Question about Dryers
Whirlpool dryer model leb6000pq1 dryer gets warm but not hot enough to dry clothes in 1 cycle.....i need schematics
  • Anonymous Dec 13, 2008
    mine too I converted mine to lp gas operation about wo months ago it did well for a month or so now it takes two sometimes three cycles to get clothes dry I disaembled the whole lint trap and exhaust passage way and cleaned the thermistor where it sits in the exhaust flow but no joy it still does not get hot enough. the machine is pristine clean inside its a contorl issue but I don't want to just start replacing parts can somebody help me narrow it down to the thermistor of control board? any experience or advice out there?? thanks
  • 12 Answers
SOURCE: Dryer does not get hot enough to dry clothes Roper REX4634KQ1 Electric Dryer
If your element is operating and drawing about 20 amps when on, your problem may be the thermostat (temperature dial) or the moisture sensor (if applicable).  My dryer has 2 heating elements.
Posted on Oct 15, 2007
maklean
  • 1665 Answers
http://www.repairclinic.com/0088_8_1.asp
Heating element Your dryer's heating element may be partially burned out. If it is, your dryer still heats, but at such a low temperature that it takes three or four times as long to dry the clothes. If the element is partially burned out, replace it.
Type in model No at search tab to find parts availability
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Posted on Jul 15, 2008
  • 3422 Answers
SOURCE: Frigidaire GLGQ642A Gas Dryer Problem - runs warm - cycles hot then cool
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these.
Vent Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
Posted on Aug 11, 2008
barkencoa
  • 3463 Answers
SOURCE: warm air but clothes not drying
Make sure u have seleced the high heat setting..The fact that it is heating more or less indicates that the element is o/k.
Check and clean any filter(s) that u can see,it is more likely to be a thermostat problem than anything else. and there are at least 2 of them, also check line voltage is correct.
Plz rate this solution.
thanks.
Posted on Jan 01, 2009
SOURCE: samsung dryer is not drying and its new
It ended up being a easy fix. Our old dryer was working fine and had been ran an hour before I hooked up the new Samsung dryer. Therefore I assumed when the new dryer did not work there had to be something wrong with it. There ended up being nothing wrong with it and it was my dryer vent. It was barley plugged which caused it to not heat up properly. I was told that the new dryers have a lot more sensors on them and its very sensitive about needing a clean vent to vent out the heat. My vent was not very dirty, but it had just enough build up of lent in it, it caused the dryer to not vent properly and it would keep shutting the flame off. Blew it out with my leaf blower and now it heats up and dry quick. I hope this helps
Posted on Feb 15, 2009
Dryer won't dry clothes
How to check the timer:
Sep 26, 2012 | Whirlpool Dryers
Our Whirlpool Duet Model GHW9100LW1 DRYER gets warm, but never hot enough to get the clothes dry. It takes several cycles.
Sorry to read about your problem, I hope this helps you out.
you mat have defective heat element
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Kitchen Ranges
Whirlpool dryer is not drying properly. Have to go through a couple of cycles to dry clothes.
2 things are needed to dry clothes. 1 is good air flow. Check to make sure that the dryer vent is not clogged or partially clogged with lint. Also make sure there are no kinks in the vent hose. With the dryer running you should feel good air flow blowing out of the outside house vent. The 2nd thing a dryer needs heat. Check to see that the dryer feels warm to hot when you reach in to tough the clothes. It is possible that the heat element has partially failed. Another thing to investigate is how well the laundry machine is spinning out the water in the spin cycle. This spin cycle is used to get as much water out as possible prior to placing the clothes in the dryer. The wetter the clothes when they come out of the laundry, the longer it takes to dry them.
Oct 01, 2010 | Whirlpool Dryers
Whirlpool dryer does not get hot enough to dry clothes.
Clean/repair the dryer vent. If the airflow is restricted the result is the one you just described.
Good luck,
Vlad
First Choice Appliance
Apr 20, 2010 | Roper REX4634KQ Electric Dryer
The vent may be stopped up, or the vent hose crimped so the air cannot escape, you can check the air flow at the vent on the outside of the house while the dryer is running.
try cleaning the vent and the lint screen with a vacuum cleaner, you may need to replace the vent hose, this should solve the problem
Jun 02, 2009 | Roper REX4634KQ Electric Dryer
Dryer is warm but not hot
Is the model number listed here or can you find the complete model number? May need cycling thermostat or gas valve solenoids. Let me know if I can help, Sea Breeze
Mar 22, 2009 | Maytag MDG16PD Gas Commercial Dryer
Gas Dryer Heats up very little, but not enough to dry my clothes
you need to check that for vent hose is not kinked if it is not then remove it from the dryer and see if it work right if it does then the vent tube that goes thourgh the wall has a blockage
Feb 24, 2009 | Whirlpool LGR3624JQ Gas Dryer
DRYER DOESN'T HEAT PROPERLY
check your heating element and your limit switches
Feb 10, 2009 | Whirlpool LER5636P Electric Dryer
Most common cause of this is a clogged venting going to the outside to test this remove the vent from the back of the dryer and run a load if it drys ok them you know you have a venting issue and will need to be cleaned out if not plz repost and we can look deeper into it
Jul 15, 2008 | Roper REX4634KQ Electric Dryer
Dryers Logo
298 people viewed this question
Top Dryers Experts
