Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
Disc error
By darrenpeache on Sep 02, 2008
disc
Same Problem
Sep 02, 2008
-   the 360 plays the game but it will freeze, then the disk drive will crunch and the 360 will scratch the disk so it is unreadable.-   ballardroo
Solution #1
posted on Mar 13, 2009
Not Rated)
chris_topher
Rank: Master
Rating: 0%, 0 votes
Microsoft Xbox have some common problem like red lights, E74 and Disc Read Error. Microsoft is providing extended warranty for red lights problem, Means you will have to spend some money in order to get this problem repaired from Microsoft also you will have to wait for 3-4 weeks to get your Xbox back. There are many reasons disc read error can occur in your Xbox like your disc might not be clean, laser might also be dirty and many more common problem. I would suggest you to first clean out the disc, you are using. If that don't solve the problem you can also take the help of DIY guide available at Internet. I think you have got good no. of options to get your Xbox repaired, Choice is yours.
Was this helpful?
Yes
No
Solution #2
posted on Sep 04, 2008
Not Rated)
gamerfixer07
Rank: Guru
Rating: 88%, 274 votes
You need a new hard drive or reformat the one you have with a laptop or PC.
Controll Panel > Administrative Tools > Computer Management > Disk Management (on left)
Hook up the hard drive with an external USB case ($5 on eBay). Right click on left side and initialize.
When that is finished, right click in the middle of that hard disk (where it says --GB unallocated) and click on format. You need to for mat with NTFS first then follow the steps again to format it in FAT. When thats done, re-install the hard drive into the case and reattach to the Xbox and it should be good to go!! Good luck and happy gaming!!!
Comments:
Sep 04, 2008
- ballardroo, you have a different problem. Someone may have jammed something into your drive that is damaging your disks.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
what are the wep64 codes and where can i find them cant get connected to my home hub
Answer
What's wrong if it just frezzez less than 5 min after turning it on
Answer
it wont turn on i tryed i every solution posssible cleaned it checked if everything was pluged in
Answer
My friends where over for like six or seven days they played the xbox and it was working just fine... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
