Tip & How-To about Ovens
What the problem is when your gas oven ignitor glows,but no heat for the oven
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
Ovens Logo
We have a Maytag gas oven and it takes close to 30 min just to preheat to 350 degrees, however the broil setting works great. Any help would be great...
Aug 28, 2011 | Ovens
stove top burners work but when the oven is turned on it looks like the pilot light will glow but will not ignite the oven
Gene...OldTech2332
Aug 22, 2011 | Maytag CWG3100A Gas Single Oven
lighter come on but burnner do not come on
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time.
GENE
Aug 17, 2011 | Whirlpool Ovens
Gas oven will not lite but thing in bottom glows do not smell gas
By "thing in bottom" Iam assuming your talking about the igniter. If you are and it is only glowing then it probably needs to be replaced. If you cant smell the gas either thats a worring sign in of itself. I would first replace the igniter and then go from there though. Let me know how it goes!!
Aug 09, 2011 | Amana Ovens
Our XL44 oven does not light. The glow bar seems to be working, but there is no ignition. How does one lift the main cover? is there a release? thank you
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Aug 09, 2011 | GE Ovens
2,900 people viewed this tip
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
