Dc power cord for sansui tv
I have a sansui ac/dc tv but the power cord has gone bad and am needing another one can you help me the model# is com311ada made in april 2001 serial # is 055410410417 how can i get a replacement for this thx
    New Friend:
Tetv sansui modelo com311ada y esta bloqueado solo se ve el canal 8 vtv como hago para desbloquearlo gracias
Posted on Feb 20, 2016
  • 520 Answers
You may be able to order a new cord from Fox International 888 369 0304.
Posted on Sep 03, 2008
How to wiring the power cord to the F/R switch?
Will need more information: make, model, etc. A corded drill motor can be AC or DC. It can be variable speed on not. An AC motor can be reversed by changing the magnetic polarity of the start winding (switching the two start winding wires). This type of wiring in not usually variable speed. A DC motor is reversed by changing the electrical polarity of the primary motor leads. Usually these type of devices have a rectifier circuit to produce DC voltage and use a PWM signal to develop variable speed.
Sep 24, 2014 | Drills
Plugged in and not charging
1) Use a multimeter, check the AC adapter (Charger) for power.
Make sure it is putting out the required voltage.
Have an assistant gently wiggle the cable FROM AC adapter TO laptop. See if there is an intermittent reading on the multimeter.
Have an assistant gently wiggle the power cord.
An intermittent reading on the multimeter indicates a broken wire.
Power cord is bad? Replace cord.
Cable from AC adapter to laptop is bad? Replace AC adapter.
If you have posted the laptop manufacturer NAME and MODEL NUMBER, I could have given you more than generic information.
Model Number is in the Bottom of the laptop. Post back in a Comment.
AC adapter works OK?
Check the DC Power Jack.
The DC Power Jack is the jack on the laptop, that the AC adapter plugs into.
DC Power Jack checks OK, this is your problem,
http://mayohardware.blogspot.com/2010/04/important-parts-on-dv6000-and-dv9000.html
Regards,
joecoolvette
Jan 31, 2013 | Computers & Internet
Power connector pinout for CT-13R50 television
Directly from the user manual, Page 5 under "AC/DC Power Sources":
DC Models ONLY
"This TV model operates on both standard household current (120 volt, 60 Hz AC) and car battery (12 volt negative ground DC) through the cigarette lighter. An AC power cord and a car cigarette lighter adapter cord are supplied.
Household Installation
Insert the AC power cord into the connection on the rear of the TV. Connect the two pronged plug into an AC outlet (120 volt, 60Hz). If you are unable to insert the plug fully into the wall outlet, try reversing it. If the plug does not fit, contact an electrician. Do not force the plug or defeat the safety purpose of the polarized plug."
The manual goes on to describe the vehicle installation which is identical to the household, with the only difference being the car plug goes into the DC side of the power connections at the back.
There are several kinds of power cord available for older TV models. Unfortunately, after an exhaustive search, I was not able to locate a photo of the back of that model television.
However, I have included three of the typical US power connectors found on a great many devices and in the majority of cases, one of these cords will likely be the one you need. They can be found at most local stores such as Wal-Mart, or can be ordered online from Amazon. Also, the cored generally only fit in one direction, especially if the cord happens to be polarized (thin blade and wide blade).
I hope this helps!
Panasonic CT 13R50 Manuals and User Guides
Apr 18, 2017 | Televison & Video
Samsung ltm1755b dc cord missing/need replacement
You can order a replacement AC/DC adapter power cord for this model (LTM1755B) from a major Samsung parts distributor at the link below:
Samsung LTM1755B Replacement Part AC/DC Adapter Power Cord
Apr 17, 2009 | Samsung LTM1755 17 in. HD-Ready LCD...
13" sansui AC/DC 12 volt use
Did you check the fuse inside the plug on the 12volt cord?
Feb 01, 2009 | Sansui COM312AD 13" TV/VCR Combo
TV/DVD COMBO WON,T WORK ON DC WILL WORK ON AC
Have you checked the fuse in the plug on the end of the DC power cord? Just unscrew the end.
Dec 30, 2008 | Sansui CDVD9000
Looking for power cord
That isn't a 'power cord' but rather an adaptor since it supplies DC power from an AC source.
Since you did not include the brand name and model of the monitor, you won't get much help here. I suggest you find that information and then go directly to the manufacturer's website to look for a replacement.
Oct 14, 2008 | Computers & Internet
Orion tv power cord
Try your local radio shack. They may have a universal cord that will work
Apr 09, 2008 | Orion1934 19" TV
I DON'T GET A AC POWER CORD JUST THE DC FOR MY VAN.
I'm looking for that TV For my van..we had same tv and now it doesn't work. How much would you sell it for?
Thank you
Mar 30, 2008 | Audiovox AVT1498 TV
Dc power cord
It should show it on the old cord, or on the DC jack on the TV set. A little diagram should be right by it.
Sep 14, 2007 | Sansui COM311AD 13 in. Combo
Televison & Video Logo
530 people viewed this question
Top Televison & Video Experts
