Question about Nokia 1600 Cellular Phone
Bluetooth pairing issue w/ jabra headset & Samsung SGH A-707
My phone isn't finding my phone when I do bluetooth device search. Can you help me?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 147 Answers
What you have to do is turn on the bluetooth of the other device and at the same time your phone's bluetooth is on. If your phone is the only device that the bluetooth is on near you then it your phone will not find a device. Cause your phone searches for another bluetooth device,therefore.....it doesn't include itself.
Posted on Sep 25, 2008
  • ralph navarro
    ralph navarro Sep 26, 2008
    And I forgot to tell you that 1600 has no bluetooth nor infrared.
How do i pair my jabra easygo to my phone
Hold your blutooth switch on button at few second the light at bluetooth is starts to blink now open bluetooth menu in mobile select pared device and select search new device or go to blutooth menu and select search audio enhancement
Apr 20, 2013 | Jabra EasyGo Bluetooth Headset
I cannot get my Blackberry Storm to pair with my Jabra BT2070.
You have to first put the Headset into discoverable mode. According to the Jabra website, this is done by pressing and holding the end/mute button until the light comes on steady. Follow the procedure for your phone to pair a bluetooth device to it. The PIN code will be 0000.
Feb 07, 2010 | Jabra Bluetooth Headset with Adjustable...
Jabra BT125 headset not connecting to Samsung F480
you have to switch the bluetooth headset to pairing mode not just swithcing it on. Hold the power on button continuously even after it switches on then the light will remain on. Then you switch on the bluetooth in the mobile and start searching for bluetooth devices. You will find your bluetooth headset in the mobile. Select it and pair. Usual code will be 0000, but it might differ check with the manual which can be found online too. This will definitely solve your problem.
Sep 10, 2009 | Jabra BT125 Headset
Charged earpiece doesn't communicate with cell phone
My advice would be to re-pair the two devices. In the Bluetooth menu on you phone find 'paired devices' and delete the headset from the list. Next you will need to put the Bluetooth headset into pairing mode. Make sure it is switched off and then press and hold the power button on the headset and keep pressing it ( some headsets need to also have the up volume button pressed at the same time). What should happen is either a solid blue light of alternate flashing of two colours. (pairing mode varies on different headsets and you made need instructions or call Jabra) At this point on the phone in the Bluetooth menu search new devices. It should find your headset and request pairing code. Code should be '0000' or some headsets use '1234'. This should now set up a fresh pairing and work again. Hope that helps.
Apr 23, 2009 | Cell Phones
Our SGH-c417 Samsung cell phone will pair easily with a bluetooth headset but with our Toyota built-in bluetooth handsfree headset, it will not pair. It just searches and searches and never finds the...
I have had a similar issue with SGH-A707, I have found that taking the device out of discover mode, then removing the battery from the phone to reboot it. once booted, turn on the bluetooth on the phone and put the device into discover mode. Should find it.
Mar 20, 2009 | Samsung C417 Cellular Phone
I have a Jabra set, but my Motorola Krazer can not find it
Follow the steps below:
• Setting the headset into pairing mode
1) Ensure the headset is fully charged
2) The headset must be switch off
3) Press and hold the on button for around 8 seconds until the light flashes red-blue
4) The headset is now in pairing mode
• Searching for the headset on the phone
1) Go to “settings” or “connections”
2) Select Bluetooth, then options
3) Select Devices and click add
4) The phone should search for any available Bluetooth devices and display what was found
5) Select the Jabra device and click add
6) You will be required to enter in a pass code which is standard ‘0000’
7) If successful then the headset will start flashing BLUE every few seconds.
• The headset is now paired with the phone
Hope this helps
Chris (ziraffa)
Jan 16, 2009 | Jabra BT350 Bluetooth Headset Headset
J can't use the bluetooth headset wep210
If you have lost the pairing on your phone with the headset follow these simple steps below:
3) Press and hold the on button for +- 8 seconds until the light flashes red-blue
5) Select the Samsung device and click add
6) You will be required to enter in a pass code which is standard ‘0000’. If not try '1234'.
8) If it’s a Samsung or Nokia phone you will need to “AUTHORIZE” headset on the device.
Hope this helps
Chris (ziraffa)
Jan 11, 2009 | Samsung BLUETOOTH? WEP210 MONO HEADSET...
I have samsung sgh-a707 phone cannot pair plantronics 521
I have samsung sgh-a707 phone cannot pair my new plantronics 521blue tooth.I search but get "no devices found".is it the phone or bluetooth?Help
Dec 23, 2008 | Plantronics Hama Voyager 520 Bluetooth...
Cannot pair Nokia N70 to Jabra BT150 bluetooth headset
turn on cell phone. activate bluetooth. press right button to search for bluetooth devices. Then press the on button and the volume UP button at the same time on the Jabra headset. The cell phone then finds the device. put in the password/pin (usually 0000). and voila! it works
Dec 07, 2008 | Jabra BT150 Wireless Headset
Bluetooth from Samsung D900 (HELP PLEASE!)
nback - DO AHARD RESET *2767*3855#
KEWL - BUT YOUR BT TO SEARCH SWTCH THE JABRA ON THEN PAIR THE P/W 0000
Sep 27, 2007 | Samsung SGH-D900 Cellular Phone
Nokia 1600 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
