Question about Konica Minolta DiMAGE Z1 Digital Camera
Service manual I dropped mine , lens is stuck in the out position. I need a service manual or instructions on how to open case. Thank You.
  • Iam Noone Sep 03, 2008
    camera was on and lens extended almost fully when dropped. Now lens is cocked horizontally to the right when facing camera. I need an exploded view of the camera case and lens assembly. Thank You.
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Service manual available on payable website. If you are interested, let me know.
  • 10,594 Answers
Did you receive my previous message as follows...
Clarification Request by welcomejee, posted on Sep 02, 2008 Service manual available on payable website. If you are interested, let me know.
Posted on Sep 02, 2008
Lens stuck open
hey, I had the same problem when I accidentally droped my camera, some parts in the mechanism are probably broken or jammed.
Most likely repairs required.
Apr 13, 2008 | Samsung Digimax S600 Digital Camera
Camera dropped. lens is stuck in open position, won't turn on
Hello
Thank you for using FixYa for your problem
Zoom lens is jammed, It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Jan 20, 2010 | Cameras
Dropped the Camera, Lens is stuck open
I already tried posting this but I think it falied. Just in case, here it is again!
I just now fixed my own Nikon S220 (very similar to 210) which suffered the same fate as yours. However, I laid my camera down on a cushioned foot-rest (you could use a couch cushion or pillow on a table) with the lens facing UP, pressed down on both sides of lens front gently yet firmly, and BAM, the lens went back in all the way. I turned the power back on and the camera is good as new (except for the small dent from the fall of course).
I suggest you try this before spending $100 on repairs and/or buying a new camera!
Sep 09, 2009 | Nikon Coolpix S210 Digital Camera
Optio s4i shutter lock up
If it is under warranty i advice you give it for service as this is a pretty complicated procedure to get it fixed.
This error is caused due to the failure of lens alignment system.Try following the procedure below..
it may be the lens contacts or grit in the gears
open it up on the side of the lens you will see a row of thin gold coloured contacts that report the lens position back to the cpu sometimes these get dirty or bent.on the side of the lens is a motor, look where the gear meets the lens and use a pin to flip out any grit that is stuck in the teeth.
Its very unlikely the lens is "out of alignment" this just cant happen unless its been dropped or bashed, in which case it may be broken and needs to be sent in for proffessional service.
Sep 28, 2008 | Pentax Optio S4i Digital Camera
Sony dsc-p200 camera - lens stuck out
Download the service Manual for this Camera from www.eserviceinfo.com/downloadsm/22939/SONY_P200.html and that should get u started to fix it yourself and in case you need parts for it, go to ebay and buy it "as is". Just make sure that the part you want is good. Good Luck!
Mar 15, 2008 | Sony Cyber-Shot DSC-P200 Digital Camera
Dropped dsc 650
sir, internal lens unit dislocated or broken ,its randomly shuts off u try any local reparer
Jan 31, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
Lens stuck open
Hi! Sounds like we have the same problem but mine says lens error 221,0,0,0 and my daughter dropped mine. If i dont get an answer soon, im sending my in for repair, it will only cost me $50.00. Here is the website incase you want to fix yours :) WWW.Kodak.com and just click on the repairs and services. Good Luck!!
Jun 18, 2007 | Kodak EasyShare C703 Digital Camera
Dropped the lens, nothing broke but focus ring came undone
This will need technical service eventually. Try temporary solution with Sellotape or similar
May 07, 2007 | Canon EF 50mm f/1.8 II Lens
I dropped my camera and now the pictures are funny...
What you describe is the symptom of a stuck shutter. The shutter is inside the lens and must close in order for the image sensor to properly record the image. Yours is stuck open, and that is why you see the lines across your images. When a stuck shutter results from an impact it usually requires full disassembly and manual re-setting of the delicate shutter blades. This problem would require professional repair. Unfortunately damage from an impact is not covered by your factory warranty. You can find good repair services on the internet who can service your camera. David Millier Advance Camera Repair
Dec 17, 2006 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Konica Minolta DiMAGE Z1 Digital Camera Logo
332 people viewed this question
Top Konica Minolta Cameras Experts
Greg Cann
Greg Cann
Willem.
Willem.
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
