Tip & How-To about Sony VAIO SZ640N/B - Core 2 Duo T7250 / 2 GHz - Centrino Duo - RAM 2 GB - HDD 160 GB - DVD RW ( R DL... PC Notebook
Computer running but not booting
I had the same problem with my hp, if you have dual ram slots remove one most likely under the keyboard. I did the now my laptop runs fine.any questions e-mail me at Timatee_808@live.com
Sony VAIO SZ640N/B - Core 2 Duo T7250 / 2 GHz - Centrino Duo - RAM 2 GB - HDD 160 GB - DVD RW ( R DL... PC Notebook Logo
I have a HP NC6120 laptop and am tring to upgrade the RAM, I found one card slot, but, don't know where the second socket is. do you?
Hello, and thanks for using FixYa.
If the 2nd slot is not in the bottom of the laptop, then you will find it from under the keyboard.
According to HP specifications of the laptop the memory is Upgradeable to 2048-MB maximum (1024-MB SODIMM in slots 1 and 2) So yes the laptop does have two memory slots. It will be under the keyboard.
Please let me know if you require further assistance or if you have any questions.
Thanks,
Ekse
Oct 17, 2010 | Computers & Internet
How can i get to both memory slots so i can upgrade to 2GB of Ram? Thanks
Your laptop has two memory slots. One of the memory slots (external) can be easily accessed if you remove the cover on the bottom of the laptop.
The second (internal) memory slot is located under the keyboard.
Keyboard removal procedure:
1. Unplug the AC adapter and remove the battery.
2. Remove two screws securing the keyboard on the bottom of the laptop. These screws are marked with a small keyboard symbol.
3. Release 4 keyboard retention tabs located on the left side from f1, f5, f9 and delete keys.
4. Lift up the keyboard and place it upside down on the palm rest.
5. Unlock the keyboard cable connector on the motherboard.
6. Remove and replace the keyboard.
Hope this helps. Thank you for using FixYa.
Sep 30, 2010 | HP Compaq nx8220 Notebook
my HP Pavilion zt1170 fails to boot 90% of the time. Once power was turned on, I could hear the fan run for one second and stopped. No video, yet the LED was on. It seems like it froze. Occasionally, it booted up successfully and it would work normally. However, it would freeze up if there's no activity for a few minutes. Any idea???
I also have a ZT 1170 and it began to do the same thing. It was a bad solder joint in the RAM slot connector in the bottom of the laptop. It would intermittently cause the laptop to hang on bootup, or to randomly lockup.
This laptop has two slots for RAM. One is underneath the laptop behind a small access door, and the other is under the keyboard and requires removal of the keyboard to access it.
To find out if your laptop problem is due to the same issue, open the bottom access panel and remove the bottom RAM memory card. Try booting it up. It should still be able to run, although more slowly due to having less RAM. If it starts up, you are closer to isolating the problem.
In my case, I initially thought I had a defective RAM card, so I purchased another 256Mbyte card for the laptop (mine came with two 256Mb cards), but the new card had the same problem. Then I discovered that pressing down on the RAM card would momentarily fix the problem, which clued me in on it being a bad connection. It seems that heat under the laptop causes some of the solder connections between the memory slot connector and the main PC board to develop hairline cracks. I was able to find the cracked joint and resolder it, but you almost need a microscope to do it. Depending on how much installed memory you need, you could simply leave the one slot empty, and buy a larger RAM card to stick into the other slot (under the keyboard). This laptop can accept a maximum of 512Mbyte card in each slot, for a total of 1024Mbytes.
Sep 01, 2009 | HP Pavilion zt1170 Notebook
I have 2 x 2gb ram, and can't find 2nd slot for one of them
if you only have 1 slot, on the underside of the laptop.
it,s most likely, if there are any more slots, they,ll be under the Keyboard.
This will possibly be, where the 512 mb is now, although some laptops do have on-board memory chips from 256-512mb. ( try under the Keyboard )
Mike @ compurepair.
Jan 21, 2009 | HP Compaq nx6310 Notebook
2,652 people viewed this tip
Top Sony Computers & Internet Experts
Martin Murray
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
