Question about Canon EOS-10D Digital Camera
Manual white balance
How does one do manual white balance on a 10D? I'm sure I can find the answer in the owner's manual but I procrastinated and didn't make time for this. Thank you.
    Sergeant:
  • 255 Answers
From Page 52, Canon EOS 10D instruction manual --- 1) Shoot a white object. * The white object should fill the entire partial metering circle. * Set any white balance setting. (see p.50) * Shoot the white object so that a standard exposure is obtained. If it is underexposed or overexposed, a correct white balance setting might not be obtained. --- 2) On the menu, select [Custom WB]. * Press the Menu button. * Turn the thumbwheel to select [Custom WB], then press Set. --- 3) Select an image. * Turn the thumbwheel to select the image captured in step 1, then press Set. - The image's white balance data will be imported. * After the setting is completed, the menu will reappear. * To exit the menu and turn off the LCD monitor, press the Menu button. --- 4) Press the AF-WB button. 5) Select the ?custom white balance?. * Turn the thumbwheel to select the custom WB symbol. Notes: - For the standard white object, a sheet of plain, white paper is recommended. - You can store on the CF card the images of the standard white object captured under various lighting. Then while shooting, you can select one of these images with the [Custom WB] menu command to easily set the white balance best suited for the current lighting condition.
Posted on Sep 14, 2005
    Sergeant:
  • 255 Answers
Click the AF-WB button and then with the wheel in the back of the camera select either K or any of the other settings. If set to K then you must go to your Menu (click menu button on back) then go to Color temp. and select your Kelvin tempature. Hope that helps....
Free owners manual ae1 canon film camera
You may download a copy of the AE-1 manual here.
If you have an AE-1 Program, you may download its manual here.
Dec 02, 2011 | Canon Eos 10d 20d 30d 1v Ae1 A1 Ef Ef-s
White balance is off on my Canon EOS 40D; how do I fix it?
Where is your owner's manual? It explains the procedure for setting the white balance.
Jul 20, 2010 | Canon EOS 40D Digital Camera
I'm using my Canon 350D to shoot jewellery in a pop up "cube" and it gives a very yellow light. Is there any way to adjust the 350D for a bright white light? Many thanks Anthony
Try the various white balance settings until you find the one you're looking for. If you don't find one in the presets, you can set a manual white balance using a white sheet of paper...check your owner's manual for instructions.
Nov 12, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Colour balance for majority of photo is good but sky or white goes to pink. Colour balance is obviously not the problem. Help?
How about White Balance? Taking a photo outdoors, for example, white your WB is set on "Fluorescent Light" will turn your images bluish. To set WB, see the owners manual.
Jun 07, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Need a canon 10 d manual
Manual for EOS 10D PLS RATE ME FIXYA FOR HELP
http://gdlp01.c-wss.com/gds/0900000229/EOS10DIM-EN.pdf
all downloads for EOS 10D
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=325&modelid=8772
Apr 03, 2009 | Canon EOS 10D 35mm SLR Camera
Setting custom white-balance
F1 or 4 are white balance memories, rather than buttons to set the WB.
Menu > Custom WB > Right Arrow > Select F1 or F4 >
Then put your piece of white card in front of the lense and hit the shutter button. Make sure you haev enough light though !
dave
Jul 26, 2008 | Fuji FinePix S2 Pro Digital Camera
10D Canon SLR can't start up
Well replace it by all means - what does the Manual have to say about this particular battery It is usual for a full manual to be on a PDF file on the software disk - have you checked this out? If all else fails- Canon Technical Support is the next stop
May 30, 2007 | Canon EOS-10D Digital Camera
Is full EXIF available for W1? Menu Items
You might try the free exif viewer: http://www.opanda.com/en/iexif/index.html Once installed, just Right Click on your image and select View Exif
Sep 15, 2005 | Sony Cyber-Shot DSC-W1 Digital Camera
Magenta cast
I guess it could be several things; perhaps the color temperature of your lights is the culprit. At any rate, it shouldn't be too difficult to correct - here are two suggestions: 1) Shoot in RAW mode so that you can fine-tune color balance after the fact and don't have to get it right in-camera. 2) Shoot a black/white/grey card in the same lighting as your subject. (all three "colors" on the same card) You can then use the eyedropper tool in either curves or levels to set the black and white points, and the grey eyedropper tool (when clicked on the grey in your shot) should get rid of any color cast, magenta or otherwise. Good luck!
Sep 14, 2005 | Canon EOS-10D Digital Camera
Canon EOS-10D Digital Camera Logo
191 people viewed this question
Top Canon Cameras Experts
old marine
old marine
Doberman
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
