Tip & How-To about Power Acoustik PTID-4003TV Car Video Player
Bypass
Just ground the wire to some metal that is on the brake
Power Acoustik PTID-4003TV Car Video Player Logo
electrc trailer brake wiring schematic
Not knowing the year or model makes this impossible to answer.
Dec 28, 2013 | RVs
Back right light does not work whent the head lights are on - works when brakes are on. - light is good -
sounds like a bad socket or a bad ground to socket.try wiggling bulb while lights are on to see if it lights, you can also take a wire and hold to side of bulb (the metal part) and the other end of wire to a metal ground on truck if it lights then its a ground, then hold on bulb and stick other end in the connector going to that plug, make sure it going to ground wire use a test light to see which is for park light and brake light and then tthe ground, if light lights when the wire is stuck into the ground wire then it going to be a bad socket. hope this is helpful. good luck,.
Dec 23, 2009 | 2002 Jeep Grand Cherokee
left turn signal quits when brakes applied but only sometimes any ideals 1984 chevy g20 conver van only happens after brakes are applied for short time period
one of the bulbs has abroken filament and it connects to the other filament causin this concern replace lr brake light bulb and it will be fine
Aug 23, 2009 | Chevrolet Sportvan Cars & Trucks
Brake Lights on a 05 Ford Escape
Hi and welcome to FixYa,
Check the ground wire. There would be 3 wires, brake, tail/park and ground. To verify, have someone step on the brakes, jump the base/metal body of the bulb socket to any exposed metal such as a screw/bolt.
Good luck and Thank you for using FixYa. Happy New Year.
Jan 02, 2009 | 1996 Ford Contour
brake lights failing
Both issues would seem to be a loose/corroded connection and most probably the grounding. The brake light is part of the taillight. Most taillights operate with dual filament bulb (3 terminal). The metal body of the bulb bottom is usually connected to the body ground. The correct procedure would be to trace the wiring harness from the taillight and determine which is the ground and verify that the contacts are clean and free of corrosion. An alternative is to add a grounding wire from said metal body of the taillight bulb and attached to any bare metal/chassis/body in the rear. The same loose ground could cause the inconsistent battery indicator.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Jun 09, 2008 | 1983 Ford Fairmont
1,031 people viewed this tip
Top Power Acoustik Car Audio & Video Experts
Tygh Duval
Tygh Duval
Jose Velazquez
Jose Velazquez
Are you a Power Acoustik Car Audio and Video Expert? Answer questions, earn points and help others
