Categories:
165 Products for Smith Corona
how do we use the correction on a smith corona sl...
Provided that you have a fresh correctable ribbon and lift off and they are properly installed type a letter, press correction key...
need a manual for typewriter
Try smith carona. com you may find one there.DickyO
how old is my smith corona typewriter serial no...
There is a scm place in Dunkirk NY that may be able to answer.Googlle them.DickyO
Manual for Smith Corona
Hi there, Michalina,Go to: www/manualowl.comClick on ManualClick on Smith CoronaGood luck and hope this helps!Jimmy
where can i get a manual for my smith-corona...
Can you give us any help in identifying the machine? Is it manual or electric, for example?There's a downloadable and...
Changing correction tape in model SL 105 I am
If the correction tape is moving and lifting there is a good possibility that the ribbon or correction tape are old and have...
Spell-Rite 11 SD300 - Hi,
Here is the contact information for Smith Corona. Theye aren't many typewriter repair shops left so, you'll probably have...
i cant remember my pin how do i reset the pin and
To reset the recorder you just press the SET and DEL buttons simultaneously for 10 seconds. And yes, when you reset it you will...
Doesn't type correctly. I
Printwheel in wrong. release the printwheel, make sure the pin is aligned with the slot on the hub and snap it back in. The...
Where can I get a ribbon and a correcting ribbon
I googled typewriters manila and got 3 places. You need an "H" series ribbon the L/O can be either 2 spools or a...
