Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
50p/60p Converter-Transcode CX360 MTS to ProRes for FCP X Editing
Merge/Edit Sony CX360V 1920x1080 50p/60p AVCHD to ProRes 422(HQ)(*mov) on FCP X with Highest quality
I used Sony HDR-CX360V to record 1920x1080 50p/60p AVCHD MTS files, which are not compatible with FCP X. So in order to edit the movies on FCP X, conversion from MTS in 50/60 progressive mode to ProRes is necessary.
I've tried Clipwrap, Toast and Aunsoft to carry out the conversion. Clipwrap failed because it cannot export 50/60 progressive mode; Toast completed converting but the quality is badly affected.
Only Aunsoft Final Mate for Mac successfully converted the 50p/60p MTS to ProRes 422 with no loss of quality. I really want to say that it is the best software to Transcode Sony HDR-CX360V 1920x1080 50p/60p AVCHD MTS footage for FCP X that I've ever used.
Here is the step-by-step guide to quickly Convert/Edit Sony CX360 50p/60p MTS to ProRes 422 (*.mov) on FCP X.
1. Importing 50p/60p AVCHD MTS files to Aunsoft Final Mate for Mac
Use a USB cable to Connect Sony HDR-CX360V to Mac. Follow the popup window and wizard to complete the import.
2. Merging and converting 50p/60p AVCHD MTS files to what you want.
After the MTS movies are imported, select one or several videos you would like to convert and then drag and drop them to Movies tab. You can choose the files to be joined as one whole, or create a single movie for each file. Then click the "set parameter" button. Choose Apple ProRes 422(HQ) (*.mov) under Final Cut Pro as its output format and choose "50" (or 60) for the frame rate.
3. Export Apple ProRes 422(HQ) for editing on FCP X
After setting the output format and frame rate, click the "Export" button and conversion from 1920x1080 50p/60p AVCHD MTS files to Apple ProRes 422(HQ)(*mov) starts.
After the conversion is completed, Import and Edit ProRes 422 (HQ) on FCP X.
Tips:
If you want to join/merge Sony HDR-CX360V AVCHD MTS clips and play on WDTV Live with original quality, you can use Aunsoft Final Mate to import MTS files and flawlessly export MKV without transcoding.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Convert AVCHD Files to Apple ProRes 422 for FCP with Best Camcorder Software for Mac Do you have problems of importing AVCHD 1080/60p, 1080/50p, 1080/60i MTS or M2TS files to Final Cut Pro and want to find camcorder software on Mac OS X to Transcode AVCHD files to Apple ProRes Codec for editing in FCP without rendering? As the best camcorder software on Mac OS X for Sony, Panasonic, Canon, JVC camcorders, Aunsoft Final Mate for Mac is featured with one most important feature for Mac users-help Convert AVCHD video footage to Final Cut Pro ProRes formats including Apple ProRes 422 Codec, Apple ProRes 422 HQ Codec, Apple ProRes 422 LT, Apple ProRes 422 Proxy, Apple ProRes 4444 Codec. With Final Mate for Mac as the default camcorder software on Mac, you can choose preferable format for editing on Final Cut Pro without rendering. Final Mate for Mac also support converting AVCHD files to Apple Intermediate Codec(AIC)for editing in Final Cut Express or iMovie. The guide will share with you a easy and fast method of Converting AVCHD files to Apple ProRes 422 with featured software for camcorder on Mac. 1.Run AVCHD to Apple ProRes Converter for Mac and add AVCHD files. Launch Aunsoft Final Mate for Mac and add AVCHD files to the program by clicking on "Add" button to browser AVCHD file path on your local Mac computer. Then all AVCHD MTS/M2TS clips will show in Resource Tab of Final Mate for Mac. 2.Join AVCHD files and choose Apple ProRes 422 as output option. Directly drag and drop AVCHD files from Resource Tab to Movies Tab or Timeline to create a new movie and join AVCHD files into one for converting to Apple ProRes 422 Codec. There will be a pop-out window during the process shown as following: Please choose "Create A Single Movie" to merge all AVCHD video footage into one movie. 3. Start converting AVCHD to Apple ProRes 422 Click on Export button and follow Export into Editor > Final Cut Pro > Apple ProRes 422 HQ(*.mov) format to choose your output format for converting AVCHD to FCP supported format. Confirm your settings and click ok to starting conversion. Minutes later, you can access combined Apple ProRes 422 MOV movie by clicking on "Browse for Export Path". Now you are able to edit AVCHD files on FCP without rendering with the help of Final Mate for Mac as the best camcorder software on Mac OS X.. Tip: If you use iMovie or Final Cut Express for AVCHD editing, you may be interested to know how to Convert AVCHD files to Apple Intermediate Codec for iMovie/FCE.
Jun 28, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
2,340 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
