Question about Dell Axim X5 Pocket PC
Infrared Beaming Problem
My wife has the 400MHz model Axim with 64MB RAM. When she tries to use the infrared to beam something to another Pocket PC,she gets a message that it is searching for the other device and eventually it times out without ever beaming. She's tested this with another Axim and an IPAQ. (In fact, the IPAQ locked up and she had to do a soft reset.) She did get it to beam successfully a to another Axim but only after trying multiple times and slowly decreasing the distance between the devices down to about 4 inches. The results are the same even if the beaming is initiated from the other Axim, so this would seem to rule out the problem being with just her Axim. Anyone else having similar problems?
    Master:
  • 852 Answers
Problem my wife is having is beaming from one Axim X5 400MHz Pocket PC to another. Exact same hardware. She's having intermittent success with most attempts timing out or failing. Anyone else had trouble beaming to another like device? I don't hold out much hope from Palm to Axim transfers - don't even really need that - but I would think that from one Pocket PC 2002 device to another should be a cinch....
Posted on Sep 14, 2005
    Master:
  • 852 Answers
My Axim is behaving the same way. I find that if I try to transfer something from my Palm IIIc to my Axim via infrared, it rarely sends the data immediately, and it often times out. I have found that I can often get it to work if I request the transfer on the Palm and then "stimulate" the Axim via tapping a menu selection or by momentarily blocking the view between the devices.
Remote infrared light are not working
Here is another post that describes how to test to see if your IR emitters are working. In addition, it steps you through the process of replacing the emitters on the Harmony 880. Although you have a different model, you may be able to pick up a few tips from this article. Good luck!
http://hubpages.com/hub/HowToFixaLogitechHarmony880Remote
Jan 23, 2010 | Logitech Harmony 785 LCD Remote Control
I can't get my Infrared port to work. What do I need to do?
infrared option shuold be in control panel you will find infraport sideways of pocket pc first try to connect a infra enable mobile device then check it.
Dec 09, 2007 | Acer n30 Pocket PC
What is beams on a htc 6800 cell phone?
this refers to the infrared transmitter. Some printers and other devices have infrared receivers to collect the information you would be sending without wires (this was done prior to wi-fi and is installed on many PDAs for legacy support. I would venture a guess that 90% or more of the people who own devices with the transmitter do not use it.
Nov 01, 2009 | HTC PPC-6800 Smartphone
My Dell Axim X5 400MHz Pocket PC wont hold the charge
Some people have said that the original ppc2002 ROM has battery draining problems. If this is something new, perhaps it is a bad battery. Ebay for a new one.
If you think it might be a software problem and you have ppc2002-also known as Windows Mobile 2002, upgrade your Axim with the A04 ROM:http://support.dell.com/support/downloads/download.aspx?c=us&cs=19&l=en&s=dhs&releaseid=R63937&SystemID=PDA_AXIM_X5&servicetag=&os=PPC&osl=en&deviceid=4434&devlib=0&typecnt=0&vercnt=3&catid=-1&impid=-1&formatcnt=1&libid=7&fileid=82832
Other Axim stuff here (make sure to choose the correct operating system - ppc 2002 or ppc 2003): http://support.dell.com/support/downloads/devices.aspx?c=us&cs=19&l=en&s=dhs&SystemID=PDA_AXIM_X5&category=0&os=PPCA&osl=EN
May 05, 2008 | Dell Axim X5 Pocket PC
How to connect it to a pc running Win XP
Simply download the active sync from http://www.microsoft.com/windowsmobile/activesync/default.mspx
And use the USB cradle to connect to computer (You can also use Infrared and Bluetooth). As long as active sync is on the computer system will recognize pocket PC automatically
Good Luck
Jan 27, 2008 | Dell Axim X3 Pocket PC
Transferring files w/o conversion?
You are going to have to use a SD reader/writer to transfer the files from your PC to the SD card and then you can use it that way.
Sep 14, 2005 | Dell Axim X5 Pocket PC
Can Axim import Palm data?
Yes, Palm data like calendars and contacts can be transfered various ways including through Outlook or via infrared.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Can the Axim connect to a mobile phone thorugh the IR sensor to connect to the Internet. If not what would be the recommended way to connect through a mobile.(
I can connect my Axim X5 to the Internet using my mobile phone via infrared without a problem. You need to create a new dial-up connection using "Generic Infrared" modem in the setup. The number to be dialled is a function of your mobile phone. On my Nokia 6230i the "number" is *99# for creating a GPRS connection. Your mobile phone has to be correctly set up for Internet access and obviously you have to have a data plan.
Axim 5 upgrade path
Microsoft is well aware of the popularity of the iPAQ 3600 upgrades made available and that is one reason they mandated a Flash ROM with the new Pocket PC 2002 hardware. I am pretty sure MS will make an upgrade path available to the OEMs. It will then be up to Dell, Compaq and friends to make it available to the customer. Dell has always been good about that. As for the ROM size. The current Pocket PC 2002 image is 22MB. I have no idea how big the next one is or even when it will be out! Could be 2003 or 2004. MS has traditionally upgraded every 18 months or so on their PDA OS since 1998. IF that pattern holds true, 18 months from Oct 2001 would be spring 2003. We'll see. Ok, back to the ROM. Most Pocket PC 2002's have a 32MB ROM though a few have a 48. I think the 48 is primarliy to handle a big user file storage area in the ROM. I would be surprised if the next PPC increased more than 45% in size. It could though, but if I had to bet, though, I'd say 32MB would be plenty. Still - I'd look at the 48MB model for other reasons. 33% faster processor, 64MB RAM, included cradle.
Compact Flash 802.11b card?
just a guse but the batery looks to have enouth mA to run a CF 802.11b card and an sd blue touth card i think if you will be connected to a network or a wifi connection i would invest the money in the 3400MAH insted of the 1440MAH.
Dell Axim X5 Pocket PC Logo
97 people viewed this question
Alun Cox
