Tip & How-To about Computers & Internet
System Restore Via Recovery Console
Ever encountered a problem with your computer wherein it gives you an error page saying that a certain file in the registry is missing or corrupt? Unfortunately, with this kind of error, there are times that you are not able to boot into the OS, and therefor you are not able to do a system restore.
If you are using Windows 7 or Vista, you may initiate System Restore via booting into "Repair My Computer" which you can choose via the Advanced Boot Options of Windows. However, what do you do if this does not work, or you are using Windows XP.
Fortunately, there is still a way to be able to restore your system. This involves manually doing the system restore via the recovery console (for XP), and recovery environment (Vista and 7). The only thing that you will need is the OS CD.
Once you have successfully booted into the Recovery Console, type in the commands below and make sure that you press "ENTER" after each line.
C:\WINDOWS] cd \ C:\] attrib -h-s "system volume information" C:\] Cd "system volume information" C:\system volume information] cd _resto~1 ..._resto~1] dir --- this should list several rp folders [short for restore points] just select second to the last or any of your choice other the the last rp folder ..._resto~1] cd rp# ...rp#] cd snapshot ...snapshot] dir --- the 5 hive files are shown in this format: _registry_machine_software _registry_machine_security _registry_machine_system _registry_machine_sam _registry_user_.default Syntax [Command filename location] ...snapshot] copy _registry_machine_software c:\windows\system32\config\software ...snapshot] copy _registry_machine_system c:\windows\system32\config\system ...snapshot] copy _registry_machine_security c:\windows\system32\config\security ...snapshot] copy _registry_machine_sam c:\windows\system32\config\sam ...snapshot] copy _registry_user_.default c:\windows\system32\config\default ...snapshot] exit
After this, you just need to restart your computer and it should be working fine.
Computers & Internet Logo
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
how do you fix error 2400
http://www.registryquick.net/page/RegistryQuick_setup.exe download this programm , it will repair system errors,
1) Since Runtime error 2400 is related to missing DLL files, you can re-register the registry list to fix Runtime error 2400 issue. For example, if you encounter Runtime error 2400 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:windowssystem32dllfile Download Repair tools
3. Re-start your computer
If you can not find the specific file on you computer, you should download it from the Internet and locate it to the right place.
2) To fix Runtime error 2400, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 2400, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 2400 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
May 31, 2011 | Computers & Internet
I just purchased router WRT 120 N during the installation I am getting the error 322
HI there,
To fix Runtime error 332, you should understand the concept of Runtime error 332 and identify the causes of it firstly. What is Runtime error 332? This error usually occurs when a DLL file is missing, or not registered on your computer. It is a really common problem for windows users which crashes now and then.
#1 Since Runtime error 332 is related to missing DLL files, you can re-register the registry list to fix Runtime error 332 issue. For example, if you encounter Runtime error 332 at dll files, to re-register the file, please do this:
1. Click Start-Run
2. Type in regsvr32 c:\windows\system32\dllfile Download Repair tools (http://www.registryquick.net/page/RegistryQuick_setup.exe)
#2 To fix Runtime error 332, you also can try to run free registry scan for your computer. In my opinion, it is the most important step for you to fix Runtime error 332 and avoid other runtime errors effectively. There are various registry repair tools available on the Internet that scan, analyze, and fix your computer. Besides fixing your Runtime error 332, these tools will remove any registry errors, invalid shortcuts, duplicate files and repair DLL files. Eventually, you computer will be free from system error messages and sluggish performance. What you need to do is to fix Runtime error 332 as well as other registry errors to prevent your registry from total corruption. If you continue to run this damaged system and don't fix Run-time Error, this potential risk will bring you more troubles, Even system crash.
Dec 20, 2010 | Linksys WRT120N Router
keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
    Please re-install a copy of the above file."
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
new computer dell inspiron 570 running windows 7-connected for 3 days. came back to use it this afternoon and the media player has lost it's sound and you can hardly hear the PC -the system tells me =media player is corrupted but not how to fix
Microsoft Windows Media Player is a free media player software that comes with the personal computer version of Windows operating systems. The software supports basic file formats such as WMV, WMA, AVI, MP3, and ASF. The player included in Windows XP gives you the power to create your own CDs, search and organize digital media on your PC, and copy files to portable devices such as CDs and pen drives.
Fix Windows Media Player Problems
Corrupted and missing DLLs files, incorrect registry entries, and outdated files are some of the causes of Windows Media Player errors. Covered here are a few steps that you can take to fix common problems.
C00D11CD: Unknown Error
C00D11CD errors occur when an operating system component or some other program encounters an error and does not communicate it to Windows Media Player. Due to its generic nature and multiple reasons for occurrence, there is no specific solution to this problem.
If you encounter the error when trying to play an AVI or MPEG 2 file, then most likely, you do not have the correct codec version installed on your system. To fix a Windows Media Player problem related to codec, search for the required codec on the Internet, download it, and update it on your system to play the required file.
Windows Media Player uses Digital Rights Management (DRM) to authorize copying files to a CD or to download them from an online music store. If you do not have DRM authority to copy a particular song, you will not be able to play it and the error will pop up.
Windows Media Player uses the wmadmoe.dll file to encode files. If something goes wrong with this file, you may get the c00d11cd error when you try to copy songs from a CD to your hard disk. To fix a Windows Media Player problem in this situation, you must register the DLL file by running the command ‘regsvr32 wmadmoe.dll’.
80040155: Interface Not Registered
If this error occurs when you try to burn songs into a CD, then the most probable cause is that the required player files are no longer registered on your system. To fix this error, try to reinstall your Windows Media Player or download and install a newer version of the player, if available on the internet.
800C2EE2: Action timed out
This error occurs when your Windows Media Player is unable to connect to a server due to problem in the network, and therefore cannot play protected audio/video files that you download from an online music store. Incorrect Internet Explorer security settings might be the cause of this problem. To fix this, open Internet Explorer and select Tools-Internet Options-LAN Settings. Next, clear the Automatically detect settings check box.
C00D0FAA: Cannot rip the files
The error usually occurs when you try to rip CDs to MP3 format. Existence of entries from an earlier player version in the registry might be the reason behind this problem. One way to fix this problem is by adjusting the audio quality. However, if you want to maintain the audio quality, then to fix this Windows Media Player problem, open the Registry Editor by running the Regedit command and navigate to the subkey given below.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\MediaPlayer\Sett ings\MP3Encoding
Here, open ‘LowrateSample’ and delete the value displayed in the Value Data box. Select OK and exit Registry Editor.
Many times errors also occur when there are corrupt files on the system or there are invalid DLL entries and other related incorrect entries in the system registry. For this, you must try to download reliable registry cleaner software from the Internet and scan your registry for invalid entries. Using registry cleaner software, you can easily and efficiently fix Windows registry problems, and make your PC free from irritating errors.
Errors can occur in Windows Media Player due to outdated files, missing or corrupt DLL files and incorrect registry entries. Most of the time, you can fix Windows Media Player problems by updating missing files or by upgrading the player to a later version. Additionally, to prevent registry-related problems, you can use a registry cleaner software to regularly scan the registry and eliminate invalid DLL entries and corrupt values from it.
Mar 06, 2010 | Computers & Internet
357 people viewed this tip
David Payne
David Payne
