Tip & How-To about Garden
Small Engine Carburetor Adjustment
This Tip is for the Weed Eater/Trimmer, Leaf Blower, type carburetors. Adjusting a Small Engine Carburetor isn't as difficult as you might think.
As a general rule, it's always best to start at 1 1/2 turns for each adjusting screw.
Screw them all the way in, turning them clockwise until snug. (DO NOT tighten them down like a normal screw!) If your adjusting screws have the plastic regulators over them, the will pull off with a pair of needle nose pliers.
Then back them both out counter-clockwise 1 1/2 turns. This will get you in the ball park. Try to start your machine at this point. (If it doesn't start, turn both screws in, counter- clockwise, 1/4 of a turn. Continue this process until you get all the way to 3 full turns on each adjusting screw. If it still doesn't start, then you have bigger problems and you will need to check out a couple more of my Tips before you can go any further.) If it does start, then you are ready to move on.
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
You should first, adjust the High screw, 1/4 turn(s) in or out, as needed. After you have adjusted the H screw, then adjust the Low screw in the same manner.
Your final adjustment should be the idle screw, which adjusts....you guessed it, the idle...lol. The Idle screw is usually larger than the H/L screws.
Good Luck!
If you should have any questions about"Drywall Finishing/Patching", or know someone who does, put your questions to Category:"Tools- Building & Power- HAND TOOLS" at FixYa.com
I will do my best to answer your questions about drywall finishing. However, it would be best if we could speak on the PHONE or do a live CHAT. I can answer any question you have if it involves getting a wall ready for paint!
Thanks for looking,
Jim
Key Words: Weed Eater, Trimmer, Chainsaw, Leaf Blower, Snow Bower, Pressure Washer, & Varnisized
Garden Logo
is there a special tool to adjust the Hi Low fuel mixture on a mc culloch t55 hedge trimmer
Anon, you may need a special type screw drive bit. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Amazon com Lifetime Warranty 2 Cycle Carburetor Adjustment Tool 4 Piece...
carburetor tool
Adjusting weed eater carb without special tool
Carburetor Adjusting Tool eBay
May 25, 2016 | Garden
poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 26, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
The leaf blower won't start and I did change the spark plug and last time it run for like 30 sec. before it shut down again.
Main cause of small gasoline engine failure is carburetor clogged. Try spraying carburetor cleaner into carburetor and intake. Check if unit has air cleaner. If engine starts briefly with cleaner then carburetor needs manual cleaning. Carburetor removal and overhaul.
Jul 10, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
poulan trimmer , will not stay running ?
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris. (Should be able to see daylight through it.) Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If you need further assistance, just let me know.
Jim
Jun 20, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
2,563 people viewed this tip
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
