Question about HP iPAQ H5150 Pocket PC
Time changes The time on the pocket pc changes 3 hours, for example instead of showing 10:30 a.m., it changes to 7:30 a.m. I already tried a hard reset. Any suggestions? Thank you.
    Master:
  • 450 Answers
If you are syncing the ppc to another computer, is the time on that computer correct?
Posted on Sep 14, 2005
Where do I find a user manual for a Timex Expedition (H2Y518)? I had Timex install a new battery and although the date 3-17 is correct, the day of the week is SUN. I have tried changing the date for over...
You are very observant! Timex watches don't have a way to adjust the day.
However, if you turn the hands clockwise you will see the day advance.
So, heres the secret, follow exactly:
1. Turn the hands until the day of the week shows the day before. If today is Wednesday then turn the hands until the watch shows Tuesday
2 Adjust the date to the day before. If today is the 17th then adjust it to the 16th
3. Now pull the crown all the out and and advance the hands until the date changes to the correct date, 17 in this example. This happens at midnight. Continue the movement in a clockwise direction for a few more hours and you should see the day change to the correct day.
4. Now continue to move in a clockwise direction until you have the current time. Remember that your date/day changed at midnight so if the current time is after lunch(noon) you must continue past noon to get to the correct time. If you don't do this correctly your date will change every day at noon instead of midnight.
If you don't succeed the first time, try, try again! Good luck, Michael, Watchmaker to the Stars!
Mar 17, 2011 | Timex Watches
Not detected
1stly try the Kingstone in another PC - if it works in another PC you have 1 of 4 problems:
1] You are using a very old version of Windows and therefore would require drivers for the memory stick. (i.e. Windows 95 or Windows 98)
2] Your USB ports are faulty - try the ports at the back of the PC instead of the ones in the front if you have not done so already
3] There is a virus on your memory stick and it is attempting to load an executable file when u plug it in and that is causing it to fail.
4] It is detecting fine but you cant read it because the FAT (File allocation table) is damaged in which case it will need to be formatted.
I will need some more info though - for example:
Does windows say "Hardware detected" when u plug it in?
Are you getting any lights flashing on the memory stick?
What do you see when u click on my computer? Does is show up at all but u just cant open it?
Good Luck
Feb 04, 2011 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
The time is off one hour how do I fix it...Nortel
Programming should be done from the M7310, M7324 or the T7316E set. Administration access code: Feature * * 2 3 6 4 6 which also is Feature * * A D M I N.
If asked for a password enter the same 2 3 6 4 6.
If that doesn't work you may have the newer Compact ICS or the Modular 0x32 control unit which will be Feature * * 8 4 6 3 which is T I M E. Password is 2 2 7 4 2 which is B A S I C or A D M I N which is 2 3 6 4 6.
When in programming just press the next button(lower right arrow) until you see what you want to change. Then press show ( top right arrow) ,then change if you want to change it. If you pass it, press back (lower left arrow)
Example: To change the Time & Date Press next until you see Time & Date. Then show Then Chng Then change again, change it if you need to, Then next again until you see what you need to change. For example; only the hour needs to be changed for day light savings time. Just press next until you come to the Hour. Then Change it. Then press release RLs when your done.
Oct 28, 2009 | Nortel T7316E 2-Line Corded Phone
Setting the correct time
Oct 27, 2009 | NorStar Meridian M7310 Phone
Imate jam shuts down every now and then
hi thanks for using fixya!
On that kind of error, I suggest that you bring your phone to a service center to check further the software that you have. Be sure that you have change the battery even so that you said that it works fine. You already did the soft and hard reset, but unfortunately, still not working properly.
Good Luck! hope you still have your warranty!
Don't forget to rate my solution! thanks!
Mar 17, 2009 | i-mate JAM Pocket PC
Wireshark
NOT TOO CLEAR TO MY TEAM
source:
solution dictionary for fixing all pc problems on htpp://www.tinyurl.com/52mwor
http://www.digitalpowering.blogspot.com
Apr 06, 2008 | Microsoft Windows XP Professional for PC
Change the time
Depending on the software of the Norstar it is connected to, you would log in to the key system by using Feature **23646 and then follow it up with the administration password.
If this is a pre 1.0 system, i.e DR5.1 do the following. If not, go to the bottom and click on the link and find the manual for the system your phone is connected to. Generally the system coordinator guide will have what you are looking for.
Setting the date
Begin with the display showing
l.Sys speed dial
1. Press [NEXT] (second key from the top on right for a 7310) twice.
2. The display shows 3.Time and date.
3. Press [SHOW] (first key on the top on the right for a 7310)
The display shows the time, for example, Time 01:00.
- All times and dates must be entered using numerals. For
example, February would be entered as “2”.
- The time may be entered in either 12 or 24-hour format. If the
display is in English, and the hour entered is less than
thirteen, the display prompts you to specify “am” or “pm”.
Press [Show] This will open the time change function. Simple rule. If you want to modify a value, press [CHANGE] and you'll get a cursor. Once you're done with that entry, press [NEXT] to go to the Minutes, press [CHANGE] etc...
I have also included how to change the date below.
Press [Next].
The display shows the date, for example, Date 31 Mar 91.
4. Press CHANGE (softkey under screen). The display shows Year: 88.
5. Set the year.
a. Press CHANGE.
A cursor replaces the number on the display.
b. Enter the year using the dial pad.
For example, press a a to enter the year 1990. ?
c . Press [Next] The display shows the month, for example Month: 01.
6. Set the month.
a. Press [CHANGE]
b. Enter the month using the dial pad.
For example, press 02 to enter February.
c . Press [Next].
The display shows the day, for example Dar: 01.
7. Set the date.
a. Press CHANGE
: A cursor replaces the number on the display.
b.” Enter the date using the dial pad.
For example, press 14.
Apr 03, 2008 | NorStar M7324 Telephone
Shows Li-On battery charged when plugged into AC, shuts down when unplugged
Here is a palm article on the battery not holding charge-
http://kb.palm.com/SRVS/CGI-BIN/WEBCGI.EXE/,/
?St=42,E=0000000000826384196,K=1280,Sxi=19,Case=Obj(30029)
My battery loses its charge very quickly
Like all Lithium Ion batteries, the battery in your device will eventually wear out. If you charge your device fully but it loses power after a few hours (or sooner), it may be time to replace the internal battery.
Sounds like you already did this. Do you have someone you know who has the same battery you could try? Or try your battery in their device?
Also this site looks good -
http://www.ipaqrepair.co.uk/ipaq_battery.php
Step #11
You can connect it via USB and let it charge that way a little while, then try charging it normally. It's called trickle charging-
Trickle charging
Some Palm devices have the ability to "trickle charge" from a USB port on a PC or Mac. This means that it receives a very small amount of charging from the USB port, even if it is not connected to its AC charger. If your device is capable of this function, the charging time will be significantly longer for a trickle charge (depending on the power rating of the PC USB port). However, the device may not charge at all on an unpowered USB hub (or for example off off a keyboard).
Dec 30, 2007 | HP iPAQ RX3715 Pocket PC
Changing the time from military to civilain
Start | Settings | SYstem | Regional Settings | Time . Change the Time Style.
Nov 11, 2007 | ViewSonic V35 Pocket PC
Date & Time of calendar
Sounds like your PC is not set to adjust for daylight savings.... the ipaq automatically adjusts for daylight savings but the PC does not. On your PC double click on clock, click on Time Zone tab and then on that screen you will see the box that needs to be checked. also check that both PC and IPAQ are set to same time-zones.
Sep 12, 2005 | HP iPAQ HX4700 Pocket PC
HP iPAQ H5150 Pocket PC Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
