Question about HP iPAQ HX4700 Pocket PC
HX4700 does a hard reset when car turns off power to 12V outlet
I have a HX4700 and use it for navigation (Navigon 4.0) in my car which is a new Volvo S40. When I turn of the cars ignition it takes approximatly 5 seconds until the power to the 12V outlet is turned of by the car. If the PDA is connected when this happens, it does a hard reset and everything is gone. If I disconnect it before the power is turned off, this does not happen... Has anyone experienced a similar problem or has any advice on this? Thanks.
    Master:
  • 450 Answers
HP told me that this is not really a problem of the PDA, but of the navigation software... Those guys told me that there will be a free of charge update to version 5.1 to cure these problems.
Posted on Sep 14, 2005
How to fix the 12v outlet so I CAN CHARGE MY PHONE IN 2004 VOLVO xc70
If there is power to the unit then a replacement can be installed.
Apr 15, 2015 | Volvo Cars & Trucks
I turn it on now it says navigon software cannot be started hold on off key pressed and press reset simultaneously..still doesnt work...help!!!!!!!!!!!!!!
Delete the app and reinstall it via iTunes.
If that doesn't work, you might want to consider restoring your iPhone via iTunes, then reinstalling Navigon. Hope that helps.
Regards,
-K
Jan 13, 2011 | NAVIGON AG NAVIGON MobileNavigator North...
I have a Navigon 2100Max 4.3" GPS. When it turns on freeze at the Navigon screen. I tried to reset it won't work. Their website is no help. Please help.
Please remove the battery for a minute or so. If the problem still persists then have the firmware reinstalled as it has got corrupted.
Dec 14, 2010 | GPS
HP iPAQ hx4700 need default password
If you can't remember your passcode, you may have to do a hard reset(factory settings) if you have a sync folder on your computer, there is your backup. To do a hard reset: 1. Remove your iPAQ from the cradle, making sure that it's running on the internal battery power. 2. Use the stylus to press down the recessed reset button on the back or side of the iPAQ. 3. While the reset button is held down, press the On/Off button. 4. Release the reset button. When you press the On/Off button again, your iPAQ turns on and all your files are gone. To avoid repeating this major disaster in the future, you should back up your iPAQ files on your desktop PC. Activesync will generate another folder,and you will have to rename your pocket pc. But once your past that point, open both folders and drad and drop into the new folder. Hope this helps.
Jan 25, 2010 | HP iPAQ HX4700 Pocket PC
Black screen - won't turn on
I have put solution to fatal application error try that solution us IE as web brouser.
Nov 29, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Wont turn on charged it it still wont turn on ,
Try holding the power button while plugging it in. Also try holding the power button while wiggling a mini screwdriver in the reset hole
Oct 15, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Navigon 2100 displays the computer symbol when connected to charg
Wiring diagram pinout for Navigon GPS charge and concurrent use Pin Pin
Name Description 1 +5V 5 Volts Direct Current 2 Data floating/Not connected 3 Data floating/Not connected X Ident Conneted to Pin 4 (GND) as pure short, no resistor 4 Ground Ground, shorted to pin "X" Use of standard mini-b will place unit in Data Exchange/Synchronization mode. Use of mini-b with a 4-x pure short will allow use of Navigation software and concurrent charging. USB power source must be 1000 ma or above.
Sep 13, 2009 | Navigon 2100 Portable GPS Receiver
My Navigon 7100 doesn't turn on! It does get charged though...
I had a similar problem with my 2100Max. I took the SD card out, plug it into my computer and then reinstall it. It works like a charm these last months still.
Jun 08, 2009 | Navigon 7100 GPS Navigator GPS Receiver
Plug in car charger and it shows navigon connected to computer
The problem lies with the fact that a standard mini usb pin-out has + voltage on pin 1 and ground on pin 5. The navigon is programmed to recognize this as a computer. The navigon charger however has + voltage on pin 4 and ground on pin 5. The reason for navigon doing this as opposed to following the standard pin-out is due to the unit requiring a stronger power supply to charge the battery. USB current output on a computer does not have the capacity to do this. As a consequence, you will have to find a charger that has the right pin-out for this device ( + on pin 4 and - on pin 5 ). The tough thing is, there is no way to tell one from the other, they look identical. However, I have found that chargers with a capacity of 1000 ma or greater are pinned-out like above ( + on pin 4 and - on pin 5 ). Other than using a multimeter to verify the pins, the only thing to do, would be to plug it in and see if it works. Hope this helps.
Dec 28, 2008 | Navigon 2100 Portable GPS Receiver
HP iPAQ HX4700 Pocket PC Logo
94 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
