Question about Kuppersbusch Coffee Makers & Espresso Machines
Kuppersbusch cafe profi machine
Please, help to find solution how to fix my Kuppersbusch cafe profi machine.
Fault codes for a kuppersbusch coffee machine
You didn't say which model you needed. I believe if you gop to this link and select the model you have. You will be able to open the manuel and it will tell you the codes. Kuppersbusch Coffee Machine Manual
Oct 29, 2014 | Coffee Makers & Espresso Machines
Grinder doesn't stop
Hi
I have the samedi machine and had the same problem.It was only the spring inside for the doser that give up.I had it fix and everything is fine.
Good luck.
Aug 09, 2014 | Saeco RIO Profi
Saeco rio profi making a loud noise no water coming out
Someone onCoffee Geek had this to say and it sounds like it could be the same problem:When I first got my machine--a steal from a fellow barista friend for $40!--It had been sitting dry for about 18 months, and I had the same problem with the pump. After trying some things myself, I eventually called the manufacturer's help line and was told I needed to manually prime it. I used a little squeeze bottle full of water to slowly fill the intake tubing with water and turned on the machine and opened the steam/hot water valve which turned on the pump. After some stuttering, it caught and has been fine ever since. So yes, I would recommend manually priming and then running water through the pump, boiler, and steam wand until all air is out of the system. Hopefully that will fix you up.
Aug 05, 2012 | Saeco RIO Profi
Have just bought a cafe roma de luxe cofe machine
Here's an online version of the cafe roma coffee machine. The owner's manuals this company provide are known to be very skimpy in the info they provide, so don't expect much
Hope you find this very helpful and best regards!
http://www.ariete.net/libretti_pdf/mod1315.pdf
Aug 07, 2009 | Coffee Makers & Espresso Machines
Estro Profi - Green Light not coming on
It is vapor lock possibly,
1. Soak the steam wand in some hot water for a few minutes
2. Using a cup at the bottom run the brew function and open up the steamer valve until it starts pulling water through. May take a bit of time. Be careful with the steam.
Hope this helps
my white profi of 12 years has been acting up and will not even turn on.
Good luck
Aug 09, 2008 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
100 people viewed this question
Top Kuppersbusch Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Kuppersbusch Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
