Question about Hobart AM14-253 Free-standing Dishwasher
I can't figure out how to remove the dough hook from my Hobart commercial mixer.
  • 535 Answers
Force and a torch is your path.
First cut a block of wood that is of a length that is long enough to go from the column to the attachment portion of the planetary. (The block protects the gears from the force.)
Look at the rotation of the hook, you're going to twist it the opposite direction. Above the hook, loop a strand of a wet towel. While keeping the towel damp, not wet, torch the **** out of the hook. I recommend "mapp" gas. Heat it for about 90 seconds to to 2 minutes. The old dough stuck inside will burn off. You should get some black smoke. Use the block of wood, between the attachment portion of the planetary and the column, to resist the twist of the hook. If the wood is properly placed to absorb the load --- dampen towel, torch, block, TWIST. If you use a wrench -- be cautious. Good luck
Posted on Nov 02, 2008
  • Hobart Master
  • 19,396 Answers
Check here:
I quote:
"There are 2 set screws.Make sure their both out,if for some reason there is only 1 set screw these are your options.Heat the shaft and remaining pin with a mapp torch (you can buy them at home depot,lowes for $40 bucks),heat it up really good then get a punch and try to knock out the pin,option 2---if you cant get the pin out then youll have to replace the shaft and if thats the case you should also clean out the planetary and replace the bearings and seals.If the hole in the shaft is oblongated or worn you should probably replace the shaft because the dough hook will rock the pin back and forth breaking the pin.Also look inside the hook and make sure thatI its not worn out where the pin sets.IF you see thee hook or shaft pinhole worn you will break the pin again if you are able to replace the pin.I work for hobart and service mixers regulary,if you need part numbers or advise let me know."
    President:
  • 1,263 Answers
You should be able to push up on it and turn at the same time it should come off.
Posted on Sep 02, 2008
What is the correct dough hook to get for my 'OLD' A200 Hobart?
Check with your local Hobart office.
www.hobartservice.com Click on "Locate an Office" and enter your Zip.
Jan 20, 2010 | Hobart A200 Stand Mixer
Need to know the part number for a dough hook for a hobart a200c stand mixer. What number would be stamped on the hook?
A 20 qt "E" dough arm is S-23467. A 12 qt is S-62886.
A 20 qt "S" sweet dough beater is R-8022.
Jan 05, 2010 | Hobart A200 Stand Mixer
Having a hard time removing the dough hook on the h-600.
make sure the beater shaft is clean. is the dough hook new or old if its new you can deburr inside of dough hook to ease in install and removal of attch. please let me know so i can futher asist
Dec 03, 2009 | Hobart H600 Stand Mixer
Hello, I have a commercial dough mixer,
it's a standard drive system found on most hobart mixers like the a200 style and you may find only hobart parts will fit it
Oct 10, 2009 | Hobart D300-6036 Mixer
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
The gear is slipping on my Hobart A200
In what speed is it slipping?You only use 1st speed for dough,right?Can you put it in gear and stop the hook from moving with your hand?Let me know.
Jan 13, 2009 | Hobart N50 Stand Mixer
Hobart a200 mixer won't mix
The bowl holds 20 quarts--are you overloading the mix?This mixer is not made for medium/heavy pizza dough.Depending on the pounds of dough,water and other ingredients will affect the mixer in some way.
Nov 09, 2008 | Hobart A200 Stand Mixer
Help with removal of Dough Hook on A200.
Look at the rotation of the hook, you're going to twist it the opposite direction. Above the hook, loop a strand of a wet towel. While keeping the towel damp, not wet, torch the **** out of the hook. I recommend "mapp" gas. Heat it for about 90 seconds to to 2 minutes. The old dough stuck inside will burn off. You should get some black smoke. Use the block of wood, between the attachment portion of the planetary and the column, to resist the twist of the hook. If the wood is properly placed to absorb the load --- dampen towel, torch, block, TWIST. If you use a wrench -- be cautious. Good luck -- Mike
Jun 27, 2008 | Hobart A200 Stand Mixer
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Feb 21, 2008 | Hobart H600 Stand Mixer
Hobart AM14-253 Free-standing Dishwasher Logo
235 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
