Question about Kenwood KDC-135 CD Player
Ipos nano 3
Dear sirs
i rented a car that has kenwood kdc 237 stereo system
i have an apple i pod mamo 3rd generation the kenwood sys has aux outlet kinda that u plug the earphone in i havee the audio cable however the kenwood sys doesnt recognize it and cant read the ipod nano
what 2 do
    Problem Solver:
  • 18 Answers
It will work bu tonly after enabling the aux jack.
Place unit in standby mode then press menu for a second and then goto aux and select it to aux on1
Posted on Jul 20, 2009
The aux option doesnt just come up you need to do some funny trick to get the aux cahnel to come up when you going thrugh the standby>tuner>Cd> mode
Posted on Sep 16, 2008
    Novelist:
  • 100 Answers
There shouldn't be any type of "reading" between an ipod and the head unit through that jack. That should only be audio and you should be able to just press the source button until it says AUX then it should be putting sound through your radio. Good luck
-Andrew Hawkins
Posted on Sep 02, 2008
How do you hook up an i-pod to a KDC-135 AND HEAR IT?
You will need a 3.5mm mini to mini cable (available at any good car audio store for between $10-20. Plug that into the headphone jack on your ipod and then into the aux input on your stereo. Then select aux-in as the source on your Kenwood. Now play the music on your ipod at about 3/4 volume on the iPod.
Feb 04, 2011 | Kenwood KDC-135 CD Player
Will the Kenwood KDC 1032 RCA outputs work with an ipod adapter similar to an aux output? If so, how?
Hi, if you are trying to get your I-pod to play through your car stereo, then you would need to have the RCA inputs, not outputs. If you connect your i-pod to the stereo outputs it won't work because both things are trying to push sound out of their outputs. If you connect the adapter to the stereo's inputs then it would work.
Aug 11, 2009 | Kenwood KDC-1032 CD Player
Can;t play my Ipod through Kenwood KDC 237
i was just having this same problem but i pressed standby and menu and scrolled up till i got to a AUH which is off all i did was turn it on and press standby again and my ipod started playing
Jul 06, 2009 | Kenwood KDC-135 CD Player
I pod nano will play but not take a charge
Well then you cannot charge your i pod on the bose system *******
Mar 01, 2009 | Apple iPod nano 3rd Generation
GET IPOD TO WORK ON KENWOOD KDC-W3037 CAR CD PLAYER
you have to activ ate the aux port form the menu, on standby hold the menu button and then use the control knob on the right to change the aux to on1
Sep 18, 2008 | Kenwood KDC-W3037A CD-receiver,...
Kenwood Kdc 237
hi i just had same problem . Its because the steroes aux port is not switched on as default.
I downloaded the pdf manual for free and went through the steps .Unit has to be in standby mode then hold the menu button down untill the menu appears select aux then turn it to either off aux1 or aux 2 and that fixed the problem for me :) goodluck
Aug 25, 2008 | Kenwood KSC-310CCS Center Channel Speaker...
I pod hang
If you press down on the center button while holding down on the menu button, usually the will reboot your Ipod and return it back to normal.
If you need service on it locate an Apple store in your area or your nearest Best Buy can help you out as well.
Jun 22, 2008 | Apple iPod nano 3rd Generation
Ipod nano 3rd generation and 1st generation nano
The first question I'm not sure. Is that the wireless network system that works with the wall outlets for power and networking?
The answer to the second question is No. You can only transfer playlists from ITunes into the IPod. Make sure your playlists are created in ITues before transferring.
Jun 05, 2008 | Apple iPod nano 3rd Generation
Ipod not turning on/not recharging
Have you tried holding down the menu button and the middle circle button?
first place your ipos somewhere flat and press down the circle button and the menu button,make sure your not touching any other part of the click wheel.hold them down for about 5 seconds untill the apple logo appears.then let go,and it should be back to normal.you can use this procedure any time that it freezes or stops working.Hope fully that should fix your problem.if not i suggest you get it repaired under your warrenty.
Good Luck.
Regards.
Sophie
Feb 13, 2008 | Apple iPod nano 3rd Generation
How do I put album artwork on my i-pod nano 3rd generation?
you cannot put album artwork on your ipod, it eother comes with the mp3 file or if your importing from a cd the artwork is within and put in the ipod.
Jan 01, 2008 | Apple iPod nano
Kenwood KDC-135 CD Player Logo
375 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
