I have a Sanyo hln567w. When it is turned on, after a few minutes the screen freezes up, goes black, and the only way to turn the TV off is to unplug it. The green light at the bottom flashes. I have had the bulb and balyst replaced, it did not help.
  • clintt Sep 03, 2008
    The problem still happens even after replacing the ballyst. The tv will turn on and has a picture. After a few minutes, it will go black and I have to unplug it in order to get it to turn off. The button on the side and the remote will not turn it off.
  • clintt Sep 04, 2008
    thanks
  • 19,396 Answers
If you had picture, there was no need to replace lamp, that is an expensive part.
Regarding ballast , before replacing you need to test voltages on it, this is an hazardous procedure that must be performed by a technician.
The problem it is some faulty component on one of the internal pcbs, can be a faulty IC , a capacitor or any of the several thousends components inside your TV.
Often, for example you get same problem from the high voltage board powering the bulb.
You need to have a repairman diagnosing the problem before buying more parts.
Posted on Sep 04, 2008
  • Ginko
    Ginko Sep 04, 2008
    I forgot to mention that the TV is turning itself off because the chip controlling your tv activate the internal safety switch after detecting an error (overvoltage , shorts, faulty component etc.).
    The safety device will put TV on standby and stop normal TV operations, that is what is happening to your TV.
    President:
  • 1,263 Answers
This is a problem that still occurs after you replaced the balast? does the picture come on at all? or after a few minute of clear picture it goes blank.
Posted on Sep 02, 2008
I have a 50" Samsung tv. The tv turns on and the screen comes on, then within 1 minute the screen goes black. I can still hear sound.
Samsung HL-R5087W TV screen goes blank -tv/sound on - Forums ...
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - About a month ago, the at various times the tv screen would go blankeven though the tv ... Try turning off the cable/sat box when the happens. ... In reply to: Samsung SP50L7HX DLP TV linked to Sky HD box - same problem .... on it comesback to normal. however, once it went off again (Black Screen) after only 2-3 minutes. ln-t4069f picture problem lcd warmup - Forums - CNET
Jun 11, 2015
Samsung LCD TV LN-T5265F Black Screen Diagnosis Help ...
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
Samsung TV screen goes black w/ audio still playing ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Jan 28, 2016 | Samsung Televison & Video
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
Why my 42" sanyo DP42841 HDTV LCD SCREEN GOES BLACK ON THE LEFT SIDE?
That sounds like a faulty LCD panel tab. The only true fix is to replace the screen. This usually isn't cost effective.
Jan 19, 2013 | Sanyo DP46849 46 in. HDTV
Sanyo DP46848 LCD TV has black screen with colored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 16, 2017 | Sanyo DP46848 LCD TV
Sanyo 46' flat screen tv - has issues like all of a sudden it will make a high pitched noise and then the TV goes out - the picture freezes and then the screen goes black
our Sanyo Flat screen tv freezes, makes a loud noise, then turns off then back on automatically. It does it more frequently while watching an exciting part of a movie
Jan 10, 2010 | Sanyo DP46849 46 in. HDTV
SANYO TV Picture
I just bought a new Sanyo DP19649 and we can watch it for about 15 minutes then the screen goes black but the sou nd stays on. We have to turn it off and turn it back on to get the picture back for another 15 minutes-then it's the same thing all over again. The sleep mode is off and it isn't on automatic shutoff.
Jul 21, 2009 | Sanyo Televison & Video
My TV pictures turns black afetr a few hours but I still can hear sound perfectly!!!
It sounds like your rptv lamp is going out. If this is an older DLP this is most likely the cause. You can get a replacement at www.laptopsforless.com part number BP96-00224J for $151. If the tv is still under warranty, I would have them do it, otherwise replace it yourself. If so here is a link to give you step by step instruction. Please give me a good rating. ;-)
Dec 18, 2007 | Samsung HLN567W 56" Rear Projection HDTV
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
