Question about Digital Audio 2, CHANNEL 600 WATTS HIGH POWER CLASS A/B AMPLIFIER DA2200W Car Audio Amplifier
Any other suggestions...
I already checked the output of the reciever wich was still sending signal through outputs....and checked all other obvious things..but thanx...any other suggestions?
  • 421 Answers
Make sure you have solid power and ground resistance (connections)
-jeff
Posted on Sep 04, 2008
  • jeff r
    jeff r Sep 05, 2008
    figure it out?
My pioneer AV reciever last shows in the display a "amplifier error" then suddenly the power shut-off. aftr that i power on again but the reciever do not power on again. I remove all the...
The real problem is already informed you by the unit itself.
For us technician it was obvious that you have a faulty output I.C.
Your unit automatically shuts off to avoid further damaged most especially to the speakers.
I've advice you to look for a qualified technician/service center to replaced the output I.C.
After that your unit will back to normal again........
Jan 03, 2011 | Pioneer Audio Players & Recorders
My Sharp LC-32SB24U says An incompatiable video signal has been recieved. Check the output device settings?
It sounds like an HDMI lead has standard video on it or the output from a digital unit is not the correct specification for your TV.
Check the instruction booklet for recomended signal sources and then check your DVD, Video, Computer for the right type of signals to be outputed to your TV.
Hope this helps.
Oct 29, 2010 | Sharp LC-32SB24U 32 in. LCD TV
Hooking up my Sony HD Tv
Couple of items come to mind.
In the menu of the receiver, is there a way to choose video and RGB?
Set the receiver to SAT
Connect the HD Cable Box to SAT
Check the TV is on Monitor RGB.
Check the input being used by the monitor RGB cables is selected on the TV.
Have a picture? NO, receiver has issues.
Yes? Do this with each input to confirm they work.
You can reset the whole receiver to factory by holding the tone button down and holding the standby button for three seconds. (This clears your speaker setups, too.)
Apr 02, 2010 | Televison & Video
Is this tv capable of receiving digital signal from directTV
The direct tv reciever has a coax output that will send a signal to channel 3 or 4 that any older telivision can recieve...so the answer is yes. You obvously need a direct tv reciever to watch direct tv on any telivision.
Nov 26, 2009 | RCA E13319 13" TV
The green overdrive light on the dash keeps flashing and the transmission jerks into gear. Any suggestions on how to solve this. The test codes that come are P1747, PO156, and PO161. I have already...
not an oxygen sensor
vehicle speed sensor or oss is most likely cause.
Output Shaft Speed Sensor (OSS) 7H103: The output shaft speed (OSS) sensor is a magnetic pickup, located at the output shaft ring gear that sends a signal to the powertrain control module to indicate transmission output shaft speed. The powertrain control module uses this signal for torque converter clutch control, shift scheduling, used in determining EPC pressure. Symptoms: No converter engagements, harsh shifts, abnormal shift schedules. DTC: P0720, P0721 std~us~en~file=d14110a.gif~gen~ref.gif
Vehicle Speed Sensor (VSS) 9E731: The vehicle speed sensor is a magnetic pickup that sends a signal to the powertrain control module. This VSS signal tells the PCM vehicle speed. The PCM uses this signal to modify upshift schedules. Symptoms: Shift engagement/disengagement (hunting) on grades. DTC: P0500, P0503, P1500, P1501, P1503
Mar 15, 2009 | 1996 Ford Thunderbird LX
Amp powers up (switchable) but has absolutely no output
If possible return the amp to the seller for a refund (before you tamper with it).
If that's not possible, the amp will need to be repaired. Do you want to try to repair it yourself?
For the head unit, you need to check the shield ground first. The following page will show you how to perform the test.
Shield Ground Test/Repair
Let me know if you have any other questions.
Sep 19, 2008 | Kenwood KAC-7202 Car Audio Amplifier
Subwoofer connection
if this is ao powered sub, that plugs into the wall, there should be no problems, if it is powered solely by the reciever it may work fine but be sure you dont exceed amperage on the subwoofer.
Jan 28, 2008 | Bose 151SE Main / Stereo Speaker
No digital to reciever??
This tv will only output the sound from a digital tv channel through the optical output when using the tv's digital tuner. So if you are connecting a DVD etc it will not output through the optical output on the tv. ONLY digital chanels through the tv's tuner will give you sound. Refer to the tv's owners manual for more info.
Dec 27, 2007 | Sony Grand WEGA KF50WE610 50" Rear...
Digital Audio 2, CHANNEL 600 WATTS HIGH POWER CLASS A/B AMPLIFIER DA2200W Car Audio Amplifier Logo
59 people viewed this question
Top Digital Audio Car Audio & Video Experts
Joe Ankney
Level 1 Expert
Tom Chichester
Are you a Digital Audio Car Audio and Video Expert? Answer questions, earn points and help others
