Question about HP iPAQ h6325 Pocket PC
Text messaging I am having a problem sending a text message. The message just goes to the outbox and just sits there. This was working before. The SMS icon is also grayed out. Please advise.
3 Suggested Answers
Bogdan
  • 198 Answers
SOURCE: Vanishing of sms folder.
If after a hard reset the PDA doesn't give you back the sms folder, it is most likely to asume that a ROM reinstall must be done. If you have a USB sync cable, check the HP site and download the ROM version for your Ipaq. Carefull with the rom upgrade, it's a simple process but must be done with care and by the instructions given there.
Posted on Jan 15, 2007
Bogdan
  • 198 Answers
SOURCE: SMS Inbox Disappeared
Hello Brian, The SMS folder dissapears most probably because another program interferes with it. The same happens on some HP's with camera, where this options dissapears from menu because of some user installed programs. In your case, it doesn't have to be a SMS - messaging related program, there are some compatibility issues and programs that apparently doen't have anything to do with messaging are causing this. You should first try a master reset (hard reset) (save your data first). However in some cases this doesn't help, even if the program that's causing the problem is removed, and you will need a firmware rewrite/update. In order to perform this, or if you don't want to risk performing it yourself please contact me on the live assistance for step by step instuctions. Good luck, Bogdan.
Posted on May 11, 2007
SOURCE: Text Message Failure
I simply uninstalled some Applications Softwares I downloaded from the internet. After which the problem was solved. I was able to send sms yet again. I later installed the Softwares I had uninstalled and my phone is back to normal.
Posted on Mar 03, 2008
0 characters
1 Points
Hi ! Every time I try to send a text message, it appears Memory full! Close some applications and try again.I did erase my pics as well as those file saved in my memory card, but it still hopeless. It's 3...
Go your message setting. There is option where you'll save your message and choose save to memory card.
Delete all message in inbox and outbox folder, delete all cache in your browser and close all active applications. Try to send text message.
If the notification "Memory full" still appear you must uninstall a one or more application (not just close it but uninstall it) to make some space in your phone memory. Choose application that you don't use the most.
If the problem persist, format your phone back to factory setting.
Hope this help and if helpful RATE please.
Feb 09, 2011 | Nokia 3230
Text message problem
hi there,
call the customer service of your service provider ( AT&T,Vodafone,Verizon etc)....they will set up message center number on your phone , the one that you have might be incorrect...your mobile operator will send you sim updates that will refresh the settings ....and then you will get the text message options
cheers
Jan 13, 2010 | LG KU990 Viewty
Problem receiving and sending texts on HTC P3600 PDA
Check your message center number. Contact your service provider. If nothing helps, reset your phone to factory settings
Sep 04, 2009 | HTC P3600 Pocket PC
My Nokia e51 wont send txt msg's, it used to be
there is a service center number in your message setting. if it is edited your messages wont go . correct service center can be taken from your service provider. if that is right the reset your phone once it will start working fine.
Aug 27, 2009 | Nokia E51 Smartphone
Text messages wont send, delete, or change status
I think your mobile is affected by virus. I suggest you to format your memory card and flash your phone. Dont use the backup you have taken other than the contacts. Load other things manually and frehly. hope this helps.!!
Aug 22, 2009 | Samsung Blackjack SGH-I607 Smartphone
Cant send texts but can recieve them
This is almost certainly a problem with your phone not having the correct Message Centre settings (have you ever used this phone with a different carrier?).
The Message Centre number can be found in Messaging/Settings/Text Message/Text Message Centre. You will probably need to check with your Service Provider to get the correct number, although you may find it on their website.
Mar 30, 2009 | LG KU990 Viewty
Nokia n81 8gb cant send txts
If you can't send text messages the SMS settings of the service provider may not be saved on your phone.You should define a message centre on your phone for sending and receiving text messages.Contact your network service provider and they can send it to you..
Jan 26, 2009 | Nokia N81 Smartphone
Text messaging
clear messages in your inbox outbox and drafts to clear up space. restart the phone. then try sending message
Jun 20, 2008 | Pantech Duo Smartphone
Text is stuck in my outbox
I had this same problem. Deleting and clicking "yes" at the warning screen would not remove the message from my outbox and the message kept resending for days.
Solution: In the Outbox, click "Menu" > Empty Deleted Items. Click "yes" at the warning. The message should now be gone from your outbox and your text buddy should now be able to regain sanity.
T-mobile credited back the resent text messages when I called them.
May 04, 2008 | T-Mobile Dash Smartphone
HP iPAQ h6325 Pocket PC Logo
21 people viewed this question
Top HP PDAs Experts
David Payne
David Payne
ka4iup
ka4iup
Bob S
Level 1 Expert
Are you a HP PDA Expert? Answer questions, earn points and help others
