Question about GE Spacemaker JVM1640SJ Microwave Oven
Scratched control panel
The plastic that covers my control panel is all scratched. Does anyone know how to replace just the plastic? I spoke to GE and it only comes as the control panel assembly which is $110-200 to replace depending on where you look.
  • 706 Answers
You might try a local appliance repair shop to see if they have any used microwaves that they are scrapping for parts... Ask around at a few appliance repair shops.. you may be surprised and find one.. Good luck..
Posted on Sep 03, 2008
Scratched Control Panel
Normally yes, however you must contact to the supplier manufacturer and ask them because some material are compatible other NOT.
Get the support via ONLINE char or phone.
God bless you
Sep 30, 2012 | Frigidaire FGMV185KF Stainless Steel...
I've got a badly scratched touchpad membrance from abrasive sponge - lesson learned the hard way. Anyways, how do I replace the touch pad membrane on a Kenmore Microwave Model # 721.80049700? I&
I am not familiar with that specific model but typically touch pads either come as an assembly or as just the membrane that has a peel off paper on the back that covers a sticky layer that sticks onto the metal frame inside your unit. If that is the case, you have to remove the old touch pad and take a screw driver or a knife and start at one end and lift it off of the frame, once peeled off, clean the metal frame with laquer thinner to remove the old adhesive, make sure it is dried completely and then take off the protective paper of the new pad and stick it to the frame. If it is a plastic frame you CANNOT use a solvent like laquer thinner as it will melt the plastic frame and destroy it. On those I tend to just drag a razor blade across the surface until I feel it is clean enough to mount the new one. You could use alcohol to clean it. Or possibly mineral spirits. You jsut want it to be perfectly clean and grease free
Oct 02, 2017 | Microwave Ovens
We have a GE Oven Model JKP70W where the cover on the control panel came off. Can one replace just the cover for the control panel or the entire control panel?
Call GE - 866-622-6184
There is a campaign to replace that part as they are defective.
They will send you the part for free, but charge you $200 to install it. The install is not too hard. Make sure you power off the oven when you do it. Instructions are included.
May 26, 2012 | Microwave Ovens
How do I remove crazy glue from control panel? The cover over the plus control(to raise oven temperature) was coming off so I thought I would glue it back on! Bad idea ....now that control remains...
Not to much can repair / remove the crazy type glues once they are applied to plastics and plastic overlays. Some people attemp to use these not knowing that some types of plastic will not bond. most of the solvents that can desolve the glues will also damage the panels.
Mar 27, 2012 | GE Microwave Ovens
Is it possible to restore the teflon surface of teflon coated pans on which the surface has become scratched (in this case Jamie Oliver Tefal Frying pans)
No. There is no effective repair procedure for the pan once the teflon coating has become scratched down to the bare metal or begins peeling off.
You can continue to use the pan safely, but the non-stick surface will not be as effective as an undamaged coating would be.
Never use metal forks / spatulas / utensils on a teflon coated pan.
Instead try using thermal rated plastic, teflon, or wooden spatulas which will not scratch the pan coatings.
Good luck.
Jun 12, 2011 | Microwave Ovens
HOW DO YOU REPLACE THE LIGHT BULB IN A GE 1540 MICROWAVE?
1) unplug unit and remove microwave cover (phillips on 3 sides)
2) unscrew white funnel shaped plastic part near back of control panel
3) remove specialty bulb and disconnect leads
4) look for T170 bulb replacement (eBay has them) or roll your own 25W bulb solution
Nov 11, 2009 | GE JE1540 Microwave Oven
GE JVM1190WY 003 Microwave Convection sparks
The problem that you are having is that the magnetron inside the microwave is shorting out to ground and it will find the shortest path to reach whatever has metal in it. Replacing the magnetron will solve your problem altogether and you need not do anything else different and continue using your metal racks.
Nov 09, 2008 | GE JVM1190 Microwave Oven
Keypad buttons fail
I always recommend that you use the hood / vent fan whenever cooking on the stove top. That can help keep steam out of the controls.
Also, I always recommend that users spray cleaner on a soft cloth (not on the keypad itself) then wipe the control panel off.
I recommend a soft cloth since paper towels can scratch the plastic.
Also, I always recommend non-ammonia cleaners since ammonia can crack and damage plastic.
Otherwise, the spray can get into the controls and lock it up or make it act odd.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Aug 18, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
How to remove the outter door frame on the GE Microwave
You need to use the entire correct model number at their site, but you can find a helpful exploded view PDF diagram by searching for "Repair Part" at the GE parts site: http://www.geappliances.com/shop/prts/ Normally you can separate the door panels without removing the door. I've included a diagram from a Sharp model that might help. If you do have to remove the door, you have to be sure you reinstall it exactly where and how it was, or you may get microwave leakage. You should definititely mark the locations of all the hardware before disassembly.
Nov 06, 2006 | GE JVM1650 1000 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
422 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
