Tip & How-To about Washing Machines
How to change lid switch in a Whirlpool top load washer.
Tools needed: Phillips screwdrive, flathead screwdriver, putty knife, 3/8 inch nut driver.
Every model is different. So read though. While standing in front of washer there is a phillips screw on each side of console. Some models have a screw on each side but in back of console. Some models dont have screw so you will need a putty knife to slide under console on each side an push the clips inward and lift up on console. Once you have removed the screws or the clips lift the console and allow to flip upside down and the support hindges on the back of washer. Disconnect the quick connect the clips into another quick connect Brcketed on the frame. Remove the two gold curved shaped hinges one one each side with the flathead screwdriver.Tilt cabinet back and move it away from the washer. Unerneather you will see a quick connect with wires running to the lid switch. Remove the two phillips screws that are under the lid holding the lid switch in place. Remove the 3/8 inch nut holding the ground wire next to lid switch. There are also two hindges the hold the wires inside the lip of the frame. Pull hinges towards you enough to allow the wires to come out. Install new lid switch with the two phillips screws from the old one. Reconnect the 3/8 inch grounding wire to frame. Insert the wires back inbetween the hindges to hold wires. Snap the quick connect into the frame from underneathe. It can only go on one way. Once you have the new lid swtch installed than go back in front of washer. Place the cabinet back in place. Push the lower lip of the bottominside of cabinet back under lip of frame of washer. Gently tilt the cabinet back into place. Take your hand and make sure the glide (white plastic strips ) on the back frame line up and than put the gold hinges back in place. Than do the other side. Make sure its stable. Reconnect the lid switch quick connect. Place console back into place and make sure its snug. Put screws back in place. Now standing in front of washer. Tilt washer towards you to reset the self leveling legs. Now lift the lid and start your washer in spin cycle. Close the lid and open it until the basket returns to normal stopping mode. Keep doing this it usually takes 5-10 times increase speed of basket each time ( have lid closed longer for faster speeds). When the basket breaks are reset you will hear the breaks engage and the basket slowly comes to a stop. If you see it jerking or breaking hard The break package is not reset yet keep trying to reset. Once the break package is reset and the lid switch works good than its laundry time.
Future knowledge: Lid switches go out for a few different reasons. If you drop the lid and it hits the lid switch hard it can start damaging it. Wear and tear using your washer will wear them out over time. Most common is the dropping of the lid which breaks lid switch over time. Thank you for taking your time to reason this How To and I hope this helped you in your task.
Washing Machines Logo
the start button fell off need to remove panel to get out and reattach what tool do i need
A putty knife to open the top and then either a phillips screwdriver or nut driver to remove the front panel.to get access to the switch
Apr 27, 2015 | Maytag Bravos X Series MEDX500BW 29"...
mmi have a ge advantiun x20 model SCA1001FSS01 THE HNDLE IS BROKEN OFF HOW DO i REPLACE THIS pafife@yahoo.com
HELLO.
THE SOLUTION ON HOW TO REPLACE THE BROKEN HANDLE
THINGS NEEDED.
Phillips screwdriver.
Thin, flat-head screwdriver.
Putty knife.
Replacement microwave door handle.
1 Examine the inside of the door. The handles of some early GE Spacemaker microwave models were attached after the two inner door panels were assembled to the outer door. If you see two recessed screws opposite the handle attaching points, undo them with a Phillips screwdriver and remove the handle. If not, go to the next step.
2 Insert the blade of a thin, flat-head screwdriver into the top, outer corner of the door, between the plastic inner frame and the outer door. Gently pry the inner frame out and slip a putty knife into the exposed opening on top of the door. Slide the putty knife toward the hinges to free the top of the inner frame; repeat on the front and bottom edges of the door and lift the inner frame out to expose a second metal inner frame.
3 Insert a thin, flat-head screwdriver into each of the small square openings on the top and bottom of the inner metal frame, starting at the handle end of the door. Undo the attaching clips by gently levering the inner door away, using the rim of the outer door as a fulcrum. Move the inner door away from the outer door on its hinges.
4 Remove the glass from the outer door. Undo the two screws holding the handle to the outer door with a Phillips screwdriver. Screw the replacement handle onto the door and tighten securely.
5 Replace the glass panel and reassemble the door by snapping the two inner frames back in place.
Thanks.
Aug 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
how do you remove the front kick panel
Here are the steps.Hope this helps.
Insert a putty knife between the top of the kick plate and bottom of the front panel near the center of the washer, if you have an older model top load washer. Move the putty knife blade in and out in that area until you feel an obstruction. The obstruction is the kick plate retaining clip
Press the putty knife blade over the spring clip until you feel the clip disengage. Let go of the putty knife and grab both ends of the kick plate with your hands. Pull the kick plate away from the washer
ift the front of the washer with help from a friend, if you have a front load model Whirlpool. Slide a block of wood under the front of each side and gently lower the washer Remove the three hex head screws on the bottom edge of the washer kick plate with a Phillips-head screwdriver or nut driver. Pull the kick plate away from the washer.
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
How do I re-install the idler pulley belt on the drum?
Instructions
Things You'll Need:
* Duct tape
* Putty knife
* Phillips-head screwdriver
1 Unplug the LG dryer power cord from the dryer outlet. Pull the dryer out two feet from the back wall so that there is room to raise the top panel.
2. Place duct tape over the edges of a putty knife blade. This protects the finish of your dryer while using the putty knife. Insert the putty knife blade in between the front and top panels, three inches from the right corner. Feel for the spring clip with the blade, and lift up on the right corner as you slide the blade over the spring clip. Repeat the process three inches from the left corner. Lift the front of the top panel straight back toward the rear wall.
3. Open the dryer door and remove the two screws on the lower lip of the dryer door opening with a Phillips-head screwdriver.
4. Remove the two screws on the top edge of the dryer front panel with the Phillips-head screwdriver. Pull the front panel away from the dryer enough that you can access the door switch wiring harness on the left side of the cabinet by the door.
5. Grasp the white wiring harness connecting to the door switch on the inside of the front panel with your fingers. Squeeze the locking tabs together and pull the harness away from the door switch. Pull the front panel off the dryer.
Feb 22, 2011 | Maytag PYE2300AY Electric Dryer
I have a Kenmore 90 series dryer. I want to clean the lent that has accumulated. I want to remove the lower front panel to do this. How do I remove that panel
Get a putty knife or flathead screwdriver. There are two clips between the top panel and bottom panel about 3 inches from the corner. Push your screwdriver/putty knife straight in and it will release from the top. Give a little pull. There you go!
Aug 19, 2010 | Kenmore Dryers
717 people viewed this tip
Top Washing Machines Experts
