Tip & How-To about Televison & Video
How to get a Universal Remote code
Hey its Me again back with another Short Tip
Many of you have asked , how do i program my remote , how do i get a code? Well while searching this problem for my own personal reasons i came across a website i would like to share with you
Here is the link to the website
http://www.remote-codes.com/Codes4UniversalRemotes.htm
This Website has all codes for all Brands of universal remotes you could think of.
To get a code from this site all you have to do is click on your brand of remote then it takes you to another website where you enter what model it is .etc
Hope this helps stop you waiting for someone to answer on your need code question :)
Televison & Video Logo
code list for universal consolidator pm435s
Please check all links:
pms435 manual (to program) is here:
Universal Remote
http://remote-
codes.findthedata.com/l/163/JVC-Remote-Codes
codes:
Remote Control Programming Codes DVD http://remote-
May 06, 2016 | JVC XV-N312S DVD Player
Program my remote to Magnavox DVD player????
If your Magnavox Remote is a universal remote control, you should look up the code for Magavox DVD player in the user's manual. It also should indicate the procedure to program your remote and the prcedure if your device won't respond to any code..
Don't have a manual?
Do a google search fer
Manual Magnavox remote Mode
Now, if your Magnavox remot is NOT a universal control and it won't work for your DVD, theres is no way to reprogram it.
See some Magnavox code lists here
http://www.remotecodelist.com/
Sep 11, 2015 | Magnavox Televison & Video
i need the 5 digit code to program into a new remote
To program your unspecified new remote please check in its user's manual the codes for your unspecified Home Theater System.
If your unspecified Home Theater System is not listed in your unspecified new remote, please follow well specifed instructions in user's manual, for this case.
If your don't have a manual for your unspecified new remote, you should go back to the shop where you bought it and CLAIM for one. They MUST give you a user's manual. A UNIVERSAL REMOTE WITHOUT USER'S MANUAL IS USELESS!.
In any case, should you specify the make and model of your unspecified new remote, maybe we (I or any other FIXYA user) could find it on line (or maybe not, questoin of good luck, not everything is uploaded)
Also, you can make a Google search for the manual using terms Make and Model, universal remote and manual
So, please be more specific to get help.
Jul 07, 2015 | Audio Players & Recorders
code needed
The Zenith remote control codes for an Innovage Jumbo remote control are:
000, 001, 004, 023, 038, 058, 059, 064, 073, 121, 135, 136 & 153.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Dec 24, 2009 | Innovage Jumbo Remote Control
9,147 people viewed this tip
Top Televison & Video Experts
