Tip & How-To about Cell Phones
Best secret codes sony ericsson
1. Sony Ericsson Secret Menu: -> * <- <- * <- * (-> means press joystick, arrow keys or jogdial to the right and <- means left.) You'll see phone model, software info, IMEI, configuration info, sim lock status, REAL time clock, total call time and text labels. You can also test your phones services and hardware from this menu (main display, camera, LED/illumination, Flash LED, keyboard, earphone, speaker, microphone, radio and ******** tests)
2. IMEI Number: *#06# -For checking the International Mobile Equipment Identity.
3. Lockstatus: <- * * <- -SIM lock - Do not lock your phone if you don't know the unlock code. This is another good check before you buy any phone, especially second hand ones. If phone is SIM locked, you may not be able to switch to other GSM operators.
4. Shortcut to last dialed numbers: 0#
5. Shortcut to sim numbers: On main menu type a number and press #
6. If you change the language from default to any other language, then it may be difficult to switch to default language. The shortcut is very simple. Just press <0000>. <> stands for right arrow button or joystick.
Cell Phones Logo
i formatted but its appear the same thing
Hello, Please do it and reply me whats the problem ,
> * > means press joystick or arrow keys to right
1. push joy stick to RIGHT once
2. press *
3. push joy stick to LEFT twice
4. press *
5. push joy stick to LEFT once
6. press *
The Service Menu will appears containing following information !
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
b. LED/Illumination - *This test is very cool
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
i. Joystick Counter*
Lockstatus:
Secret Games: Snake on the T68
Go to Erix and then on the main screen press 123 and you will be taken to the game.
Reply me
Jan 26, 2011 | Sony Ericsson K790i Cellular Phone
how to format my sony ericsson w350i phone internal memory
HELLO, Sony Ericsson Secret Menu:
2. press *
4. press *
6. press *
1. Service Info
a. Software Version
b. SIMlock
c. Configuration
2. Service Setting
a. Contrast
3. Service Test
a. Display
c. Keyboard
d. Buzzer
e. ********
f. Earphone
g. Microphone
h. Real Time Clock
Lockstatus:
Hope this helps
Jan 26, 2011 | Sony Ericsson W350A Cell Phone
I have a Sony Ericsson C905a cell phone, and my mic is broken: When I make or receive calls, I can hear the other person but they cannot hear me. Is there a way I can fix this?
you need to replace the mic hardware if that is the case.
Sony Ericsson Secret Menu: -> * (-> means press joystick, arrow keys or jogdial to the right and
so do the mic test, if there's response then go to a certified SE tech and replace the mic
Oct 23, 2010 | Sony Ericsson C905a Cell Phone
don{t know how to do it
note: u must have a usb cable for this phone.
try to insert ur phone on the usb cable and into a computer the press file transfer and it will automatically charged. if its not work, use this: go to this ericsson secret menu by pressing -> * <- <- * <- * (-> means press joystick, arrow keys or jogdial to the right and <- means left.) the screen wrote service will pop out. then, goto service settings and there will be wrote charging __(on/off) u can read its info. then make the charging on.
Nov 15, 2009 | Sony Ericsson W850i Cellular Phone
320 people viewed this tip
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
