Tip & How-To about Pioneer VSX-D810S Receiver
Loose memory
My receiver lose the memory after of power cord stay disconnected about seven days. Any body now where is the backup battery?
Pioneer VSX-D810S Receiver Logo
Losing configuration
I am not sure there is nothing that I can fined on the user manual but if you talk to your nearres electronics shop and see if there is any thing they can do
Jan 28, 2014 | Pioneer VSX-D514 Receiver
My strde445 is 10 years old now...whenever I disconnect the AC power cord (even for a dew seconds) the Demo mode is activated...accordingly to the manual the DEMO mode should only be activated if the AC power cord is disconnected for about a week. how can i fix this?
They don't actually say it in so many words but the "two week" comment and the Demo Mode startup on even the briefest power loss implies there is a battery or a charged capacitor for memory keep-alive somewhere inside the unit and it is dead or malfunctioning.
Maybe someone can add something more specific to look for. Either way, a tech needs to check it out.
My 8-year old Pioneer loses settings on extended power losses, too. Oh well.
Dec 28, 2010 | Sony STR-DE445 Receiver
we loose our auto attendant greeting everytime we lose power.
I suggest getting a battery back up or UPS for this system. If it is a 12 volt system, it should be relatively inexpensive to get one installed. Call a security system installer or a trusted electrician to give you an estimate on a battery backup. If you have one, your system will stay active for up to 24 hours during a power failure. Your Callpilot uses volatile memory, which clears when power is not supplied. If you had a battery backup, it would never lose power and your greeting will stay on it.
Thanks for asking.
-Josh
Feb 28, 2010 | NorStar CallPilot 100
lose memory
I do not know for your particular model. There are a dozens of these models in each of the manufacture type receivers. Not all of these receivers use a battery for backup.
If your reciever uses a battery for backup:
In most of these recievers the backup battery is located behind the front bezzle on the front control circuit board. On others it would be on the main circuit board. The battery looks like a small silver coin. Depending on the model, it can be a diameter of about 3/8 of an inch up to over 1/2 of an inch. In many cases the battery is a special type that has solder lugs spot welded to it. The battery would be available from the manufacture's parts and service rep for your area. You will need experience in soldering, and have de-soldering and soldering tools to change the battery in most of these receivers. The cost of the battery is usually in the area of about $6 to $10 depending on the type and rating.
If the reciever's memory uses a gold leaf capacitor:
In many models, they are using a gold leaf storage capacitor instead of a battery. The value of the capacitor is usually in the range of about 4.7 F to 5.5 F rated at 5V to 6V depending on the type. This capacitor is usually not a stock item from most generic electronics parts suppliers. The original should be available from the manufacture's service and parts rep. It is possible to order a generic type from most electronic parts suppliers. You must specify the electrical ratings for it, or an equivelent generic part number. You will need experience in soldering, and have de-soldering and soldering tools to change this capacitor. The cost of this capacitor can be in the area of about $8 to $20 depending on the type and rating.
If your receiver uses an EEPROM for its memory:
Many of these receivers use an EEPROM for the user set-up and memory settings. The EEPROM may be intergrated with the main uPC in many of the models. If this is the case and service is required, this will require proper troubleshooting to determine if the fault is actually the EEPROM section or some other support component. The EEPROM section in these receivers is usually not a socket-ed type IC device. It is usually soldered to the circuit board and it would most likely be a high density surface mount type device. In this case specialized SMD type soldering tools and the proper skills will be required to change this component. To perform this level of service, the factory service manuals, experience and training will be required.
The uPC/EEPROM would have to be purchased as an original part from the manufacture. It will contain internal firmware that is dedicated to the model of the receiver. Many times, they may recommend to change the complete circuit board rather than the IC itself.
After changing the uPC in many models of receivers, as like TV sets, there will be the factory level programing that is necessary to make the receiver work to specs. This will require the factory service manuals, training, and the proper calibration and setup instrumentation to do the task.
Jerry G.
Sep 01, 2008 | Pioneer VSX-D810S Receiver
Resetting the code
The 7550 has a battery backup (little door on bottom of machine - 2 AA batteries). Remove batteries for a couple of days and the code should disappear. Removing the batteries WILL NOT effect the main memory of the machine - they are just for the backup of any personally designed stitches and memory combinations - not the hard memory of the machine. Periodically these batteries will need to be changed - a message will pop up on the screen to let you know.
Hope this helps (ex-Pfaff employee - GREAT MACHINE!)
Mar 21, 2008 | PfaFF Creative 7570
1,660 people viewed this tip
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
