Question about Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum
Clogged vacuum - Kenmore 35922 Slate Blue
Rather stupidly, my boyfriend 1) were vacuuming without a bag and 2) vacuumed up a big piece of cotton from a sofa cushion. And now it's making a horrible noise and I see it vibrating where the tube connects to the machine. When you look inside there's a white thing sticking out but it looks like it's part of the vacuum. If it's a clog, how do you fix it? I tried unscrewing the tray the bag sits in but it won't budge. Model # is 35922
Kenmore Progressive Upright Vacuum with Inteli-Clean System, Slate Blue Mfr. model# 35922
  • Anonymous Sep 16, 2008
    I have went through 3 of these first an intell clean kenmoore now one with a bag. And I have the same problem everytime!
  • Milo1998 Feb 26, 2009
    vacuum is making a loud noise. noise is coming from hose. Vacuum will work w/ hose, but not w/ brushes etc. hose gets tight when attatched to vacuum.Vacuum will not work in traditional setting. Will not suction. I do not see a clog.
How do i put a belt on a kenmore vac model116. 3481290
Posted on Nov 25, 2009
    President:
  • 1,673 Answers
35922 is not the complete model number, it will be on the back or the bottom of the vacuum. Example: 116.35922****
Posted on Sep 02, 2008
Beater bar not turning
need new belt remove bottom cover to replace it
Nov 02, 2014 | Kenmore Progressive 35922 Bagged Upright...
Brush stop and have to reset but stops again
Most likely on the edges of the brush, there's likely tons of hair and carpet wrapped on stopping the brush roller to spin. A worn or stretched belt could do this as well and trip the machine.
Jan 28, 2011 | Kenmore Progressive 35922 Bagged Upright...
We understand that your problem is: I currently own and use on a regular basis the Kenmore Progressive upright bagged vacuum. Model number 116.35923500. The headlight flickers and the intelliclean light...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Kenmore Progressive 35922 Bagged Upright...
I have a kenmore upright direct drive vacuum. The vacuum works fine in all ways except the brush just stopped working. Any ideas?
The rubber belt which drives the brush could be broken or the brush can be clogged with string and hair etc.
Jul 15, 2010 | Kenmore Progressive 35922 Bagged Upright...
I took the filter assembly apart, now I can't get it back together. There's a silver medal ring, a big cotton back, an inner plastic seal and an outer plastic seal. Somehow, they all fit back together....
The cotton bag wraps around the hepa filter - the blue plastic part will not be visible once the bag is in place. The silver ring sits inside the cotton bag to hold the sides of the bag against the sides of the vacuum top-half. DON'T pull the plastic inner seal and outer seal apart. They snap together and snap onto the lip of the vacuum top-half. It's a bit of a struggle snapping the seal back onto the lip.
Jan 11, 2010 | Vacuums
Vacuum clogged. Can't figure out from where.
Follow the air path: brush, handle, tube, bag, inlet filter, exhaust filter. Run the vacuum without these , in that order, to identify where the plug is.
Oct 26, 2009 | Kenmore 25614 / 25615 Progressive Bagged...
35922, sounds like there is a clog , have cleared hoses, put new bag in loss of suction, still hear loud clogged noise near rear vent hole
Try putting the vacuum hose end into vent hole while running. That may dislodge the clog. Otherwise, you will need to disassemble the machine far enough to get to the clog area.
Aug 14, 2009 | Vacuums
Clogged vacuum
You can start by taking off the bottom plate or top cover, which ever comes off, that is where the inlet starts going in and hopefully the clog is there. Could be in the hose also. But without the complete model number I can't look it up to see a picture of it.
Sep 01, 2008 | Kenmore 31912 Progressive Direct Drive...
Kenmore 31912 Progressive Direct Drive Bagged Upright Vacuum Logo
710 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
