Question about Sony NWZ-S615F Walkman Video MP3 Player
My mp3 players volume button isnt working anymore No sound when i play any video and audio. The + and - volume button seem to be working because I put the Walkman on Hold and press them and get an "On hold ..." message when I press either one. However the buttons do nothing to affect sound it almost seems like the unit is on mute or something. MP3 worked fine for ten months and all file formats e.g mp3, etc. are good.
  • japaquin Sep 26, 2008
    Reset or a format didn't help me, but what did work was popping the mp3 player open.  With a set of headphones and a mp3 file playing I opened the player shook the chipboard a bit and the audio came back on.  I know that this may be a band-aid but I did drop it a couple of times and the audio is still fine.
  • Anonymous Mar 17, 2014
    my mp3 players volume button isnt working anymore No audio is coming out when i play any video and audio. The + and - volume bar doesn't show up.
  • 66 Answers
Hi,have you tried diff headphones? or maby the jack is broken??
hope this helps :-)
Posted on Sep 03, 2008
I can't get the volume loud enough to listen to the songs on the Eclipse mp3 player(2GB). How do I get the volume to work so I can listen to the songs?
The volume button is the one under the center pause/ play (>II) button.
It may be marked VOL.
The manual does not give anymore information than that.
Try using short press or press and hold to change the volume.
This is a common method for using two functions on the one button
Jan 31, 2011 | Eclipse CLD2 MP3 Player
My volume control is not working properly. It says AVLS. What does that mean?
AVLS stands for Automatic Volume Limiter System - and it basically limits the maximum volume being output which is why your volume control isnt working properly. You will need to go into settings to turn this option off.
Press and hold the back/home button until the HOME menu appears, press the arrows to select Settings then press the Play button to confirm, press the arrows to select Common Settings then press the Play button to confirm, press the arrows to select AVLS(Volume Limit) then press Play button to change it to OFF.
Jan 27, 2011 | Sony Walkman NWZ-B135 MP3 Player
My speakers isnt working anymore i dont know why tha lights are going on everything seems 2 be fine before when i touched tha 3.5mm jack it made a strange sound that how i know it was working but now it...
This article contains tips for resolving sound related issues in Windows XP.
No Sound From all speakers
  • Check that the speakers are powered on.
  • Check that the speakers are connected to the correct ports on the PC. This is particularly important If the customer has both integrated sound and a sound card.
  • If the speakers have a volume control button - ensure that this is turned up.
  • Check that the Windows Audio service is running. If this is not running then many of the subsequent troubleshooting steps will not work. Go to Start->Run and type services.msc. Double cliick on Windows Audio. Select Start if possible and check that the Startup Type is Automatic. Click OK.
  • If the speakers are digital speakers then try forcing the sound card to use digital. Go to Start->Control Panel->Sound and Audio Devices.. On the Volume tab, click the Advanced button in the Device Volume section. In the Volume Control window, below the Play Control Volume slider, click Advanced. If this does not show select Advanced Controls from the Options menu. Select Digital Output Only
  • If possible try an external audio source like a Walkman, CD, or MP3 player (connect the speakers to the headphone jack)
  • Check that the volume control in Windows isn't muted or turned too low. See the screen shots below. Go to Start->Control Panel and double click on Sounds and Audio Devices.
Aug 06, 2010 | Harman Kardon SoundSticks II Computer...
Video ipod 80g. not playing movies
download the latest version of itunes for ur pc and ipod
Aug 29, 2008 | Apple iPod MA446LL/A MP3 Player
Sansa doesn't work
May have to substitute HOLD or REC for Volume +:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard
Jun 23, 2008 | SanDisk Sansa e250 MP3 Player
Mp3 Player wont connect
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Aug 09, 2007 | Siren Edge MP3 Player
Ilo mp3 player gets stuck on first song...
Make sure the songs are in the correct format
This is the worst mp3 player ever invented - i have to tell you this up front. There is no driver, the company does not support the product anymore - I would return it now while you still can.
Either the device is bad, the pc port is bad, or the software is faulty. Try connecting to different usb port, then a usb port on a different pc with a compatible os. If still not recognized, then there is physical damage to player.
Aug 07, 2007 | iLO (2 GB) MP3 Player
Problems changing volume & sound horrible
Your player is flipped. It thinks that it's connected to an external device, and acts as if it in line out output. When outputing to line out, you really don't have volume control, and you hear it right with the headphones, you would be missing some amplification. Try to reverse the actions that choose line output: Press and hold BACK. The Home menu appears. Press the arrows to select the settings icon(looks like a suitcase), and then press play/pause. Press the up/down buttons to select Audio Output and press play/pause. Now you should see "line out" selected. move the arrows to another setting - headphones if available, and press play/pause. Now unless something is really wrong with your player it should work. If it doesn't, use your warranty if valid, send for repair. Good luck
Jun 23, 2006 | Sony Network Walkman NW-A3000 MP3 Player
JENSEN vm9510 NO VOLUME
I am going to assume you are making a standard DVD-Video disk, since the other format takes more specialized and much less common software. One likely possibility is that you have authored your disks with mpeg audio rather than Digital Dolby (AC3) or linear PCM (LPCM) audio format. MPEG format audio is commonly used in home DVD authoring but is seldom if ever found on commercial disks. my guess is that your car player isnt set to properly decode mpeg audio disks. I would suggest you go through the menus / owner instructions for your car player and find the menu setting which allows your car player to play back mpeg (rather than Digital Dolby or LPCM) audio, and your disks should then play fine in the car. Hope this helps.
Dec 16, 2005 | Jensen VM9510 Car DVD Player
Sony NWZ-S615F Walkman Video MP3 Player Logo
215 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
