Tip & How-To about Cell Phones
THE JAMES BOND TRICK on NOKIA PHONES
If you short-circuit theleft middle and right pins on the bottom of the phone with all connections touching each other, the Nokia software hangs! The profile "Headset" will be activated. Before you do this just activate the "Automatic Answer" in the headset profile and set the ringing volume to "Mute". Now you can use your phone for checking out what people are talking about in a room. Just place it under a table in a room and call it. The phone receives the call without ringing and you can listen to what people are saying.
Cell Phones Logo
have put in a 000000 code to unlock puck lock and it is now asking to reset pin but when i put a number in and confirm it, it rejects it and wants the puk again, help, sony erricson cybershot not sure what model maybe a 810, was the james bond one about 3 years ago.
this is not a phone set problem PIN and PUK was actually lock of service provider. meanwhile 3 wrong attemp of PIN be a reason of asking PUK code/ dont be smart and try a random numbers as 10 attempt of wrong PUK code will dead your SIM permanently. contact your service provider and as for PUK code.
please dont forget to vote if it help you
Jul 30, 2011 | Sony Ericsson K750i Cellular Phone
what is the default securety code for the lg ks360 vodafone
Other secret tricks for LG mobile or cellphone
LG all models test mode:
Type 2945#*# on the main screen.
2945*#01*# Secret menu for LG
IMEI and SW (LG 510): *#07#
Software version (LG B1200): *8375#
Recount cheksum (LG B1200): *6861#
Factory test (B1200): #PWR 668
Simlock menu (LG B1200): 1945#*5101#
Simlock menu (LG 510W, 5200): 2945#*5101#
Simlock menu (LG 7020, 7010): 2945#*70001#
Simlock menu (LG 500, 600): 2947#*
LG-U81XX SPECIAL CODES
Code to read phone version :
- Phone without SIM
- Enter 277634#*# or 47328545454#
- Select 'SW Ver.info'
Code to reset phone :
- Phone without SIM
- Select 'Factory Reset'
Code to enter UNLOCK MENU :
- Phone wit SIM inside
- Enter 2945#*88110#
Test Menu 8330 : 637664#*#
Test Menu 8180 V10a: 49857465454#
Test Menu 8180 V11a: 492662464663#
Test Menu 8130-8138: 47328545454#
Test Menu 8110-8120: 277634#*
View our Mobile tips and Guidelines for better Handling of Mobile phone.
[AD]
SECRET PRANK
Change closed caller group (settings >security settings>user groups) to 00000 and your phone will sound the message tone when you are near a radar speed trap.
Setting it to 500 will cause your phone 2 set off security alarms at shop exits.
Try this secret trick if you can handle the unexpected.
Note: This secret trick wont work with all phones Models.
THE DETECTIVE TRICK (Mobile Spying)
Now you can spy on anyone using your cellphone. Just do the following.
1. Activate the "Automatic Answer" in the headset profile of your cellphone and set the ringing volume to "Mute"
2. Short-circuit the left middle and right pins on the bottom of the mobile phone with all connections touching each other this will activate profile "Headset".
If you cant do this just keep your earphone connected to mobile.
3. Now place it under a table in a room and call it. Now you can use your phone for checking out what people are talking about in a room. Just call on your phone.
4. The phone receives the call without ringing and you can listen to what people are saying.
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 20, 2011 | Cell Phones
Sustain pedal on Yamaha DGX not working
I had the same problem, its to do with the polarity of the pedal. My pedal had a polarity switch on the bottom just flick this over and this should fix the problem. Otherwise another solution was to hold the pedal down and turn the keyboard on.
Jul 18, 2009 | Yamaha Full-Size Keyboard
612 people viewed this tip
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
