Tip & How-To about Washing Machines
What is wrong when your washer keep filling all the time
Their are 2 possibilites causing it to overflow
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement
Good luck, i hope this helps.
Gene
Washing Machines Logo
water won't shut off at specific load capacity
Good luck, i hope this helps,
Gene
Aug 15, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
model # 110.26832692 does not stop filling up with water when the load selector size is set will overflow if I don't stop it!
Good luck, i hope this helps to figure out what is wrong with your washer,
Gene
Aug 05, 2011 | Kenmore Washing Machines
my washer water never shuts off water runs all the time had to turn off the valve to get washer from filling up
I hope this has helped you,
Gene
Aug 04, 2011 | Roper Washing Machines
washer keeps filling with water never shuts off overflows
1) the water inlet valve that the hoses from the house plumbing attach to is sticking open,when it sticks it will stick open regardless if thier is power to the machine or not,so to determine if that is the problem,start the washer and quickly unplug it,if the water continues to fill, that valve is sticking.
2) the water level switch is defective,do the same as far as starting it,if the fill stops when power disconected it's the water level switch that is in need of replacement.
Gene
Aug 04, 2011 | Kenmore 26422 Top Load Washer
Gene
Aug 01, 2011 | Kenmore Washing Machines
1,056 people viewed this tip
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
