Tip & How-To about Washing Machines
Whirlpool/kenmore/estate/kitchen aid/roper waher washing but wont drain or spin?
A leading problem that will make the washer not drain is a defective lid switch. To check if that is the problem,open the lid and close it slowly,when it is almost closed you should hear a clicking sound,do this a couple times and if you do not hear the click the lid switch is what i would suspect as the problem.
To me a technician with 30 years experience i think the switch is very easy to replace,i believe with some mechinacal ability you too could replace the switch assambly.
If it turns out to be the switch i have attached a youtube video that will show you step by step how to replace it http://youtu.be/MFsvLiuTniU
Good luck,i hope this will help you to fix your washer,
Gene
Washing Machines Logo
the washer appears to be agitating but not sure if it is doing so with normal action. after the fill agitation cycle the machine does not go into rinse it just shuts off leaving the machine full of water. I tried to do it on a different wash cycle but results arew the same
Gene
Aug 09, 2011 | Whirlpool Washing Machines
kenmore washing machine fills up and washes but does not rinse and spin? It is a top load washer
Gene
Aug 09, 2011 | Kenmore 22642 Top Load Washer
my kenmore 70 series won't spin and drain.
Good luck,i hope this helps
Gene
Aug 04, 2011 | Washing Machines
washer fills ok; the wash cycle completes ok, but then it stops; no spin, no rinse cycle. This happens on all wash settings.
Good luck,i hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 31, 2011 | Whirlpool Washing Machines
kenmore washer 70 series won't drain...what could be the problem? Is it worth fixing?
Good luck,i hope this helps and if it does please give mea 4 thumbs up rating
Gene
Jul 29, 2011 | Kenmore 22422 Top Load Washer
2,005 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
