Tip & How-To about Audio Players & Recorders
Roku, How To Setup a Roku Player
You want to try the Roku player so you can stream NetFlix to your TV over your home internet connection. It can be a bit of a hair pulling experience to set one up. So I'll try and make it as easy as it can be. First; Once you receive your player, and connect it to your TV. You need to get your new player on to your home network, be sure you have a router with wireless capability's. You will need to know the name of your home network, and you will need to know your WEB key or the pass key to secure your access into your home network. To do this, go to "Settings" (on the Roku menu) then scroll thru the menu until you see "Network", press network, look for your home network and press on it, then put in the WEB key to access your home network router. Remember after each step unplug the Roku for 10 to 20 seconds to set the memory.(may take more than 1 time with some players) NEXT; Go to www.Roku.com internet site and set up your account with them, they will need info on how to bill you if, you use a pay chanel. So they will need some bank account info, Or you can use PayPal. Next On the Roku "My Account" page, down at the right bottom of the page you will see the "Link Player" button, follow this to input your Link code, or go to http://owner.roku.com/link to input the code. Then go to the Roku menu screen and finish the setup with your Link Code. This will now activate your new Roku player. Next you will want to go to NetFlix and set up an account with them. Same thing here, they need bank account info to bill you, if you stay past the free demo time limit. Now go back to your TV, Roku menu and scroll thru the menu to press on NetFlix, here you will go thru the Menu to get another link code. This time it will come on the TV, Roku menu to go back and put that code in your NetFlix account to activate your Roku player with NetFlix. Now in the process of all this, you may have to unplug your Roku player after each link code to set it into memory. This causes a lot of folks to have some trouble as they do not, "Turn Off" the Roku after they put in the network key, the Roku link code, then again after they put in the NetFlix link code. One last bit of help. Do not create a large Instant Queue on your NetFlix account over 50. This causes problems with the memory usage in the Roku player, and It can keep NetFlix from loading. Hope this helps FixYa up.
When I click to open Netflix from Roku, there is no title pictures showing in the little boxes. There are only little pictures of a TV. What happened
Roku
  1. Press the Home button to navigate to the Roku home screen.
  2. Select Settings.
  3. Select Netflix Settings.
  4. Select Deactivate this player from my Netflix account.
  5. Select Yes. The device is now deactivated.
  6. Select Netflix from the home screen and follow the prompts to reactivate the app.
  7. Sign in to your account and try Netflix again.
All other Roku models
  2. Highlight the Netflix app and press the star key on the remote.
  3. Select Remove channel.
  4. Select Remove channel again to confirm.
  5. From the home screen, select Streaming Channels.
  6. Select Movies & TV.
  7. Select Netflix.
  8. Select Add Channel.
  9. Select Go to channel.
  10. Sign in to your account and try Netflix again.
Sep 25, 2017 | Televison & Video
How can I restore my access to Netflix?
I forgot my Netflix login or password. - Netflix Help Center
https://help.netflix.com/en/node/365
NetflixIf your Netflix login isn't working, this article explains how to regain access to your ... You can reset your password by receiving a password reset email, or by ...
My Roku freezes on the Netflix loading screen.
https://help.netflix.com/en/node/14236
NetflixHighlight the Netflix app and press the star key on the remote. Once you confirm by selecting Remove channel again, the device will be deactivated. Deactivating the Roku Streaming Stick in this manner will remove the Netflix channel from the main menu. Torestore it, select Streaming Channels > Movies & TV > Netflix.
Troubleshooting Network Connection Issues - Netflix Help ...
https://help.netflix.com/en/node/85
NetflixIf you are experiencing Internet related streaming issues such as the error "Cannot Connect to the Internet," this article will help troubleshoot your home network.
Jan 10, 2016 | Computers & Internet
where to find netflix log in for code on tv
If you experience the error code NW-1-1000 and NW-1-19, it typically points to an Internet connectivity issue.
Apr 23, 2015 | Roku Televison & Video
What special equipment do I need to watch Netflix
All you need is a computer and a connection to the internet and you can watch it directly on Netflix.com. In addition you can download the free Netflix app onto your smart TV, game console, streaming player, phone or tablet.
If what you are really asking is how do you watch it on your digital TV (not smart TV) then you will need a wireless home network and a streaming internet player such as Amazon Stick, Roku or Chromecast. Your digital TV will need an HDMI input connection. Most players are also powered through a USB port so it would be helpful to have a USB port on the TV but it can be powered with a transformer at a normal AC plugin.
Mar 10, 2015 | Netflix
how do I hook my tv to Netflix without a cable
Hello Anony, the best way is to buy a 'dongle' there is several the one that comes to mind is ChromeCast, from Google. Hope that helps Anony. Cheers Greg.
Mar 04, 2015 | Netflix
3,916 people viewed this tip
 Grubhead
Grubhead
