Tip & How-To about Computers & Internet
Simple Tweaks to speed up your system
To improve the feel of how fast your system is all you have to do is reduce the response time from the start menu
to do this follow this easy windows xp tweak.
1. Go to Start then Run
2. Type 'Regedit' then click 'Ok'
3. Find "HKEY_CURRENT_USER\Control Panel\Desktop"
4. Select "MenuShowDelay"
5. Right click and select "Modify'
6. Reduce the number to "100′
When you access a directory in Windows XP it wastes a lot of time updating the time stamp showing the last access time for that directory and for all the sub directories. To stop XP from doing this follow this tweak.
1. Go to Start and then Run and type "regedit"
2. Click through the file system until you get to "HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\FileSystem"
3. Right-click in a blank area of the window on the right and select 'DWORD Value'
4. Create a new DWORD Value called 'NtfsDisableLastAccessUpdate'
5. Then Right click on the new value and select 'Modify'
6. Change the Value data to '1′
7. Click 'OK'
Computers & Internet Logo
what disavantage about LCD?
The most notable disadvantage to LCD screens is their fixed or native resolution. An LCD screen can only display the number of pixels in its matrix and no more or less. It can display a lower resolution in one of two ways. Using only a fraction of the total pixels on the display or through extrapolation. Extrapolation is a method whereby the monitor blends multiple pixels together to simulate a single smaller pixel. This can often lead to a blurry or fuzzy image particularly with text when running the screen below is native resolution.
Video was problematic with early LCD monitors because of lower response times. This has been overcome by many improvements, but there are some that still have low response times. Purchasers should be aware of this when purchasing a monitor. However, the improvements are often work arounds that can actually lead to another problem of reduced color clarity. Unfortunately, the industry is very poor about properly listing the specifications for monitors to help buyers understand and compare monitors.
  • Blurry images Outside Native Resolution
  • Motion Blur on Fast Moving images
  • Some Models Have Reduced Color Clarity
Conclusions At this point and time, most consumers will likely be purchasing LCD monitors over CRTs. There is almost no difference in the cost to consumers thanks to production improvements in LCDs and the reduction in the production of CRTs. Typically CRTs will only be seen sold with the least expensive of desktop computer systems or by those with special imaging needs such as graphics and medical professionals.
Mar 04, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Need an update for magellan roadmate 1200
Magellan® RoadMate® 1200 Software Update Version 1.50/3.12 - Release Notes This update applies to Magellan RoadMate 1200. It includes the following features, fixes, and improvements:
Improvements:
  • Point of interest (POI) Search Improvements reduce POI search times
  • Map Draw Improvements improve zooming, panning, and time to display the map
The software update version corresponds to your current software version:
  • If you have software version 1.46 or 1.48, your software will be updated to v1.50.
  • If you have software version 3.10, your software will be updated to v3.12.
You can locate your software version by following these steps:
  1. Start at the Main Menu.
  2. Press the arrow on the bottom right of the screen.
  3. Select "User Options"
  4. Select "System Settings"
  5. Select "Next"
  6. Select "Product Information"
  7. Your software version is on the line titled "Firmware Version"
Download Update: (Click here:)
I WANT TO DOWNLOAD THIS UPDATE
Feb 07, 2010 | Magellan Roadmate 1200 Car GPS Receiver
My PC Toshiba laptop is running very slow. It's
You need to give more details...
Following are the common methods to increase computer running speed:
- Delete Windows temp files
- Run disk cleanup and defragmenter, this can help you clean junk files, and speed up opening programs and files. If possible, use a third-party programs rather than the built-in system tools, they take really a long time...
- Clean WIndows registry and run defragmenter. This can reduce registry errors and reduce its size, so as to speed up application response. Here is a free registry defrag tool which I feel quite easy to use.
Jan 10, 2010 | Toshiba Satellite P105-S6197 Laptop
slow in boot up
MAKE YOUR MENUS LOAD FASTER This is one of my favourite tweaks as it makes a huge difference to how fast your machine willMAKE
This is one of my favorite tweaks as it makes a huge difference to how
fast your machine will 'feel'. What this tweak does is remove the slight
delay between clicking on a menu and XP displaying the menu.
Find "HKEY_CURRENT_USER\Control Panel\Desktop\"
Reduce the number to around "100"
This is the delay time before a menu is opened. You can set it to "0" but
it can make windows really hard to use as menus will open if you just look
at them - well move your mouse over them anyway. I tend to go for anywhere
between 50-150 depending on my mood.
Aug 04, 2008 | Microsoft Windows Vista Ultimate Edition
430 people viewed this tip
David Payne
David Payne
