Question about Frigidaire ATF6000ES Front Load Washer
Door lock light on
On my Frigidair Gallary front load washer the door lock light stays on, the machine will not turn on no matter what I do. No clicking or noises can be heard, just when I pull the knob the lamp comes on no matter what position the knob is turned. The washer is only 4 years old.
  • 30 Answers
The lid switch is defective, and you need to replace it.
Posted on Sep 03, 2008
MY FRIGIDAIR LTF2140FS1 FRONT LOAD WASHER DID NOT DRAIN AND THE DOOR WILL NOT LOCK TO TRY THE SPIN/DRAIN CYCLE
Hi Bob, thank you for your post! I understand that your door will not lock and your washer will not drain. Try resetting the unit by either unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn on the washer. Select a normal cycle and verify if the washer will start. If not, the washer may possibly be experiencing an issue with the door lock assembly, faulty pump, timer or control board not communicating correctly. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
Aug 28, 2013 | Frigidaire Washing Machines
2487 LG front load washer
sounds like a door lock issue , i would replace the door lock if you are not getting any error codes.
door lock error would be a DL
Feb 17, 2013 | LG WM2455 Front Load Washer
Kenmore front load washer door won't latch lock light on
On some Kenmore front load models, if the black gasket around the door opening is unseated (for example, because you drag some heavy wet laundry over it) the door will not engage the lock and stay closed. This is a feature to prevent the washer from leaking when the gasket is not sealed. To fix it, simply reseat the gasket and the door will close and lock.
Jun 21, 2012 | Kenmore 44102 Front Load Washer
Door won't open. door locked light stays on. I
Press and hold the End of Cycle Signal button for three seconds. This will turn off the Control Lock feature.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a frigidair front load washer 4 years old it pumps water out but will not spin at anytime can u help
is the door locked and the locked light on???
these things will not spin if the door does not lock and register with the control unit that it is so.. latch may need replacement.
does it move at all, in any cycle??
if not the belt may have came off, theres usually a reason why tho, investigate and correct.
worst case scenario you will have to locate the technicians data sheet inside the lower part of the unit (i hope) and check the diagnostics button dance out and follow through the diagnostic for your units problem..
you may find the motor or motor controller to have defected.
hope this helps,
best of luck,
ttfn
Oct 27, 2009 | Frigidaire Affinity ATF7000E Front Load...
Hotpoint wf 250 aquaries
try changing your water valve this should sort problem
Jun 11, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Frigidair front-loader washer door remains locked
there is an Emergancy release you can pull to open the door it is either in the soap dispenser area or behind the front lint clean out door depending on your model
Mar 30, 2008 | Frigidaire ATF6000ES Front Load Washer
My new Frigidair front loader
Wow it sure sounded like the water was turned off. There should be no problem getting a tech out soon to see whats going on why it wont bring the water in. It sounds like maybe the door lock isnt working?? Is the strike broken on the door?? I take it it wont spin on its spin only cycle??just return it to place of purchase. If you need any other assistance let me know, reply to your old posts so i can be notified you wouls like more assistance.
Jan 15, 2008 | Frigidaire ATF6000ES Front Load Washer
Door lock
Check for loose wires in the door lock; or replace door lock.
Dec 02, 2007 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
184 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
