Tip & How-To about Facebook Apps
How to revert to the facebook chat application to the old one
1.go to the website : http://userscripts.org. from there find the grease monkey add on.
2.install the add on
3.once grease monkey is activated a small picture of a monkey will be added to the tool bar
4. install the script (click install)
Facebook Sidebar Chat Reversiongrease monkey will do the rest, test your facebook chat then you will notice that all you online friends will inline again.
Hope this helps and have fun
Facebook Apps Logo
ingerroll rand 2132g how do I oil my air impact wrench?
Most I.R. impacts require grease in the hammer mechanism (clutch) and oil in the air motor.
To lubricate the air motor simply add oil through the air inlet about 3 to 6 drops at every use.
To lubricate the hammer (clutch) mechanism you will need a grease gun with a needle, the grease fitting (item# 17) is located on the hammer case assembly (item# 15) 2 or 3 small squirts will sufficiently lube the hammer (clutch) mechanism.
With heavy use grease the tool once a month, with light use 2 to 3 times a year.
Follow this link for the parts list, also indicates the grease needed:
http://manualarchive.ingersollrandproducts.com/ir_pdfs/Tools/Vehicle%20Service%20Tools/Air%20Impact%20Tools/80164726_ed4.pdf
Aug 04, 2013 | Impact Husky® 1/2" Wrench
my eco sense model #rtg-74pvn-2 get code c8 13
1) Copy following link for EcoSense-Rheem tankless resources:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
2) Error 13 is oxygen depletion sensor activated.
Get more fresh air to unit
Perform required maintenance.
Have qualified service technician test, clean, etc, and possibly replace burner.
3) Repair any brand tankless, same day, yourself for $368
http://waterheatertimer.org/How-to-install-gas-water-heater.html
4) Add a comment and say what you did to solve problem.
Mar 06, 2013 | Water Heaters
Can't get rid of recommended videos on youtube homepage
Hi! Try this extension. It worked perfectly for me:
http://userscripts.org/scripts/show/153698
Dec 12, 2012 | YouTube Videos
how to unblock vevo
On YouTube just use ProxTube, Greasemonkey and this script: http://userscripts.org/scripts/show/39167
On vevo only with VPN and special tools for mac for example: Jaksta and on windows use URL Snooper to get direct link
Nov 17, 2012 | vevo.com
theme of xp and vista operating system
To download themes for XP and vista, you'll need a few things.
Firefox Web Browser - http://getfirefox.com/
Greasemonkey Firefox Addon - https://addons.mozilla.org/en-US/firefox/addon/748
ThemeXP.org Link Rewriter - http://userscripts.org/scripts/show/5150
UXTheme.dll Patcher - http://www.neowin.net/forum/index.php?showtopic=140707
WinRAR - http://rarsoft.com/
Install them in that order. Once they're installed (you probably want to restart), visit http://themexp.org and download a visual style (theme). Extract it to c:\windows\resources\themes and it should show up when you right click on the desktop and go to properties.
StyleXP helps this process a bit (you won't need to install WinRAR or the UXTheme patcher). It does, however, cost money.
Nov 09, 2007 | Microsoft Windows Vista Business DVD...
559 people viewed this tip
Top Facebook Apps Experts
David Payne
David Payne
Bill Boyd
Are you a Facebook App Expert? Answer questions, earn points and help others
