Tip & How-To about Sony Alpha DSLR-A580 Body Only Digital Camera
Import/Convert Canon XF300 MXF movies to Apple ProRes for editing on FCP X
Edit Canon XF300 MXF on FCP X?Transcode MXF to Apple ProRes 422 First
Are you trying to import the HD MXF videos shot with your DSLR camcorder to FCP X? If so, you must be extremely disappointed to see the mxf files being grey and cannot be imported. I have just encountered the same problem.
I shot many mxf videos with my Canon XF300 and wanted to edit them on FCP X, but the problem is that FCP X refused to import them. I turned to Yahoo Answer and found Aunsoft Video Converter for Mac,it helps me convert MXF files from Canon XF300 to Apple ProRes easily.
Following I would like to share the quick steps of Transcode Canon XF300 MXF to Apple ProRes for Editing on FCP X.
Step 1: Import MXF files from Canon XF300 to Aunsoft Video Converter for Mac
Run Aunsoft Video Converter for Mac as the best converter to transcode Canon XF300 videos to Apple ProRes 422.Cick the "Add" button to import mxf files from Canon XF300 to Aunsoft Video Converter for Mac.
Step 2: Choose Apple ProRes for FCP X
After the movies are loaded, click the "format" button and choose their export format "Apple ProRes 422(HQ) (*mov)". Click "Browse" to specify the output destination.
Step 3: Convert mxf videos of Canon XF300 to Apple ProRes 422 (HQ) for FCP X.
After setting the output format and destination, click the "Convert" button under the preview window and conversion from Canon XF300 mxf files to Apple ProRes 422 (HQ) starts immediately. It will complete in a few minutes.
Then you can enjoy your time editing HD ProRes movies on FCP X.
Sony Alpha DSLR-A580 Body Only Digital Camera Logo
Best Mac MXF File Converter-Import/Edit Canon MXF Files to ProRes 422 MOV to FCP MXF file format comes from like Panasonic HVX200/HPX300, Canon XF300/XF305, Sony EX camera, etc. It is not compatible with many programs just like Apple Final Cut Pro. So Convert MXF file to FCP MOV Video is a necessary step to do if you want watch your video from your camcorder which export mxf file. And we know that Apple ProRes 422 , Apple ProRes 4444,introduced in Final Cut Studio, was advertised to one of the codecs to result in less compression and higher data rate/higher quality files for HD editing in Final Cut Pro. Below is the step-by-step guide for you to quickly Convert/Edit MXF to Apple ProRes 422 (*.mov) Final Cut Pro on Final Cut Studio,Final Cut Pro 7 on Mac. Step 1. Add MXF videos to Aunsoft MXF Video Converter for Mac. Connect your MXF Camcorder to iMac with USB 2.0 cable or use card reader to transfer the .mxf files to Apple hard drive disk. Run Aunsoft Video Converter for Mac as the best Mac MXF to FCP Apple ProRes Converter . and click the "Add" button to load .mxf videos. Step 2. Choose Apple ProRes codec for Final Cut Pro. Click the "Format" option, choose the Final Cut Pro > Apple ProRes 422 (*.mov) and navigate to the Final Cut Pro group, you will notice that there are profiles with Apple ProRes 422, Apple ProRes 422(HQ), Apple ProRes 422(LT), Apple ProRes 422(Proxy), Apple ProRes 4444. Here we choose Apple ProRes 422(HQ) (*.mov) as output format. (The Apple ProRes 422 (Proxy) codec is intended for offline editing and contains 30 percent of the data rate of Apple ProRes 422, and I recommend you to select Apple ProRes 422(HQ), Apple ProRes 422(LT) MOV for outputting.) Step 3. Merge Canon MXF files. (Optional) Tick the checkbox for "Merge into one file", and the Mac MXF Video Converter will join and combine the video clips into a single file as output. Step 4. Convert MXF to Apple ProRes MOV for Final Cut. Click the convert button under the preview window, the Mac MXF Video converter starts converting MXF videos to Apple ProRes MOV, and joining the MXF files for editing in Final Cut Studio. After Converting and Merging the MXF files, just import the output Apple PreRes 422 .mov files to Final Cut Pro 7 or Final Cut Pro 6 for editing and the video .Optimize your workflow and save time with the Apple ProRes compression for Final Cut Pro. You can also import the output videos to Final Cut Express (FCE) 4 for editing in full HD.
Jul 13, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
1,956 people viewed this tip
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
