Tip & How-To about Whirlpool Duet GHW9150P Front Load Washer
Is your Whirlpool or Kenmore front load washer not draining
Hello.
The most likely problem is that the drain pump screen is clogged so its not draining and if it isn't draining it wont spin.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage,
Good luck,i hope this helps
Gene
Whirlpool Duet GHW9150P Front Load Washer Logo
wont spin
Hello, welcome to Fixya!
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Regards.
Nov 10, 2011 | Washing Machines
My washer has gone through the cycle and the door will not unlock. Please help.
TYpically the door wont unlock due to not all the water draining from the tub so the water level switch isn't satisfied the water has drained and wont allow the door to unlock.
To check the pump remove the lower panel and the lower right side will be the pump, unscrew the big white cap a little and use towel(s) to catch the water that comes out ,when all water out remove completly and check for blockage.
GENE
Aug 28, 2011 | Kenmore HE2 Plus Front Load Washer
I saw an 02 and then an S. the water does not drain and the door does not open. What should I do?
Hello.
Good luck,i hope this helps,
Gene
Aug 18, 2011 | Kenmore Elite 45986 Front Load Washer
won't spin and drain
Hello.
Gene
Aug 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
my machine wont drain water out only very little at a time what would the problem be
If your washer is going through normal spin cycles, then you need to first check and make sure your drain hose is not clogged up. If it isn't then you will need to check to see if the drain pump is receiving a signal from the control board to activate. If it receives the signal from the control board, then your drain pump is either bad or clogged. If it doesn't receive the signal then it is most likely the control board.
Jul 01, 2011 | Washing Machines
4,041 people viewed this tip
Dan Webster
Dan Webster
Sal DeAngelo
