes. If I unpluged the unit for a few minutes it would work again. This would appear to be in the controller board. I removed the board and inspected it finding no problems. After re-installing the board the washer appears to be working again. My conclusion is that there is a loose connector/connection. I'd suggest you remove and re-install all the connectors on the controller board. This is the board closest to the power chord.
Good Luck, George S.
Sep 10, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore elite dryer no pwer
If the dryer does nothing at all, it's probably the door switch. Give it a good look over.You Does the light com on inside when you open the door? Does it appear to have power but just won't start?
Jul 24, 2009 | Dryers
Where is the filter located on a kenmore elite calypso washer
reomovethe 3 screws across teh lower acess panel, youll see the filter clean out right behind there , be warned before unscrewing get a plastic bag, or a few towells you will getwet!!!!!!
Mar 17, 2009 | Kenmore Washing Machines
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
How to Open up a Kenmore Elite Calypso Wash Motion Washer
If this is a Calypso, there are retaining clips holding the top down in the front of the washer. You will need to look along the seam where the top meets the front panel the washer about 2 inches in from each side. Using a putty knife, insert into the seam and push straight in while lifting on the top. The retaining clips will release and the top lifts up. It may take a second set of hands to make this a little easier. When you get the top lifted up, there will be a couple of screws holding the front panel in place. Remove them and you have access to the interior of the washer. If this is not a Calypso, please post back so I can give you correct advice. I hope this helps you.
Apr 06, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Elite Calypso Washer
take the pannel off the bottom and unscrew the pump cleanout
Feb 09, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite Calypso won't drain
The most likely thing to cause the code and the leak is the water pump. If the shaft seal on the pump leaks, the water gets into the drain pump motor and shorts it out. The code is telling you there is a high current/amp draw at one of the motors.
You can see if the pump is leaking by tilting the machine back, removing the screws that hold the bottom to the front edge of the machine and looking at the pump. If the pump is leaking, you will need a new pump and possibly a new motor control board.
Post back if you need further instructions and we will walk through the repair.
Nov 09, 2007 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
111 people viewed this question
Dan Webster
Dan Webster
Sal De
